2017 Sierra AT 6.2L.
BDS 6" lift kit with BDS leaf spring option, FOX coil overs w/DSC front, FOX rear shocks.
SOTA R.E.P.R. 20x9" wheels, 5.5" BS, Satin Black option.
35" MT ATZ's.
  • Like 6
Thats a damn fine looking truck!!
35" MT ATZ's.
Thank You Robert, appreciate it..
Hey guys im trying to put 488 gears on my 2014 gmc sierra 1500 with a 9.5 rear diff and nothing fits i really need help here!!!
If you have the 6.2L or 5.3L with max tow you actually have the 9.76" rear end and nobody makes a kit for it yet. Everything else is the 9.5" and it's the same design GM's been using for years.
i know i have the 9.5 i bought gears for it and it doesn't seem to work
Just trying to help. Start a thread about your issue. This isn't the correct thread.
Okay i got it figured out!! :D 488 ring and pignion and carrier from 9.5 14 bolts diff with a after market conversion yoke and seal works but be carful you might need a new cover or a cover spacer depending on de carrier
Edited by Z71 jeff
Hey guys i dont know how to put pictures, how can i do that? Id like to show you guys my truck
Easiest way is to use the Tapatalk app. Just reply to a comment and hit the camera or image icons.
Sup guys. Got a 6.5 BDS lift. I have a question about my torsion bars. I went with a non-torsion bar drop kit bc i like the clean look, but Im having an issue in the colder weather with the bars bowing and hitting where it passes through the crossmember on the driver side. Anyone experiencing anything like this?
I spoke to BDS and they are aware of the issue, and told me to torch/cut away at the opening where it passes through. I've torched the hell out of this thing to the point of there not being much left, but it's still hitting. I can definitely try to cut out more, but I was wondering if anyone had installed some sort of torsion bar drop bracket with any of these lifts?
Any suggestions?
Any suggestions?
I dont have a good answer for you, but you may get a better answer on the 2500 side of the forum. Good looking truck BTW
Thanks dude. much appreciated! I realized after I posted that this was the 1500 side.
    erickn520
    erickn520
  • Who's Online   5 Members, 0 Anonymous, 551 Guests (See full list)
