Just did a short 220 mile round trip up to OKC on Saturday (GO THUNDER!!), Left on 1/2 tank and did not reset the DIC. I Completed the trip averaging 18.8 MPG best 50 mile MPG was 23.7, I was running 80 MPH. My truck is tuned and AFM is turned off. I'm pleased!
Mike
I just did 230 miles this weekend from Norman to Keystone lake. Did 5 over the speed limit other than on the turnpike I did the posted 75. Got home and filled up (half a tank) and did the average and got 19.9mpg for the trip.
Not bad for a 6.2l truck in my mind.
Those are great numbers for teh 6.2L. Though around town is where I bet the larger engine takes a MPG hit. I can average 18 with my standard 50/50 mixed driving if I take it easy, but my lifetime average is 17. I'm happy.
I am still averaging 17.5-18 in the city with my mixed driving.
My friend bought a 13 Ram 5.7 auto 4x4 and gets a constant 13~13.5, I feel really good about the GMC.
Here is a pic of my onstar to show I am at 18mpg lifetime this is for my 2014 Denali 6.2 4x4 crew. uhe4yhaq.jpg
Sent from my iPhone using Tapatalk -
Edited by dodgehemi0
I've been running 89 octane shell with an ocassional 93 half tank. On a full tank of 89 my mileage was 15.8 on 3/4 of the tank...
Monitoring with tq pro, KR was consistently 2-3* across the board and max at around 4*. So I reset it this morning for 18.8 miles and got 18.5MPG's.
---Filled back up at 1/4 of tank with 93 V-power....Reset trip B and ran 18.6 miles back. 21.7MPG's and -1 to 2* KR across the board and still maxed at 4*.
The truck just holds the gear better with 93 octane, and the knock sensors like the 93 octane. Passed one car and it just feels so much smoother.
---Disclaimer--- No it's not scientific....and some misc info. The 18.5mpg was at 38lbs in the tires and the return trip showed 39-40lbs (tires being warmed up from the trip). Typically 1lb of air in all 4 tires is worth .1-.3 mpg's. Also my understanding and expeirience has been that 1* of timing on a "higher" compression engine is worth around 3-8hp. so theoretically the truck pulling around 2* less of timing throughout most of the trip would mean that 93 helps it gain ~10hp across the board...not enough to quantify but if across most of the map it would reason that this might be just enough to keep it in v4 longer.
Just ran to the lake and back for work yesterday. Filled up right before starting and filled when I returned. A little over 200 miles traveled with 95% cruising at 72 MPH. Hand calculated I got 20.02 MPG and I could not be happier. If a guy could slow down to say 65 or so I don't see any reason it couldn't get 22 MPG on the highway. Absolutely love this truck!!!!
While traveling at about 60-65 mph I usually average around 24-27 MPG! That's with CCSB 5.3L with 3.42 gears on my sierra. It is also leveled with magnaflow and AFE power with K&N air intake. At 70 I get around 22, and then when I start tailgating 18 wheelers in the next lane (that way I don't get any rocks thrown at me) then I shoot up to around 24MPG and 70 mph. Still really impressed and very happy with the mileage these trucks get
Just filled up. 20.1 mpg. That's a mixed bag of driving. Highway, city, mountains, rural and fields. I have a double cab v6 4x4. This tank also had a couple 60 ft burn outs. Can't complain at all!
Yea if you can find a trucker to draft, these things will get 22+ all day long!
Mike
How did you get the AFM turned off?
He has tuned his truck, tuner turned the AFM off thru the tune.
You running the 63 series K&N? I had one on my 07 1500 and it was great. Thinking about getting one for this one since AFE has no desire to make a MIT for the 2014 right now.
    RyGuy43
    RyGuy43
  • Who's Online   5 Members, 0 Anonymous, 580 Guests (See full list)
    • Any joy with this truck seems to be short-lived.   The CEL for P0172 ("bank 1" too rich) is now "intermittent".   I'm not sure where to check, or re-check, and my energy to keep chasing problems with junk is wearing thin. The P0172 seems to set as I'm coming to a stop, completely off the throttle, when fully warm. At least, that's what it's done the 3? times it's set.   Everything appears normal on the scanner EXCEPT long term fuel trim. There's only one bank on this vehicle because it's an OBD 1.5 with only one upstream O2 sensor. At idle, it's around -16.4% and will dip to -18% occasionally at idle or off-throttle. LTFT approaches 0 when throttle is held at 2500rpm. Short term appears normal, much closer to zero all the time. The LTFT tells me the engine is running rich at idle but compensating at higher load. But, why?   The EVAP purge valve doesn't appear to be leaking/sucking fuel vapor continuously. Is it sticking just as I come to a stop and the engine is choking on fuel vapor and sets the P0172? But that doesn't explain the persistently negative LTFT. Disconnecting the purge valve doesn't seem to make any difference.   I suppose that leaves another dang issue with the fuel injector. A leaking fuel pressure regulator, a new leak in the spider, or a leaking fuel injector/poppet valve I didn't see, or a small crack in one of the spider legs.   The vacuum line leading to the fuel pressure regulator doesn't have raw fuel in it. It doesn't even smell like fuel when it's pulled off, not until you suck air through it, then you can tell it leads to a fuel component. I'd consider that normal? Nothing is signaling this is a FPR issue from the outside, at least.   The oil smells like fuel but it's not building volume. I've noticed most oil in most engines smells like fuel to some degree so it's hard to say if the smell is an issue or not. Or if the engine just still smells like fuel because the crankcase was full of it a few hundred miles ago. But it's been changed twice since that original issue of the leaking fuel line dumping fuel into the intake.   Patience is running very thin. Every win seems to be accompanied by two steps backwards, or another issue that leads to removing at least the top half of the intake manifold. Enough! LOL
    • First off you mentioned "Toyo Says" and then gave the pressures 45/50, was this some person at the tire shop that pulled those numbers out of his head ?   Now of course I can't know your exact axle weights front and rear, however I have much the same pickup as yourself other than not knowing your starting weight as per the pounds the truck rolled out of the factory at due to the options yours did or didn't come with or what you have added beyond the extra tire weight. The correct way to know 100% where a person is at is by weighing each axle with the typical weight the vehicle is driven with and that means taking into account passengers and making sure you figure in a full tank of fuel and a little grace for whatever you may put in the bed "groceries" !    I am looking at and not that it really matters as all the tire companies use the same charts anyway, but I am looking at the comprehensive Toyo tire chart in the section that your tire falls under and I know it sounds confusing but your tire is not an LT metric tire like your factory tire but instead because its a standard inch measured tire its under a different category called an LT floatation series tire. That makes a difference as LT metric tires they don't want to see run below 35 psi at highway speed where as with the LT floatation series it can be run down to 25 psi on the highway as long as the weight on the said size of tire is agreeable with or less than that minimum 25 psi. It blows many people away that how is this physically possible, an empty truck for one thing and larger tires with the same size wheel diameter have a lot more air volume so they can carry the same weight as the smaller tire with less air pressure.    So my truck, I have the stock 275/65R20 wheels and tires and I have a bit of weight in the box with a bak flip cover and a rubber bed mat and some tools and spare gas. The front of my gas truck weighs a bit more than some trucks of the similar spec due to double batteries and alternators. However with full fuel and just me in the truck I am weighted such that I can run 40 front and 35 rear and so that is what I have done since day one.    If I base your truck at or slightly below the weight of my truck, in theory with your tires going by the tire chart you might be right around a minimum of 30 pounds front and 25 pounds rear. Of course that would hit pretty much minimum cold inflation pressure one could run with that tire size and a near empty truck. If you have access to an accurate weigh scale to do individual front and rear axle weights I would suggest you do that and make sure your topped up with fuel and whatever else in the truck before you weigh it and then you will have a great starting point to work off of and figure out what your bare minimum pressures are you can safely run. If you do much in the way of hot weather high speed driving, bumping up a bit for a safety margin is never a bad idea but just depends on what type of driving you do. I will include the Toyo chart and the floatation series sizes start on page 31. Without a doubt at these pressures I am speculating at minimum wise for your truck, it would most certainly ride very different then it did when you were using 55 lb front and rear.     https://www.toyotires.com/media/pxcjubjs/application_of_load_inflation_tables_20200723.pdf
    • Take an automotive stethoscope to the vacuum pump. Iirc those tick as well.
    • This landing is worse than most. Patchy blacktop with washouts, soft gravel/sand at bottom that washes out with every heavy rain. I tell everyone to put it in 4WD. A lot of them think they can pull out their trailer in 2WD. They end up digging a hole and then putting it in 4WD.  The lake is a pristine lake and has a lot of money on it. There are several wake boats and lot of large tritoons. The people with the money don't want it improved because they don't want more traffic.    Boat Landing 1.jfif Boat Landing 2.jfif Boat Landing 3.jfif
