Tyler1199 Posted April 12, 2015 Posted April 12, 2015 Here's mine so far. RC 2.5" level/Lift 20" XD mavericks w/ 275/60/20 KO2's removed assist steps HIDS on front w/ LED fogs LED reverse/license plate lights tinted windows. Need to figure out what I'm going to do as far as a sub and shell probably be done/]\ 3
Tyler1199 Posted April 12, 2015 Posted April 12, 2015 i just recently bought a new 2015 gmc sierra AT package having a 2.5 RC level installed this week and just ordered 285/60/20 duratracs....am i gonna run into any rubbing issues...i see most people here are running a 295 or 305 with small to no rubbing issues. any input would be appreciated thanks. usually those running 295 or 305 are running a 18" or a shorter tire. Im running 275 no rubbing it would be getting close w/ 295 pending on tire. You may have non or just a tiny bit
Ruben Trevino Posted April 12, 2015 Posted April 12, 2015 (edited) I own FastHeadlights LLC and we do work on headlights all the time. I just took the orange out and replaced with some switchback turn signals Do you have a link or a video on how to modify the lights? Edited April 12, 2015 by rubens megatron
Ruben Trevino Posted April 12, 2015 Posted April 12, 2015 (edited) . Edited April 12, 2015 by rubens megatron
Mike1220 Posted April 12, 2015 Posted April 12, 2015 Do you have a link or a video on how to modify the lights? I just did a lot of work on my lights. Used the same method to open them that Phil does. Check it out, may help you out http://www.gm-trucks.com/forums/index.php?/topic/171698-Mike1220%27s-SLT-Sierra-halos%2C-color-change-DRLs%2C-and-FXR-retrofit-w
Ruben Trevino Posted April 12, 2015 Posted April 12, 2015 I just did a lot of work on my lights. Used the same method to open them that Phil does. Check it out, may help you out http://www.gm-trucks.com/forums/index.php?/topic/171698-Mike1220%27s-SLT-Sierra-halos%2C-color-change-DRLs%2C-and-FXR-retrofit-w oh, I was kind of hoping it was available as a preassembled after market item like a plug n play. I wouldn't want to risk messing them up, so id rather pay a little extra for a prefabbed pair, but thanks for the link and the info
langston1726 Posted April 12, 2015 Posted April 12, 2015 4" leveling kit with 2" blocks in rear Could you post a couple more pics? That stance looks perfect. What's you wheel and tire combo? Sent from my iPhone using Tapatalk
K2jer Posted April 12, 2015 Posted April 12, 2015 Just did a custom leveling kit. RC 2" Spacer in the front and bilstein 5100 struts at .6 lift. And in the rear I used the 2" RC block and bilstein 5100 shocks. The truck rides 100% better then stock Rancho Shocks. Smooth and controlled over bumps and that stupid hope the rear end used to do is now gone. Front end is 39.75 and rear is 40.75. Super happy with stance and ride. Would recommend this setup. 2
Whiskey Bent Posted April 12, 2015 Posted April 12, 2015 Just did a custom leveling kit. RC 2" Spacer in the front and bilstein 5100 struts at .6 lift. And in the rear I used the 2" RC block and bilstein 5100 shocks. The truck rides 100% better then stock Rancho Shocks. Smooth and controlled over bumps and that stupid hope the rear end used to do is now gone. Front end is 39.75 and rear is 40.75. Super happy with stance and ride. Would recommend this setup. Got any pics? This is what I was going to do but held of because I wasn't sure how the ride would be.
cameronfaber Posted April 12, 2015 Posted April 12, 2015 (edited) Could you post a couple more pics? That stance looks perfect. What's you wheel and tire combo? Sent from my iPhone using Tapatalk Yes more pics & i agree perfect stance but where did you get the level kit from? Edited April 12, 2015 by cameronfaber
cameronfaber Posted April 12, 2015 Posted April 12, 2015 4" leveling kit with 2" blocks in rearYes more pics & I agree perfect stance but where did you get your level kit from?
XxcraigxX11 Posted April 12, 2015 Posted April 12, 2015 Just did a custom leveling kit. RC 2" Spacer in the front and bilstein 5100 struts at .6 lift. And in the rear I used the 2" RC block and bilstein 5100 shocks. The truck rides 100% better then stock Rancho Shocks. Smooth and controlled over bumps and that stupid hope the rear end used to do is now gone. Front end is 39.75 and rear is 40.75. Super happy with stance and ride. Would recommend this setup. Very interested in this setup as well. So I second the pics request. Lol
nadrojcote Posted April 12, 2015 Posted April 12, 2015 (edited) Has anyone else noticed a mark where their spindles and lower control arm are coming in contact after leveling? I have the mark on both sides on the front side of the lower control arm. Edited April 12, 2015 by projectsummit
