You're missing a relay wiring harness. See diagram attached to post #1 of this topic.
Honestly I have no idea. I have the paperwork somewhere in my room and if I can find it I'll let you know. I just know that the dealership sells many different aftermarket truck parts, such as the AFE intake W/ K&N filter, magnaflow exhaust, and the skyjacker level kit that I had them put on my truck before I picked it up. If I can find the paperwork I will share the model/part # and series
Just filled up again...running all week with approximately 30% city driving I averaged 17.85 MPG figured by hand with DIC showing 18.2.
Sorry - long thread and I probably may have missed something. Is there anything that should be done/you would do right away with my 5.3L to improve the MPG? CAI sounds like a waste and the dealer said an aftermarket tune immediately raises flags for warranty. Still I'm pissed that the speedo goes to 140 and the truck has a 99mph gov on it, not that that would help my mpg - LOL. Magnaflow exhaust? Headers? Would those still be what y'all recommend and having any luck with? FWIW I live in a 30MPH town and get crappy mileage here an in Boston, but on the clear highway 21-22mpg or better is no problem.
Not sure about headers. But changing the exhaust and the air intake to aftermarkets that are less restrictive can help the mileage. Also if you wanted to squeeze every bit that you can, you could lower the back end a bit to level or come closer to leveling with the front and then install a skid plate that covers as much under the vehicle as you can cover. Should help squeeze more mileage. It would help more on highway than in the city tbh. Also try not to carry anything in the truck that you do not have to carry.
Probably the BIGGEST factors, or atleast in my testing they were:
Cut idle time to a minimum, don't Start the engine until your ready to roll
Radio, this can affect how you drive, by this I mean try listening to more of music that keeps you relaxed more than something that would cause you to gun it all the time
Map out your trip as efficiently as possible. Traveling a route that takes you 5 minutes longer is better if it requires you to stop and go less than a route that takes less time but has a few extra stops. This also contains the advice that the 'fastest' route, isn't always the shortest or the most efficient
And the biggest factor of all! Driving habits!
This is not to say that you are a bad driver or a speed demon, but as previously stated and as you've probably been told by several others before, easing into the accelerator and getting up to 30 mph over the course of say 10-15 seconds is much much easier and less stressful, and therefore far more efficient, than if you were to try to get from 0-30 before the next time you have to blink!
I have adjusted my driving habits since I got the truck. I turned a 15 MPG / 20 minute / 14 mile trip to school in the mornings into a 17-18 MPG trip / 24 minute / 16 mile trip.
These numbers are an average over the course of around 10 trips for each route, almost identical time of morning, almost identical outside temps, identical traffic patterns
Sent from
All great advise much appreciated thanks! Trying not to gun it isn't easy in a new truck that flies but I know that the tires, brakes and everything else aren't inexpensive to replace either. Stock 20" AT tires are what $250? Skid plates came on the LTZ Z71 - it's one of the reasons I got it as opposed to the High Country (although I see now they are plastic!). Kinda hate to lower the back because it will sag when loaded up. But there are helper springs I've seen people here install that don't affect the height or the ride, so if I do both leveling and helper springs I'd be in better shape all around - slightly extra weight for that stuff but probably not much. Not keeping much in the back sept for a couple folding chairs, small tool box, fishing rod and golf clubs - LOL. And the occasional case of beer and a few stogies but hey... ;-)')
Just thought I'd put this out there. I changed the wheels and tires on my truck the same time it went in for the recall(18's to 20's) Before that I was averaging 16/17 city 19/21 highway. After the bigger tires it dropped to 13/14 city. Well the other day I noticed that all 4 tires were at 35 psi. I bumped them up to 37 psi (cold), and my city mpg's are back up to 16/17. I haven't driven any highway since but I'm sure that will go up as well. It's only 2 psi but it sure does make a difference.
My came new with 20" and they had 39 psi, I have kept them at the 39psi and like the MPG!
Edited by Audioi
Just filled up again last night. Seems like my "normal" driving routine with about 30% of it being city driving is putting me around 17.8 MPG. And that is even with a couple 0-80 MPH runs. :driving:
Man I love this thing!
I know this shows 25 mile, but the average was even a little higher for my 60 mile trip. The first 25 miles was 21.5. This is with no exhaust flapper and resonator, with a GMPP muffler. Pretty happy with the results.
Just hit this over the weekend. Highway miles on stock truck 65-75mph. I certainly can't complain.
My day to day commute is only a few mile stop and go haul to work so it kills my mileage but if I continue to get numbers like this when I do actually hit the highway then it will keep me happy.
Only way to really see what your getting is put it at the 400 miles .... And look at your trip counters, I rest every fill up and every oil change you can really see what your getting....
BTW.. My truck came with 20s". PSI Set at 40 I was getting great numbers. I drop the psi to 32 ride got way better but lost maybe 2 half mpg So I'm going back to 40 today
I should really raise my tire pressure and see what that does to the numbers. They are set right at about 34 PSI right now. I will raise them to 40 and see what happens.
My 6.2 is getting 14.6 according to the DIC with just over 2,100 miles on it now. 70/30 city/highway.
I have my tires down to 30 psi cold and I'm averaging 17.5 in mixed driving. My tires were near 40 upon receipt, and the mileage was the same. I don't think tire pressure makes as much of a difference as you're giving it credit for. I'd expect less than a 1 mpg hit as long as they're not too low. Anything below 30 is getting low.
    RyGuy43
    RyGuy43
  • Who's Online   5 Members, 0 Anonymous, 391 Guests (See full list)
    • Is it time to put a piece of tape over the CEL?
    • consider doing electrical testing?  I would guess some power or ground wire/connection has a problem.   alldata.com has wiring diagrams, connector pinouts and diagnostic procedures you can use to find where the problem is.
    • Any joy with this truck seems to be short-lived.   The CEL for P0172 ("bank 1" too rich) is now "intermittent".   I'm not sure where to check, or re-check, and my energy to keep chasing problems with junk is wearing thin. The P0172 seems to set as I'm coming to a stop, completely off the throttle, when fully warm. At least, that's what it's done the 3? times it's set.   Everything appears normal on the scanner EXCEPT long term fuel trim. There's only one bank on this vehicle because it's an OBD 1.5 with only one upstream O2 sensor. At idle, it's around -16.4% and will dip to -18% occasionally at idle or off-throttle. LTFT approaches 0 when throttle is held at 2500rpm. Short term appears normal, much closer to zero all the time. The LTFT tells me the engine is running rich at idle but compensating at higher load. But, why?   The EVAP purge valve doesn't appear to be leaking/sucking fuel vapor continuously. Is it sticking just as I come to a stop and the engine is choking on fuel vapor and sets the P0172? But that doesn't explain the persistently negative LTFT. Disconnecting the purge valve doesn't seem to make any difference.   I suppose that leaves another dang issue with the fuel injector. A leaking fuel pressure regulator, a new leak in the spider, or a leaking fuel injector/poppet valve I didn't see, or a small crack in one of the spider legs.   The vacuum line leading to the fuel pressure regulator doesn't have raw fuel in it. It doesn't even smell like fuel when it's pulled off, not until you suck air through it, then you can tell it leads to a fuel component. I'd consider that normal? Nothing is signaling this is a FPR issue from the outside, at least.   The oil smells like fuel but it's not building volume. I've noticed most oil in most engines smells like fuel to some degree so it's hard to say if the smell is an issue or not. Or if the engine just still smells like fuel because the crankcase was full of it a few hundred miles ago. But it's been changed twice since that original issue of the leaking fuel line dumping fuel into the intake.   Patience is running very thin. Every win seems to be accompanied by two steps backwards, or another issue that leads to removing at least the top half of the intake manifold. Enough! LOL
    • First off you mentioned "Toyo Says" and then gave the pressures 45/50, was this some person at the tire shop that pulled those numbers out of his head ?   Now of course I can't know your exact axle weights front and rear, however I have much the same pickup as yourself other than not knowing your starting weight as per the pounds the truck rolled out of the factory at due to the options yours did or didn't come with or what you have added beyond the extra tire weight. The correct way to know 100% where a person is at is by weighing each axle with the typical weight the vehicle is driven with and that means taking into account passengers and making sure you figure in a full tank of fuel and a little grace for whatever you may put in the bed "groceries" !    I am looking at and not that it really matters as all the tire companies use the same charts anyway, but I am looking at the comprehensive Toyo tire chart in the section that your tire falls under and I know it sounds confusing but your tire is not an LT metric tire like your factory tire but instead because its a standard inch measured tire its under a different category called an LT floatation series tire. That makes a difference as LT metric tires they don't want to see run below 35 psi at highway speed where as with the LT floatation series it can be run down to 25 psi on the highway as long as the weight on the said size of tire is agreeable with or less than that minimum 25 psi. It blows many people away that how is this physically possible, an empty truck for one thing and larger tires with the same size wheel diameter have a lot more air volume so they can carry the same weight as the smaller tire with less air pressure.    So my truck, I have the stock 275/65R20 wheels and tires and I have a bit of weight in the box with a bak flip cover and a rubber bed mat and some tools and spare gas. The front of my gas truck weighs a bit more than some trucks of the similar spec due to double batteries and alternators. However with full fuel and just me in the truck I am weighted such that I can run 40 front and 35 rear and so that is what I have done since day one.    If I base your truck at or slightly below the weight of my truck, in theory with your tires going by the tire chart you might be right around a minimum of 30 pounds front and 25 pounds rear. Of course that would hit pretty much minimum cold inflation pressure one could run with that tire size and a near empty truck. If you have access to an accurate weigh scale to do individual front and rear axle weights I would suggest you do that and make sure your topped up with fuel and whatever else in the truck before you weigh it and then you will have a great starting point to work off of and figure out what your bare minimum pressures are you can safely run. If you do much in the way of hot weather high speed driving, bumping up a bit for a safety margin is never a bad idea but just depends on what type of driving you do. I will include the Toyo chart and the floatation series sizes start on page 31. Without a doubt at these pressures I am speculating at minimum wise for your truck, it would most certainly ride very different then it did when you were using 55 lb front and rear.     https://www.toyotires.com/media/pxcjubjs/application_of_load_inflation_tables_20200723.pdf
