Besides adjusting the coilovers to the max in the front, what else could I do to raise the front end to match the rear?
remove the rear blocks which will look goofy imo. Other than that you'll need an actual lift
A smaller rear block yes, but a body lift has no effect on the height or geometry of suspension. So you could definitely do it for added height but for leveling out your truck just get a smaller rear block.
Guy's, I'm considering a small lift/level. I'd like 3-4" overall height increase in the truck. I've read through this 100x and I still have some questions/concerns
My concerns:
- no cutting, no mods that wouldn't be able to return the truck to stock if need be.
- transfer case drop is almost a must considering this height, correct?
- RCX seems cheap and weak with the worst quality ride from the comments
- would prefer to stay with stock shocks
- willing to spend ~$1500CAD, give or take
- looking to fit 285/70/17 +6 offset with no clearance issues at all (255/80/17 on stock offset as well) These almost clear on stock suspension so I'm not overly concerned In this area
- maintain small amount of rake, as I do occasional towing and hauling
- I would say 80% hwy, 20% offroad use
- 2016 Silverado CC, LT Z71, w/ steel control arms
- ready to purchase this week.
- looking to achieve the big/bulky look without sacrificing ride quality
My questions:
- what are my options?
- which of these options is the best quality/ride/warranty/has parts readily available?
- which of these options require cutting of the cross member/x-fer case brackets/brake brackets etc?
- can I get away with just a shock upgrade to achieve this lift?
Any other help is appreciated. Thanks,
I would say the Zone 4.5" is your best option in that price range.
As far as leveling, you really shouldn't level beyond 2.5". After that you should be looking st a lift kit with new knuckles, cross members, and drop brackets NOT one that levels and has a diff drop because those do nothing for TRE or BJ angles
Edited by jimmyboy8301
4.5" Zone cuts the control arm mounting knuckle as well as the differential housing. Not interested.
I agree above 2.5" front lift it should be a proper kit.
My concerns:
My questions:
Maybe a 2.0 inch level with 1.5 body lift?
I might be inclined to push this option slightly as it won't involve cutting and shouldn't sacrifice ride quality.
Aside from this a 3-4" suspension lift that has best quality/ride/warranty/etc kind of contradicts cutting. I'd recommend Zone all day long, I have a BDS in my truck as zone wasn't offered and I love it. The cutting was 100% worth the warranty/ride quality that came along with it in my opinion.
I know zero about body lifts. I reallllllllly want to run the C rated Raptor 315/70R17 KO2's, as they are cheap, light and I don't need an E tire as I don't tow/haul anything with great frequency that would require them.
I'm planning on coilovers to lift/level and greatly improve ride quality. From what I've read, coilovers, proper backspacing and even hefty trimming will not be enough to run these undersized 35's. I don't want to go with a full 4-6" suspension lift so I'm considering coilovers and new UCAs plus a 1.5" body lift.
Will a body lift defeat the purpose of going for coilovers to improve ride? I care more about ride/performance than I do looks.
Just wondering what, if any, the negatives are of a 1.5" body lift.
I despise a body lift. Seems like a way of cheaping out to me. And I hate the fact I have to cut up a 55k truck to fit some damn wheels...
Readylift has a 4" SST kit with UCA's and bushings, what the verdict on this kit? Price is reasonable too.
Found here http://www.readylift.com/products/chevy/chevy-silverado-1500/sst-lift-kits/2014-up-chevy-silverado-1500-sst-lift-kit-4wd-z71-4-0-f-1-75-r/2014-up-silverado-sierra-1500-4wd-z71-4-0-sst-lift-kit-new.html
He's wanting to run 35's, that kit says 33's are the max.
Sent from my kayak
I was replying to my question, not CMSearle2.
I think I may opt for bilsteins and a 0.5" front spacer and small rear block.
6inch BDS, Fox Shocks, 22x12 Hostiles, 33 Toyo MTs, Amp Power Steps, Retrax Pro bedcover. No trim No rub. Rides amazing.
    1981dustin
    1981dustin
  • Who's Online   2 Members, 0 Anonymous, 1,532 Guests (See full list)
