For some reason the z71 will fit but yes it won't give it a lift. So basically there pointless if u have z71. Sorry. Mine is 4x4 LTZ Max tow
Sent from my iPhone
using Tapatalk
This is the ready lift 2.25 in the front and 2 in block in the rear
Before
After
UPDATE With Tires
275/65r20 Cooper ST Maxx
Edited by tx2014
Where are you guys getting your head lights re aimed ? I have been reading I should or will need it ?
Installing 2.5 rc level kit this month
Thanks in advance
Thanks in advance
Just do it yourself. Then you can do them the way you want. I let the dealer do it because I wanted them to check the alignment cause after 600 miles I felt it starting to pull. When they readjusted the headlights they aimed them all th way down. So the cut off line was on the ground 40 ft infront of the truck.
If you do it yourself the adjustment screw is in the center on top of the headlight. You will need a Philips or Alan key.
Edited by Mike1220
Mike , thanks again for the info brother.
Do I have to pull anything off or will I see it and adjust from there ?
Sent from my iPhone
using Tapatalk
that is odd, since there wont be a lift, what if I left the level kit upfront and just ran these with it? possible? im thinking the ride would still be better. and if it doesn't lift it wont throw the front end any higher and mess up the angles.
Blue Line, on 12 Jan 2015 - 3:40 PM, said:
I saw the same thing Bub...I have a LTZ z71 and was looking into the Quick lift also. I have an email into Rancho. Waiting for reply.
let me know what they say. I ordered anyway in pairs. I can put the rears on if the fronts don't work and return them. but that makes no sense, my front end looks just like my buddies regular 4x4. its no higher.
ive also read through some other forums and threads and seem someone else had them on a Z71 and did it. so im curious now as why it wouldn't lift
Just need to pop the hood and you'll be able to see it.
I have to adjust mine down after a 2 inch. I don't like it how it is now.
Yeah me too.
Will need to do a before to see where they should be after I do the level
Funny , the local led bulb guy who works as a one man team wanted $50 to re aim.
Love this forum for this very reason ,,,everyone has some info on a truck we all love
I'll be getting my 2.5 RC front only Thursday with 305/60r18 on stock wheels, I've seen posts where some say they will rub and some say they won't anyone know for sure?
I have a 2.5 inch level and those are the tires I want as well. I've heard that some trimming is needed, but maybe someone that has this setup will chime in.
Here's my bone stock 2015 Sierra All-Terrain "before" pictures for reference. Plans are 2.5" RC kit up front, gonna leave the stock blocks in the back. I'll swap for the RC blocks if I have less than 0.5" rake or looks "nose high".
It's also getting 295/55r20 (33x11.5) Toyo AT2 Xtreme tires on stock 20's and black Bulletproof offset mud flaps. Should be done after the weekend, I'll report back with "after" pictures and measurements.
Here's a little bit of an update, got the Rough Country 2.5" kit installed up front and the 295/55r20 Toyo AT2 Extreme tires on.
Decided to leave the stock blocks in the back for now, had the shop send me a couple pics and take a few measurements.
Currently sitting at 39.5" up front and 39.75" out back from ground to center of fender.
I'll give it some time to see if it settles and if I change my mind I can easily swap the rear blocks.
Just have to get the BulletProof offset flaps on, tint the front windows and get the front bumper PPF installed.
Edited by hutch08
I'll give it some time to see if it settles and if I change my mind I can easily swap the rear blocks.IMG_0690_zpsdpawzrdr.jpgIMG_0691_zpsq3ct4wep.jpg
Please post more pic when you can. Bad ass truck
My stock Hollander 5308 wheel are 8.5 wide. Can you tell me what width those stock GMC wheels are?
    Sothpaw27
    Sothpaw27
  • Who's Online   2 Members, 0 Anonymous, 439 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
