I just test drove a 2015 diesel for 35 miles, then took my broken in 2014 1/2 ton with 3.08 on the exact route. Got the same mileage according to the DIC.
Sent from my SGH-I337M using Tapatalk
Did you encounter the exact same obstacles? Such as stop signs/lights/etc, same speed and acceleration style?
So Ive been trying to keep an eye on my MPG since I bought the truck. I started two tanks out with E85 and averaged between 10 and 12mpg. I switched to 87 after that and havent gotten anything better than 16mpg. This is all a mix of city and highway, mostly highway and country roads at 55. I do realize that my oversize tires and my lift will affect my MPG but should it be that much lower than what I am seeing from guys on here with 20 and higher? I just started using Fuelly and will keep posting updates to my tracking.
I would imagine that having the lift and large wheels/tires will prevent me from getting anything noticed by the dealer as far as a fault with the AFM or false claims of MPG ratings, so I dont plan on going that route but I do want to see if its normal or not compared to others.
Edit: Ive currently got 2112 miles on her and my current lifetime is 11mpg
Edited by liftedSLTsierra
230 miles into my new tune Fuel trims are settling in, all city driving with more than a few hard accelerations. photo_zps6bf585d8.jpg
Edited by mzodarg
Did you figure that average or are you going off the computer?
Im just going off my DIC and onstar tracking. But I will be tracking by actual average additionally from here on
How much of an improvement have you seen?
I would say I am equal to what I was getting when the truck wouldn't get out of it's own way. I've only put 200+ miles on it but the MPG keeps increasing and I drive the crap out of it. If It does nothing better then what I'm getting now, I'll be happy.
Mike
Mike
These trucks have a very efficient tune in them already, they lean fuel way out at cruise (normal) have lean decal rates, shutting down half our cylinders, retarding cam timing, reducing transmission fluid pressure at low torque output to remove parasitic loss along with several other little tricks that eventually add up in the long run. I can see some room for improvement and many may see as much as .5mpg maybe even 1 mpg depending on driving conditions but once you get these things running like they should, most people actually see less MPG because that skinny pedal is so damn fun to mash now. It literally may take months before we start driving like adults again to see if we actually gained anything in mileage.
Steve
I am right with you on the mileage. Nothing wrong with the truck it is just the nature of the beast. Lift and Tires then the mileage goes down the drain. Gears helped around town but I am still getting 14-14.5 at 75 mph.
Just completed a 3 day road trip, San Diego to Lake Tahoe, Virginia City, over 2 High Sierra passes, sea level to 8000 + ft, 27 to 95 degree temps and a fierce headwind north on Hwy 395, very little V4 mode majority of the trip, no issues or problems, smooth, quiet and comfy, still an awesome truck.
I've seen huge increases since it's above freezing. Getting 650kms (400 miles) out of a tank instead of 550kms (340 miles).
It seems so finicky
I should mention I took that diesel out for a drive again today. Drove it home in the country and back again, did a bit of running around in town. It was 15mpg, 1mpg better than mine according to DIC.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
