swapped tires, still pulls....been reading a lot about the Toyo Mt radial pull to the right and that getting a steering stabilizer that is nitrogen charged will completely eliminate this pull.... now the problem is i cant find any made for the 2015 LML
Wow! So the tread pattern must walk to right and cause that pull. I'm very interested to see if you can confirm that the stabilizer will remedy that. Keep us posted.
For those who have a 4" lift and 275/65/20 (or similarly sized tires, such as 295/60/20)
How is the fuel mileage?
I'm mostly interested in city driving (ie 35-40 mph (ps, I specify because where I live most city is 35 but one town over it's 45))
Also how is highway mileage?
And for those with a BDS 4" how is the ride?
I know lifting a truck can hurt the ride quality but I've heard great things about BDS's ride.
Thanks in advance for any help!
I've got a 6" on mine and my last 400 miles are averaging 16.2 mpg. That's high, back roads, and towns. The ride quality is excellent IMO. Sure it's a little stiffer but the look and ground clearance more than makes up for it. No vibration of walk of any kind. 6" is bigger than I've ever had, not sure I'll get another one this big again, but I like it for now.
With the suspension technology of today's lifts, I wouldn't be too concerned with ride quality from any quality suspension lift. If you've heard good things, it's good to go.
16.2?? Nice! I'm guessing you have 35's? I am currently getting 16.4 on my stock '11 4x4.
I have a 6in lift with 35 tires and get about 13.3 city. I baby mine too. I wish I can get 16. I know the Fabfours bumpers and winch are heavy, so hopefully those are the reasons for the low mileage. Would a tune or a tuner like Bully dog help?
Edited by dt4629
I reset my trip odometer when I bought the truck. Almost 900 miles and 16.2 mpg on that. About 700 miles of that is stock tune, I just put a hyper tech on it but I'm not expecting any mpg gain, just wanted the extra pep.
I can take a pic of my truck and the mpg reading on my truck at noon to prove I'm not lying. Lol.
i believe ya! what is your gear ratio and what tires do you have?
Booyah
C49A7D92-F137-4DE8-8AC2-B14894B3E5BD_zps
I must do too much stop and go driving.. I'm lucky to see 14 in town.. Headed to the Ozarks this weekend and will be anxious to see what I get.. McGaughy's set at 8".. 35x12.5x20 toyo open country MT.. stock exhaust, stock everything else..
I go 5 miles at 56 mph, probably 20 miles at 67 mph with a 40 mph curve and one stop sign. Then a mile at 40 mph with 4 stops and turns. I debated on getting a motorcycle or a 4-banger car for gas mileage, but I'm getting 2.5 mpg better than my 2010 SLT, and this truck looks a hell of a lot better than a Prius. I love this truck.
Debating on a K&N CAI and flowmaster exhaust, but I like how quiet my truck is right now. Don't really want to change anything.
I already added the body. I am going to add a 38x13.50x20 or a 37. I will probably keep another year and then get the 2015 Denali HD and add the 10" bulletproof lift with 40s. I looked at one last week but if I don't buy my wife a new car then I cant get any more toys. Bodylift looks ok but the steps look goofey hanging down so I am adding the amp steps that fold out. I like the truck but I wish I had gotten the supercharger option or just waited on the diesel. Mall Crawler Truck looks good Still wish I knew how to post pics on here
    • 87 down as low as $5.14 here... winning!
    • Progress... sort of.   Intake is disassembled, spider is out, fuel lines removed. Used a torch on the stripped screw with the lower intake off, much easier when I've got the intake sitting on my workbench, I made it talk. Walked right out with a pair of vice grips once it was nice and toasty hot.   New parts are piling up on my service cart waiting to be installed. Distributor, temperature sensor, new gaskets, fuel line kit, themostat, water neck.   My new pickle is I don't want to spend $600 on a replacement spider. I'm not sure IT is bad. I'm probably splitting hairs. Or it's $300 to send mine away and another 3 weeks of the truck just sitting. I have half a mind to assemble everything with the old spider to see if I can get away with just replacing the fuel pressure regulator to be safe. The obvious issue was the gushing high pressure fuel line which will be replaced. Getting to the spider really isn't that hard, and now I know what I'm doing , swapping it would be a breeze should it absolutely need one. Stupid, or smart?   The part that gives me pause is replacing the distributor. Well, it's already out. And I didn't mark it, whoopsie! Engine was at TDC when I removed it, I know that, so upon correct reinstall the metal tip on the rotor should point to the TDC mark on the distributor because that's where it was pointing on the old distributor. Worst case I'm a tooth off and have to re-stab it.   But then, what? I assume the truck will start. It doesn't appear the timing can be set. Here's the problem: These distributors can't be rotated but a degree or two, by design. What I read is Cam ****** needs to be -2 to +2 degrees, ideally at 0 (and checked/set above 1000 rpm). There should be enough wiggle to get that properly set, but checking the reported value is another potential issue. My Actron 9185 scanner says it supports enhanced GM PIDs and Cam ****** is one of them but it's unclear that I'll be able to correctly see it over OBD 1.5. I can see why people end up junking these things with life left in them. They're an absolute nightmare with tweener-year diagnostics/electronics and unobtanium parts.   Fingers crossed it starts and idles nicely. There can be hope, right? I'ma buy a lottery ticket the same day just in case.   Next steps..DO IT. I have not installed an intake before so I've been reading and watching a lot. Some say NO RTV except on china walls, some say DO RTV on water ports but not fuel/air intake. 1/4 or 3/8 bead on China walls? I think my strategy will be, obviously, RTV china walls with overlap on the gasket corners. Chapstick-style RTV the water ports. Leave intake ports dry. The only set of intake gaskets I could find locally are Edelbrock performance gaskets (uh...for an asthmatic 190hp V6? LOL) so we'll see how they do.   #NoToolLeftBehind. It took an hour, but my recovery mission for my deep 10mm socket was successful. It had rolled down the bellhousing and wedged itself between what I think are the fuel lines? I couldn't see it at all, but with a junk antenna I had laying around, I blindly went poking/sweeping for it, heard it clink, raised the truck, and caught a sliver glimpse of chrome with a flashlight way up there in Narnia. I had pushed it farther along the lines holding it captive, but within access of severely improvised tools, poking and cursing at it to finally knock it free to where I could get a fingertip on it to bring it home.    Not much to see.
    • Thats crazy considering im right next door (Indiana)
    • For a limited time, retail and commercial accounts receive an AMSOIL Vinyl Tool Tray with their order of $500 or more when they use code TRAY726 at checkout. The promotion runs through July 21, 2026.   Order at https://syntheticadvantage.com   Want to use AMSOIL in your business or sell at your store, apply here.  https://www.amsoil.com/business-opportunities/?zo=521390
