I finally got around to installing a 2", under strut leveling kit on my truck. They're the Moto Fab billet aluminum blocks. I noticed that the one of the lower bolts for the strut, on each side was contacting the cv-shaft, so I added a couple extra washers under the bolt head to bring down the height of the bolt threads extending past the nut as a temporary fix. Has any else run into this interference/contact between the fastener and the cv-shaft ?
I had the same issue. I put the bolt in from the top and put the nut on the bottom.
It didn't seem like there was enough clearance to get the bolt in from the top. I'll give it a try later tonight and see if I can get it in that way.
I didn't have any luck getting through to Moto Fab's customer service dept. Their website doesn't even show the "under-strut" lift blocks any more so I'm curious to see what they have to say.....
Just got my level kit installed! 2.5 rough country. Wheels and tires on Monday. If anyone lives in Phoenix I highly recommend Prestige Customs in mesa. $299 installed with alignment. Plus I got a deal on a set of 20 fuel mavericks and toyo mt tires. Feel free to email me , the truck rides great. Stop doing your research and get this kit.
Can't wait to see it. What offset are the new wheels?
RCX I put a set of old Nitto 285/55/20. Clear no rubbing, really didn't wanna go bigger. Still get 24.7mpg on the highway running 65.
Already ordered a set of wheels and tires. 2010 bmf wheels that are 8 weeks out due to custom engraving, and a set of toyo at2 285/55/20 that are 4 weeks away.
Plan on running the tires till april then swapping everything out.
Before
C82F8A57-30FF-4BF8-81BF-C8713BB8E25A_zps
AFter
B4696CCE-5448-4C2F-B5D7-A47D78CE4C0E_zps
Think I can squuzze 5k miles out of these tires.
75BACA4B-C721-46AF-8961-8C3F15645C2B_zps
For everyone that has a level and bigger tires, what mpg are you getting on the highway? I assume most people on here are not too worried about their gas milage given that we are putting big off road tires on our trucks. I installed a 2.5'' level with 305/55R20 Nitto trail grapplers (33.39x12.60x20 from Nittos website) I also removed the bottom plastic air dam piece or whatever the correct term is, could that play a part in decreasing my fuel economy?
Previously coming from driving a 2008 NNBS sierra with 6'' lift and 35'' tires and the small 4.8l engine with a Black Bear tune i was getting right at 15mpg cruising at 70 and that makes me think my new 2014 should be getting a little better mpg that what i am actually getting right now.
Previously coming from driving a 2008 NNBS sierra with 6'' lift and 35'' tires and the small 4.8l engine with a Black Bear tune i was getting right at 15mpg cruising at 70 and that makes me think my new 2014 should be getting a little better mpg that what i am actually getting right now. 80c40bfb43ed8a8d3c43a20ba14d9665.jpg0830dffddd910464a1c501b2b1164a62.jpg796007da0984d6c6b92b63a0e1413acf.jpg
Looks great!! How's the ride with the 305s?
What mpg are you getting? MT tires loose a good 1/2 mpgs. I have had my lift for 5 days and am still getting 18 mpg average. My toyo MT tires will be installed tomorrow. ...
Before
AFter
What lift are you running to clear those?
Got the wheels and tires in today. Man it looks good!
What size wheels and what tires did you go with?
Sent from my SM-G900V using Tapatalk 2
    250.3k
    Ragg-Boy
    Ragg-Boy
  • Who's Online   5 Members, 0 Anonymous, 959 Guests (See full list)
    • I had skimmed through that article when you posted the link and honestly I felt rather defeated in a sense and realized that all these years in changing oil that in fact putting in what I was told was a good quality oil was probably not filtered as well as it should be although the filter put on the engine would be what ( as long as it never went into bypass mode ) would be the final filtering of the new oil that the engine components would first see, but then the filtering media itself is not up to par to what is ideal because a full flow filter would be too restrictive to filter fine enough for the engines best outcome in the long run. Only one of our tractors over the years which was a Versatile with a 855 Cummins had a separate bypass filter, some engine manufacturers did spec a partial bypass system within the main oil filter but I don't believe any other trucks or equipment I was servicing used such a filter. No doubt a product like the Amsoil bypass system is of benefit as long as nothing goes sideways with the extra plumbing and filter such as a rupture/leak that could cause the oil to pump out of the engine ( yes that Versatile had a remote canister with hoses routed to it as well ). With the idiot egr system on a diesel and as a result forcing a lot more soot into the oil, that certainly isn't helping the diesel engines cause or as you pointed out the GDI engine issue with creating more soot and aside from having a fancy secondary filtering system, changing the oil more often helping lower the total soot load.     So oil manufacturing and the end product is not something one can control and I wonder if there are specs on what various oil packaging companies produce in particle count or size. As to the filtering, if the OEM is not designing a filter size and spec that is really what it could be, they too are short changing the end user and so what is the answer. Of course as you say the oil side can only do so much if the air side isn't keeping up its end of the picture and air filters are only so efficient and if in a dusty environment such as farm or construction or driving gravel roads there is a lot of dirt to filter out and some of that ends up into the air stream.    Of course the irony in places like where I am where they dump the salt on the highways but also will mix in some calcium or outright pure calcium for problem road area's, or using calcium as dust control on gravel roads, the vehicle that gets used in that environment may rust out before a properly engineered engine and maintenance finally wears out so one has to face that reality in the rust belt.
    • Has anyone run these on their 2500?
    • have you stuck with dealer oil changes since then? I made the same switch after getting tired of crawling around under the truck, but I’ve found some dealers are way better than others about getting you in quickly. Curious if yours has been good about scheduling or if you’ve had to look elsewhere for quicker turnaround.
    • Thank you.   I am set on a 3.0 Duramax as my previous truck with a Ford Ecoboost had just as many, if not more, "common" issues.  Cam phasers, timing chain issues, 10-speed valve body and CDF drum, emissions issues, etc.  So I figured, why not get 2x the fuel mileage (these things got 27+mpg on every mixed city/highway test drive I put them through) and better towing capability with resale value to boot?   My minimum, shortest trip will be 50 miles 1-way and I regularly go out of state with a travel trailer.  I'm planning on using this for a marketing/event promotion business also, which would require regular towing of trailers for bands, DJs, sound and lighting gear, along with my personal camera gear for filming events.   Looked at other trucks in the $30k+ price range but the issues seem to be everywhere, plus too many with gaudy mods.  I'm literally sticking with RWD trucks because they tend to be actually used as trucks, vs. the 4x4 models I've seen with unsafe lifts, huge tires, and general mods that would affect reliability (I'm wondering if some of them were tuned, hence the aggressive throttle response and hard shifting).   So my goal is to find a stock, 3.0 with 1 or 2 owners, in good physical condition, and decently well maintained.  Can't seem to find that up here, everything in the $27-30k range has had multiple owners, smoke smell, issues, or body damage.  Or the ridiculously modified trucks with 80k miles for under $27k but lots of problems...
    • That’s pretty tough Grumpy. I reread the previous few posts. They all reference oil changes. Much like your last thread. In my humble opinion it keeps things interesting.
