this may have been covered before but i cant find it in the search.
i have a 2015 and im going to do a 2 or 2.5'' level and want to put on bf goodrich all-terrain t/a ko2 tires. i know 285/65-18 will fit no problem but was wondering if 305/65-18 will fit. i dont mind working with the fender liner to make it work. but will it run the upper control arm or anything else?
thanks
This was one tire I looked at too and from my memory (not to be trusted :lol: ) that will work. But as of right now, the KO2 does not come in that size. It's the one I want to hold out for though. Some websites have that size listed, but I emailed BFG and they confirmed that it is not out yet. When I was researching I was looking at people running that size in the original ko. Some have run the 305/60/18 with no level with no problems and the 305/65 is around .6" taller, so with a level it all depends on offset.
thats kind of disappointing. i was hope to get a set of those tires in the next 2 or 3 months.
thanks for the info
Whats the average/decent price for kits & installation?
A 1.5" level and window tinting will be the first mods I make coming up this summer/fall
Congrats on the new ride! Instead of using an RC leveling kit I installed the Bilstein 5100's on the front end of my '14 Silverado 1500. These allow you to choose how much lift you want on the front end. I have mine at the highest setting which brought it up to just under level, front = 38 1/4" with the stock rear at 39". They cost a touch more, $110ish/ea but after some research I found that these don't limit your suspension travel like some of the other leveling kits. Since I'm an avid hunter and outdoorsman that's the last thing I needed. I installed them myself which wasn't too bad, just had to rent a shock compressor, it took probably 3 hours. They are also coming out with the 6112 which is basically a beefed up version of the 5100. I would definitely give them some thought if you're going to be taking your truck off road a lot. Congrats again man!
Edited by PowderRiver Let'rBuck
I went with the "Ready Lift 2.25" level kit. I have a 2014 Z71 pretty much like yours, and my truck was raised exactly 2.25" in the front. No change to the rear blocks. The end result is that the truck now sits 1" higher in the rear, but to my eye, it's pretty much level.
The "Ready Lift" costs substantially more than kits from RC, which apparently do the job fine, but in my case, my dealer sold and installed the kit, so I thought it was worthwhile to have had the "Dealer" handle the install, in case any issues come up later on. I'm from Canada, so prices are sort of ridiculous up here, but my cost for the level kit "All In" including the kit, install, taxes and front end alignment ended up around $600. Not all that bad, when you consider the level kit from the dealer was about $225. I'm not one of those "do-it-your selfers".......I'd rather pay and be sure it was done properly.
Here's a few shots of the truck......the first pic almost looks like the nose sits a little high......not the case, the truck looks pretty much level to me. The second pick is taken at the same location, before I had it levelled
Rev
Edited by revitupfaster
Ok just got all done with the leveling kit. First picture is of the day I picked it up.
Second and third picture is of it with just the front RC spacers installed.
Next to my dads 2015 high country
Measurements were:
39 front wheel well
38 rear wheel well
18 front of cab
17.25 back of cab
Here it is with the 2 in blocks in the back
39 front wheel well
38.75 rear wheel well
18 front cab
18 rear cab
Are those stock tires?
Thanks for the replies. It shouldn't been too long here before I have enough to get some work done.
I wish it would stop raining so I could get out n give the truck a wash and snap some pics. Soon though, weekend looks promising for some sun shine.
Im definitely not a DIY guy, I will pay someone to do it
Edited by quise2024
Silverado cabs level out with the fenders. Sierras don't. Mine needs to be 1.5 higher in the rear for the cab to be level.
thanks
I have essentially the same tire size, but mine are 305/45r22 and they rubbed on the sway bar with rancho quicklifts that give about 2.25" lift. Smaller rims like 20's and 18s are known to rub on the upper control arms as well. I replaced my upper control arms with skinnier rough country control arms so I can't comment on if I would I would have rubbed or not. I got around the rubbing by installing some 1/4" spacers, I got 4 of them for around $20 on eBay. It was the only size that left some hub for the rim to sit on. The hub only sticks out 1/2" so 1/2" spacer was out of the question for me. I now clear the sway bar but can make it rub a bit while turning at full lock. Nothing to worry about really. I was also rubbing the fender liner so I zip tied it back and out of the way.
how did you get the rough country uppers? the only way i see them sold on there site is with the 3.5 inch kit
Called them and they have part numbers for 2014+ and they're different part numbers if you have aluminum control arms. $250 + tax & shipping. They said they're not listed on their site.
okay. thanks
Shocks like the Kings and Fox may have longer extension than stock. Frankly, I didn't measure my Kings against the OEM Ranchos for full extended free length when they were out of the truck. I installed the Cognito UCAs because I knew that GMT900 trucks needed them with the King shocks and these trucks use the same suspension.
Anyone using spacers like the RC kit, might benefit from an aftermarket UCA with the adjusted ball joint angle. I just don't sign up to the idea a dry Teflon socket with a steel ball, exposed to the dirt and elements, is going to last very long. I hear they also develop a squeak.
For anyone contemplating an aftermarket UCA, forget about the cheapest one on the market @ $250, the Rough Country UCA. It is designed poorly and interferes with the frame fittings. No amount of grinding on the frame as they recommend, allows for complete factory camber/caster adjustment range.
I have these, I called and asked for the parts specifically for a 2014+ with factory aluminum suspension and mine fit, there was a tiny bit of rubbing in the same place you are showing, but I grinded it down a tad and after the alignment to fix toe in it doesn't touch. I'm using them with rancho quick lifts to correct the ball joint angles.
I've also installed 1" longer sway bar linkage since then to get my sway bar back to stock angles. Probably didn't change anything in reality, but I wanted some nice poly bushings.
so much for wanting to get it cleaned up and take some pics .... go to the car wash and it scratches the **** out of my truck :mad:
owner of the place says "well thats not possible, my car wash doesnt scratch. Im not coming there tonight, we can discuss it tomorrow. I'll send one of my employees to take a look"
I opted to run thru the wash for a quick fix tonight, when all along the plan was to wash it myself tomorrow like I always do. So pissed right now
I went to my usual full service (tunnel) car wash today and they did a terrible job.
    nolankd
    nolankd
  • Who's Online   4 Members, 0 Anonymous, 471 Guests (See full list)
    • For a limited time, retail accounts receive a free fender cover (G2803) with their order of $750 or more when they use code FENDER926 at checkout. The promotion runs through Sept. 8, 2026. Own a business and want to apply for a retail account?  Apply here. https://www.amsoil.com/business-opportunities/sell-in-your-store/?zo=521390
    • Thanks for that, yes just because I could I measured what came out just to give me some guidance although I already knew to expect it to take at least 9.5 to just throwing in the whole 10 quarts off the shot and doing a one and done heat cycle to drop out the excess to get to the proper level. I don't recall exactly now what I measured that came out but was less than I put back in, I knew I spilled some on the garage floor but the main part was that I was thrilled in the discovery I did not have to touch my exhaust to flex it down. The gasket manipulating is a pain of course to create that clearance to take the pan out and put back in but its all very doable if one is careful and not forcing the gasket to flex too much. From the quote I got at a transmission shop of 900.00 here in Canada ( never asked at the dealer what they charge ) I saved 700.00 doing it myself after paying for the supplies so that to me paid very good wages !, and I knew what fluid was put in and that I had changed the filter and that the level is correct without any doubts.
    • I do have one of the AFM diasable box, using it for last 1.5 years.
    • I found a setup that lets me open the cover partway with racks installed, using side-rail-mounted systems for easy access.
    • Typically its said and I agree so far that the engine oil drain plug oring is not required to be changed out unless you see some damage happening to the oring as apparently the oring lasts well. The dealer I have been getting a few parts from never even stocked the oring but instead stocked the whole drain plug that comes with a new oring which for the dealer is easier because they just throw in a new drain plug if there was any question about damage on it as well and charge the customer accordingly but again only if it is needed.    Also a hint about the drain plug oring to help it last vs a risk of causing damage to it, after its been removed and wiped off or washed off ( that is a whole other topic about some solvents damaging orings because some solvent types do ) to make sure to relube the oring with a bit of new oil so that it won't "grip" on the sealing surface of the pan and needlessly stress out the oring. Its no different than putting some oil on the sealing ring of the engine oil filter. So I just grabbed a new drain plug to have on hand although more recently bought just the oring as well but as its special it costs half the price of the drain plug ... !   Since you mentioned the hate to be empty handed theme, I am not sure what you have in the way of filter removal tools as I like using the exact sized for the filter steel 1" wide band with side to side swivel handle filter removal tool, and it can be used to snug up the filter without risk of damaging a filter as well ( its probably a lisle brand I have ). The drain plug hex size is 15mm and I always like using a 6 point socket if I have a choice and with this truck I've been using just a 3/8 ratchet that has a fairly long handle. Do you have a funnel that will work to pour oil in as that is definitely the short coming bastard part about the design with that fill port on the valve cover on such an angle that no normal funnel will even work. There are adapters and things on the market that will set into or screw into that fill port, I didn't want to deal with US shipping as that is all I was seeing at the time so caved and bought a Lisle brand multi vehicle fit adapter funnel kit and it really works well but there are much less expensive adapters out there that work in conjunction with an off the shelf funnel that would do the job also. Now that I have it, I like how it works and works so slick with the shape of the Amsoil 1 quart containers I have now switched over to. Whatever you do, have a funnel system of some sort as you will be swearing if you dropped the oil and then realize you have nothing to properly pour new oil in without spilling it all over the engine !.     Other comments, quite a bit of oil flows out down the filter when its cracked loose due to the housing above the filter so let it dribble down the filter until it slacks off flow and then remove the filter to create less possible mess. It seems these engines can sit for quite a while and drip and if you have time let it sit there and drip out of the engine as much as it wants. Also a good time to grease the 9 zerks on the front end, that's my typical practice anyway to grease the suspension and steering each time I change the oil. And remember to reset the oil change minder ( not something I am used to doing with older vehicles and equipment ).
