I just punched threw pin1 and pin6 on the original connector and just siliconed the wires in places and plugged it in
. Works like a champ. Cargo light controls those pins. No need for a harness
  • 3 months later...
Has anyone gotten a 921 bulb for the cargo light that matched the under rail LEDs color? Bright White...Xenon...VLED 5k or 6k.... to name a few possibilities.
...Yes, I've been reading through the LED threads lol
I plan to install some in the next few days I will take some pics.
Philips Brand LED 921 bulbs, they are bright and macth well
I went with the JDM ASTAR 800
Im thinking of adding a set of rigid dually LED lights to the headache rack on my sled deck and I want to tie them into the bed lights so I can turn them on with the cargo light switch in the cab. Does anyone know what the amperage is on bed lights?
You do know that the bed rail lights can only be turned on when the vehicle is in neutral or in park, while driving the lights cannot be activated.
This is slightly incorrect. The lights will not operate while in any forward gear, but they will operate while the vehicle is in Reverse. I seem to recall from the '15 Sierra I had briefly that they would operate when bringing the vehicle to a stop (forward), but wasn't able to replicate that with the Silverado. I doubt there's a difference in programming as the lack of operation in forward gear is a safety thing, and may be there for Federal DOT reasons (something about white lights facing forward).
^^Thanks block8head for the instructions, just installed this kit on my 2015 HD. I found on mine it was easier to drop the spare to get to the plug in on the harness with the big hitch on the HD it was tight up in there. Got mine on ebay 75.00 shipped without instructions,, best deal I could find at the time.
Thanks again!
Well, I added the second set yesterday.
Noticed a couple of items. I ended up having to mount them slightly lower than the factory lights due to drill bit access to the bed wall. The rail prevented me from drilling as high as I wanted to. I used the provided inserts rather than just throwing a couple of sheet metal screws in there. That was most of the work. They work fine and add the light right where I want it. I have the harness plug end available if anyone needs it.
rmart do you still have the harness available. I would like to purchase it if you would like to get rid of it.
I got some aftermarket set from walmart for like 30 bucks and they worked great! i wired them to that toggle with then instead of drilling into my brand new truck i just took the plastic cap for the hauling ring slot there or whatever off and drilled a hole in it then put the toggle switch in it. It was absolutely perfect and then this way you don't have to worry about forgetting to turn the lights on while your inside the truck or something just when you get back there you flip the switch and your good to go! very happy with the results
Can you provide a photo or part number for the lights you used? I really like this setup!
Sorry loghead, that was snatched up shortly after I made it available.
R
Where did you install these? I ordered these and they wont fit anywhere on my 2015?
    • Hello All!   My 2019 Colorado 3.6 LT, 4WD Crew Cab has approximately 77,500 miles and I recently began experiencing the well-known transmission shudder between about 30 and 65 mph. The problem had worsened to the point that I could no longer attribute it to road conditions - and I had decided to bring the truck to the dealer - when recently, I experienced a sudden loss of power while driving at maybe 40 MPH. Several warning lights flashed, the “Check Stabilitrack” message appeared, and the Check Engine, Stabilitrack, and Traction Control icons remained illuminated. The truck regained driving power, but it stayed in a low gear with unusually high RPMs for the speed. (limp mode?) Because I was only about two miles from home, driving slowly, I was able to make it back and run an OBD-II scan, which showed fault codes U0101, P0700, and U0100. My next trip in the truck was to drive it to the dealer the following day. That trip began normally, but after about a mile I experienced another loss of power, along with the same warning lights and the same “Check Stabilitrack” message. As before the truck remained driveable, but again operated at an abnormally high RPM-to-speed ratio and seemed stuck in a single gear. About a mile later, the dashboard lit up once more, this time displaying “Check 4WD.” Soon after that, I arrived at the dealer. I have verified that the truck still has its original factory transmission fluid, which means it has never received the corrective fluid exchange outlined in GM Technical Service Bulletin #18-NA-355.  That was Thursday of last week and I've heard nothing yet from the dealer.    According to Technical Service Bulletin #18-NA-355 and the build date of my truck, my truck should have the newer LV fluid. I've done a little research and read something about a problem with the wiring harness as well.   Anyone have an insights into this situation?  Thank you!!
    • Having bumper and other body damages can be very frustrating, especially as a result of a parking lot collision/bump. Our team wants to learn more about the damages to your truck so we can look into ways we might be able to help. When you get the chance, please fill out our support form with more details: https://s.gmc.com/support-request . A member of our team will follow up with you as soon as next available. We want to get you enjoying your truck to the fullest again.
    • Did you even read this article?   Even the title of the article says "U.S.-Iran Deal Doesn’t Mean a Swift Return of Oil and Gas Flows"   Remember, crude oil prices are based on FUTURE purchases by the oil companies.  Gas prices are based on FUTURE purchases by the station.  This article stated that many of the oil producing nations have to restart their processes to get the oil produced.  Then the oil has to be shipped to wherever.  And it doesn't get there overnight.  And most of that oil is not coming here. Check out this site:  https://afdc.energy.gov/data/10621   A graph will pop up to show where the US imports their oil from.  Notice that there isn't a lot of import from OPEC and Iraq.  Most of the US import comes from Canada. The US oil produces are selling their oil on the open market, which is why the US fuel costs went up.  So you're correct, the US oil companies are going to slow walk the price downward.
    • Having codes and an engine light with no hints on what might be causing it is nothing short of frustrating. How long have these concerns been present? We want to know more so we can look into ways we might be able to help you. When you get the chance, please fill out our support form with additional details on your experience so far. A member of our team will follow up with you as soon as next available: https://s.gmc.com/support-request
    • Knowing the life of your brakes is a highly important status to keep track of. If you suspect your brake sensors need attention, please fill out our support form with additional details on your experience. When did you last take it in for inspection? Our team will follow up with next steps as soon as next available. Please include your username and GM Trucks Forum in the form as well. Support Form: https://s.chevy.com/support-request
