I'm trying to play it safe being that there's only 2 inches added up front and 0 offset.
Nitto tech specs:
275/70-18= 33.62x11.10
285/65-18= 32.83x11.93
285/75-18= 35.08x11.26
I have the 275/70/18 on stock rims. I went with the Hankook Dynapro. So far so good. No rubbing. We got a ton of snow and they have done really well. They look fairly aggressive but not too noisy. I'm pretty happy with them. I did measure my truck after installing the Bilsteins. 38 to front fender and 38.25 to rear. It's damn near level. I'm running lower air pressure right now with the foot of snow we have on the ground. It may come up a little more once I start playing with more air pressure. The tire dealer only put 37 lbs in the tires and I think I'll take them up to 45 and see how it rides once the roads clear up.
Turned to full lock, how much clearance for a larger tire is there? To the sway bar and bumper corner? If you could look please. Thanks.
After the 18" tire size dilemma I've decided to go down to a 17" tire and settled on cooper St maxx's in 295/70/17. Little over 11.5" wide and a little over 33" tall, which is what I was aiming for. Might I add, Mr. Wheel Deal was the best prices I could find anywhere, online or local by over $500
I probably missed the 18 in rim dilemma but what backspacing are you using on the 17s, and what was the issue with the 18s? Thanks
I have 275/65's. No rubbing just need a cable tie the inner liner back. Both sides 3 mins. each
spx what liner are you talking about? are you running stock tires? Im doing the 2.5" RC level and going to be running mayhem wheels at +18 offset and tera grapplers 275/65/20.
The issue with 18s is the tire sizes available 275/70/18 just isnt quite big enough and 295/70/18 is too tall.
17s solves the problem by going with 295/70/17 you get the width and a good height.
the plan is to go with 17x9 +0, today. That plan may change by supper time lol
I got my 285/65-18 32.83/11.93 Nitto Trails mounted on my 18x9 0 offset today! Haven't encountered any rub so far!
Rough Country 2inch level up front . Zone add a leaf out back 275/65r20 Duratracs. bca21d71-9b9f-4277-a7d2-6aaaf1ec92aa.jpgIMG_20150221_104315.jpg
u have just 2" RC kit in the front? Does that size tire rub at full lock?
Sent from my iPhone
using Tapatalk
and yes it rides awesome. I had RC leveling kit before. Now rides awesome. U get what u pay for
Sent from my iPhone
using Tapatalk
How much did you find them for ? just curious
i paid a company to do everything. It cost total I think around $850
Sent from my iPhone
using Tapatalk
Sent from my iPhone
using Tapatalk
Oh ok, I'm running 285/75/17 cooper a/t tires and xd hoss rims but I'm not feeling the look anymore but i don't want to go to a larger tire because gas mileage will drop even more.
I want a little more offset than the xd's i have
whats the offset?
Sent from my iPhone
using Tapatalk
Sent from my iPhone
using Tapatalk
yes it rubs the on the fender liner, but if you wire tie the liner back you can get plenty of clearance. even the people doing the 2.5 kit have to do this to fit this tire.
