make sure the bulb is seated all the way and installed the same way as the passenger side
K I'll check in the morning. The bulbs only go in one way with one large tab and two small ones. I assumed you turn it to the right once the tabs slide into the housing.
Hmm, sounds like DDM changed their bulb bases as well as their wiring harnesses. Their previous design had 3 equally small tabs so you could rotate & install them in 3 possible orientations.
All the previous troubleshooting pics were only regarding the little light scatter diamonds above the cut-off line.. I haven't seen anyone have the "hot spot" issue.
- Did the bulb come with one or more O-rings?
- Would you post a pic of the HID bulb's base?
It's definitely in the only way it fits. There is a clear plastic oring if that's what you are talking about.
What's strange is that the passenger side is installed identically. The large notch in the housing is in the same place, the bulb inserts in the same orientation, and rotates to the right to lock in. Not sure why one side would project differently if everything is the same. I guess i could try switching the bulbs but that means taking the airbox out again. I still haven't been able to get it to snap back to where its supposed to go.
Edited by Turk10mm
I'm trying to make some sort of a relay harness to help me disable the drls on my truck based on voltage. Can anyone verify for me that kna non-hir 14 silverado the DRLs are underpowered lowbeams? Or are they running at full 12vs constantly?
That's what I read. Then elsewhere I read when the photo sensor senses light it'll distribute -5v pulsating. Then when there's dusk or low light the sensor will distribute the full 12v
Any members that have purchased & installed a DDM dual input kit in the last few months, please send me a PM!
DDM recently changed their bulb & harness designs, so I'm trying to figure out why some members are having issues. Thanks!
Projector housings came in today! Now I just got to find out how I want to mount them and in about a week and a half when my HIDs from DDM come in, I can do the final install and wire everything up! Let me know what y'all think about these. Also what do y'all think I should wire the rings to? I got the rings for the main purpose of helping to fill in the 4" hole created for the stock fogs. I'm thinking of trying to wire them to the DRLs, or should I just wire them to the fogs (but before HID ballast) so that they only come on with the fog light itself
Wire to keyed power, so they come on anytime the truck is on :thumbs:
Would you happen to know what wire I could tap into for that? The halo ring has a built in relay / capacitor so it won't overload and blow the ring. Only trouble for me is I'm still not as familiar with all the wiring like I was on my old car so not sure where to tap. Buddy of mine has a Tahoe that is the same body as my old truck and I was able to walk him through a few entire installations of different aftermarket parts over the phone. 2000-06 body style Yukon / Tahoe / suburban, I've taken that body apart so many times I could probably do it blindfolded and put it back together properly w/ the blindfold
There are Ignition & Retained Accessory Power sources you can tap in the fuse box under hood (but I can't remember which right now and I won't be at a proper computer to look them up for awhile). I let you know when I have a chance, or maybe someone else will post and beat me to it. Check GM Upfitter is you know how to read electrical diagrams.
I'm outside workin on some mounting possibilities right now, thankfully it seems like it'll be easier than expected to mount these things, I'll take a look at the fuse box layout and see which it is.
Here are some pictures I just took. I just pulled out a stock fog housing and wedged the projector in it's place
I checked to see how well it matched the color of the DRLs and while it's not a perfect match, it's not extremely far off. These just have the slightest hint of blue compared to the DRLs
Looking at the manual right now, there are:
drivers side fuse box behind dash:
acc power outlet 2 -- fuse #1
Acc power outlets -- fuse 11
Acc power outlet 1/cig lighter -- fuse 101
Passenger side fuse box:
Acc power outlet 3 -- fuse 1
Acc power outlet 4 -- fuse 2
Retained acc power / acc -- fuse 50
So do I use the one in the passenger side fuse box? (#50) since that is the retained acc power fuse? The only fuse in the engine compartment I saw was the "acc power module / traction power inverter module)" fuse #53. That to me sounds like it would be going to the 110V plug though
Edited by Mike1220
Use a multimeter to detect which circuits come on with the turn of the key by checking voltage drop across the two fuse port terminals. Put it in DC voltage mode, aside from that a test light would work in the exact same setup.
It's worthwhile to have a cheap meter around for small mods and tests like this
Most local auto parts places will sell a "add-a-fuse" or add a circuit, they are a fuse add-on which are very useful
Edited by tanner709
    • Google converting 98 4.3 spider injection to carburetor if all else fails.
    • The truck is a 1995 Chevrolet S10 Blazer, 4.3 VIN "W" engine. :cracks knuckles:   On a whim - because I needed a headache - this truck was for sale so I stopped to take a look. Doesn't run. Well, it does, but barely. Long crank, choppy idle, bad misfire(s), it REEKS of fuel. I can DO this..I'm thinking. Diamond in the rough. One owner until last year. A young guy is selling it, he bought it 6 months ago. It stranded him more than once, he's got a newborn. It was in the shop 10 days ago and he "thinks" they said it needs a new fuel injection system. He can't put any more money into it, needs it gone. I was thinking of upgrading my Macbook, which is a total want, not a need. For less than the price of a new laptop I can have fun for months tinkering on this truck and enjoying it. I'm taking this truck home. The guy was beyond thrilled, his wife was there, she thanked me profusely, I could tell they were hurting. They seemed like good people in a bind.   Some parts, a wash, maybe a set of tires, and I can have a few months of fun and then turn it for beer money (or the next project).   Sure enough, there's a work order from a shop last week in the INCHES of paperwork on this truck dating back to when the first owner bought it. They put a new distributor in it, fuel injection work describes basically opening the plenum and putting it back together. He said he couldn't afford any more work so he had them button it up and that's when he put it up for sale.   I'm not well versed in 4.3. I did discover 1995 uses the 1992-1995 SCPI "Spider" injector which is riddled with issues from splitting lines, clogged or cracked poppet valves and plastic spider legs that crumble over time. Cool. I'll just order me a ne---. Oh, the auto parts store doesn't have it? Rock Auto doesn't have it. eBay? $$$$$$ for used. These are UNAVAILABLE period end of story unless you know "a guy" who's still got one in a box somewhere.   Can't upgrade to the '96-'04 injector, it's a different plenum, wiring/pinout and sensor config.   There are a few kinda "know a guy" -guy rebuild services for these injectors out there for about $350. Okay, Okay... I'd like to know if anyone has used them? Anyone got a lead on these crappy 92-95 spiders?   I also don't want to send MY spider to Narnia and back without knowing if that's truly the problem. I guess I'll need to pull apart the plenum and do some digging.   I was also thrown for a loop. This 1995 model year truck has an OBD-II connector. The interface is decidedly not OBD-II. I can read and reset trouble codes and view live data, but there's not a lot of data. Like misfire count and on what cylinder, that's not there. It's OBD-1.5.   Nothing is ever easy. Now it makes sense why this guy wanted to disappear this thing for cheap. I'm guessing the shop told him the injector is toast, the part is unobtainable and they're not going to sort sending the thing to a rando offering rebuild service on craigslist, and the kid likely can't be without a working car for 3 weeks even if they'd facilitate that.   Experience with these early SCPI's? Stories? Things to check? Sympathy? (..Nah...)   This can sit until I sort it. But I haven't had a problem with a vehicle I couldn't easily solve in a long time.
    • I have four that read by the dash 8 to 10% better than miles/pump calculations and I have one that is spot on.
