Im still up in the air on weather to do 275/60/20 or a 275/65/20.... I am going to do the RC 2.5 kit with 2 inch block in rear, is everyone having a little bit of rubbing with the 275/65/20 ?? Right now leaning towards the goodyear wrangler duratracs
I don't have that size but from what I read on here I think you will just have slight rubbing. Are you sticking with stock wheels?
I just put Coopers ATP 275/60/20 on the stock truck/rim and they don't rub, but depending on the tire manufacture their 60 may be higher. I'm going to put the 2" RC lift in my truck to level it some.
ok, I'm sure this has already been talked about somewhere in this thread, but how does the RC 2.5" kit affect ride quality? I'm really enjoying the smooth ride of my new truck right now and I know the bigger leveling kits usually firm up the ride quite a bit.
Hardly noticeable at all
Good to know. My last 2 trucks have been leveled out and I've always ran 10 ply KM2's. I think I may got with all terrains this time.
Fabtech 2" level. I'm not trying to get wild with my truck, it's a dd that is almost all highway some city. I do plan on taking it camping and fishing so I do plan on changing the tires. Probably go a smidge bigger with a more terrain oriented tread.
Edited by Papa Smurf Rides On
I have that setup and still rides pretty smooth imo. Can notice it on bumps/ potholes though
Just curious.
I'm reading these posts about leveling out the front end, but some are using a block in the rear as well.
Is that just for a little bit of rake?
I have 275/65's. No rubbing just need a cable tie the inner liner back. Both sides 3 mins. each
I have a 2014 with the rough country 2.5 with 2 inch blocks, it says that it is a leveling lift kit. The level is the 2 inch kit for the front. it looks level now but it looked perfectly level with just the front done, to much so. I knew that it would sag if I just kept the 2.5 front level lift kit on it when I loaded it down with anything. Now with the blocks it sits levelish with the rear a little higher just in case so it doesnt sag so much.
post-130309-0-52410600-1401911925_thumb.jpg stock bad picturepost-130309-0-99476000-1401912019_thumb.jpg with 2.5 front lift level and 2 inch blocks.
Keep in mind the driveway is not level at all and the rear is way down because of it.
ill be using the stock 20inch chrome wheels
When I bought my truck they had installed my RC 2.5 and put Toyo AT's 275 /65/20 (wrong ones though) and I never noticed any rubbing. But, I didn't like how narrow they are. Then went to 305/55/20 Nitro Trail Grabbler, and those sucked something terrible! Took the back, and had them install 285/65/20 BFG which I'm not a fan of but better than the Nittos. They barley rub on hard turns. I know have decided to take a step back and go with a new aftermarket 18" wheel and Toyo MT 295/70/18.
I hope they don't rub.
Hope that helps...
Got my Rough Country 2.5" level kit installed with 20x10 (-19 Offset) monster rims with 295 55 R20 nitto trail grappler tires. :D Rides different but not bad. I did not drive it far enough yet to see how the mileage is effected, but it seemed to still be dropping into V4 mode fine and the instant mileage looked to be only slightly lower. I will have flares added to it by this weekend I hope. I think it is coming along. So far I am completely happy with this :chevy: truck.
    JJ_Denali2020
    JJ_Denali2020
  • Who's Online   4 Members, 0 Anonymous, 437 Guests (See full list)
