I would think both should lift 2" as well. The suspension setup on the old GMT 900s is pretty much identical to the new K2xx at least in the front
Both kits are for the k2xx trucks, but the new kit just has a different look to it. It still lifts 2"…
Same truck with 2.5" leveling kit and single add-a-leaf:
Still have a Zone 1.5" body lift for it too, haven't decided for sure if I want to put it on or not.
Edited by magstar67
attachicon.gifImageUploadedByTapatalk1431579154.380615.jpgattachicon.gifImageUploadedByTapatalk1431579169.759214.jpg
What add a leaf kit did you go with? It looks great!
Add-a-Leaf was from Zone. I like having some rake in the truck for towing and hauling, it didn't affect the ride that I could tell either.
Mdrew, they never rubbed but I only had it about a week before I did the leveling kit so no off road but they had quite a bit of clearance. I wanted to go bigger but felt these were a good compromise because I didn't want bigger tires to rub or effect the gearing and shifting too much.
It seemed like it was pretty hit and miss if they will rub somewhere with bigger tires based on reading this forum.
If I do the body lift, I will probably do some wheel spacers and flares to balance it out. Also haven't ruled out getting some 17 or 18" anthracite Fuel Anzas to get a wider stance. I like the quality of OEM wheels though, I see a lot of aftermarket wheels that don't age very well.
well guys the deed was done. the fiance and I got out 14s leveled and new tires for both.
Babe's is a 2014 crew cab 2WD and she got a pro comp leveling kit with BFgs KO2s in 275/60/20s
here is a couple of bad phone pics
her side
20150514 150221
first shots 2" level BFG Ko2
Mine is also a 2014 but double cab and 4WD also pro comp leveling kit but I have mastercraft courser mxt's in 33X12.5X20 (or 305/55/20)
more bad photography.....soon we will get good pics but I have to go back to work to North Dakota tomorrow so no time for the beach for snazzy pics!!
20150514 150214
20150514 150246
his and hers 1
Thank you. I have some Falken ATs on order. Same size. I also have Zone 2" spacers coming, just in case they rub. I have the mag ride though, and not crazy over changing the a-arm geo with spacers and oem a-arms with mag ride. But, the rake on this truck is just too much. I think a 1" rake would be perfect, and maybe air bags for towing. I'll be experimenting. ....
Took some pictures today, project is getting closer to completion! 305/45r22 dynapro atm 22x9.5 dub baller and rancho 2" quicklifts.
gallery_140298_3351_3336934.jpggallery_140298_3351_3923782.jpggallery_140298_3351_4085976.jpggallery_140298_3351_3448263.jpggallery_140298_3351_3329746.jpg
Crappy photoshop but was wondering what white corners would like......nice truck bro. Good work
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
    • Is it an optical illusion in the pic or is the truck really squatting that much horribly?
    • My initial introduction was here.  It's hard to believe that I last posted in February 2013, having just deployed to Kyrgyzstan.  Since then, I've retired from the military and the 2006 Sierra SLT Z71 that first brought me to these pages was lost.  I went forward to Afghanistan in March 2013 and did a lot of sitting behind a computer on brigade staff.  Within 18 months of getting back to the States, I was selected for Drill Sergeant duty, after which I moved back to Virginia (my home state and where I served from 2004-2008).  That '06 Sierra did a lot of driving between Louisiana, Georgia, and Virginia, and ended up with nearly 320k miles by 2022.  By then, the registration had been expired for a couple of years, but the pandemic had all but eliminated tickets for such transgressions.  Admittedly too, I usually drove my wife's SUV or son's car the 2-3 times a week I had to report to work.  Teleworking sure was fun while it lasted.   I started my retirement leave four years ago and stored the Sierra at my sister's house.  A big mess was made when her fiancé passed while she was taking care of business out-of-state in late-2024, and his son pretty much mismanaged everything to do with the estate.  Even so, I was assured that my truck was safe... until it wasn't.  I found out that my truck had been scrapped about four months after the son took over everything.  There's nothing I could do; I'm 1000 miles away and it was technically abandoned property since he'd even trespassed my sister from her own house (she had no claim to it as she wasn't married, and the fiancé was the sole owner).     Anyway, today I got my second Sierra.  This is a 2010 SLE 2WB CCSB with a little over 200k miles on it.  It's got the 5.3L I'm familiar with and should handle what I need it for.  Hauling stuff that won't fit in the Transit Connect (yep, I sold out, but that's the wife's vehicle) and towing a few times a year tops.  The price seemed decent, considering how much people sell their trucks for in the Deep South: $4500.  I've seen similar trucks listed for more than double that.  I got it from a coworker who left his tag on until we transfer the title next week (Louisiana requires a notary for transfers), so I've been driving it all day.  The rear speakers don't work, which is one of the things that brought me back to these forums earlier.  I can't say how active I'll be as a poster, but I'll be scouring the archives while I find out every little thing I can about the 2010s and particular nuances/problems with my truck.   It's definitely not a GMC, but I got another Willys Jeep a few months back as well, so I'm almost at the same place I was when I first joined gm-trucks.com.  My old 1960 DJ3A was sold back around 2010 or 2011; my current Jeep is a 1946 CJ2A.  So, I've got a slightly newer GMC and a much older Jeep.  I kind of wish I still had that F-250 I had way back when too.  The Dakota is long gone and was technically my brother's truck, though I had it registered and insured.  The F-250 had to go when my grandmother's house was foreclosed on due to mismanagement around 2012 or so.     Hopefully anyone that made it this far isn't too annoyed.  I tend to be long-winded, but I'll be doing more reading than posting in the coming months.
    • There was a recall on the tailgate in general for opening on its own. Mine has a cap on it and it won’t let the tailgate open.   My tailgate has two holes in the top of the tailgate. I filled them in with silicone sealant.
