Hey guys, question about wheel and tire fit. I've got a '14 Silverado double cab w/ max trailering pckg, 4x4. I have the RC 2" Level installed, and am wanting to order rims and tires. My main concern is wheel offset. From what I've read throughout the thread, I should be able to run 275/65/20 with minor rubbing, how big of a concern is wheel offset? I'm looking at a variety of different rims ranging from -0- to 35 offset.
Any input would be greatly appreciated.
Will post better quality pictures later next week once I get my wheel/tire dilemma solved.
Thanks again.
Anyone with the RC 2.5 kit doing alignments after the install? Im hopefully going to install mine soon, just wanted to know if i needed to schedule a apt to get a alignment done.
I was told that you have to do an alignment because you're changing the geometry of the truck.
Sent from my SAMSUNG-SM-N910A using Tapatalk
If you want your steering wheel to be straight and not wear out your tires in a couple hundred miles, yes you need an alignment, with any leveling kit.
I can't believe this question still gets asked.
Sent from my HTC One M9 using Tapatalk
The condescending attitude isn't needed, but thanks for the reply.
Haha. Well neither is your incompetence, makes us even then. [emoji106] [emoji106]
Just pulled the trigger on a 2.5 RC leveling kit. Hopefully will have in on in a couple of weeks.
There was probably a point when you didn't know that... give the guy a little slack.
I have the 2.5" Rough Country coming in the mail this week. Trying to decide on tires now. I was pretty set on 275/65/20 Toyo MTs for a while, but am starting to look at other options now. The Toyo RT and BFG KO2 are catching my eye. The KO2 comes in a 285/65/20. Not sure if it would fit. It says it is about 34.5" tall.
The Toyo M/T 275/65/20 is 34.5x11.0
The KO2 285/65/20 is 34.5x11.5 I believe.
Many have said that the 275/65/20 will fit with just the smallest of rubbing which is easily trimmed or pulled away to prevent it. The 285/65 would probably fit, just most likely cause more rubbing.
That being said I am in the same spot as you are. I looked and found that the 275/65/20 was perfect for me in the nitto trail grappler, but then I started to think of different options. Let me know what you decide, and also post pics.
I believe the 275/65/20 Toyo MTs are closer to 34.1". The weight of the Toyo MTs is also a drawback for me.
The Nitto Trail Grappler looks good, but I don't think they last as long as other tires.
I just got some BFG KO2's in a 275/70/18 and love them so far. They're a 33.2" tall tire i believe and I have the 2" RC level with no issues whatsoever.
I think I'm going to try the toyo rt's once I have the level installed.
Wanting a leveling kit for my 2015 and didn't know what I should go with 2" or 2.5". Also with a 2.5" do you have to go with blocks in the back and if so would it void your warranty?
Just installed a 2" Motofab level. Loving it so far, gets an alignment tomorrow morning.
    • That's interesting, I assume that would add to the cost of the oil but also I was forgetting to bring up the issue of the low tension rings allowing more oil past which in turn forces the cats to have more oil additives pass through them that wouldn't otherwise so they are creating that problem and of course its all in the name of fuel economy. Mind you the other issue would be the lack of additives that fight the formation of carbon within the piston ring grooves which turn the engine into an oil burner and with in this GM forums case is your average off the shelf Dexos licensed oil, meanwhile the other off the shelf oil being Valvoline's R&P isn't licensed and the only one that is which is that certain Mobil oil that came out recently ( its not even being marketed in Canada ) and only a fraction of vehicle owners are going to be using it out of all the other oils on the shelf or the quickie lube bay that meet the Dexos spec by way of actual licensing.    Also I suspect that its an easy excuse to pool the non turbo DI engines in with the turbo DI engines and design the oil to not have LSPI issues in the most demanding engines and short change the naturally aspirated DI by not offering a higher concentration of additive package they could handle and still not be at risk of LSPI.    I wonder if Amsoil flipped the switch just lately and did whatever packaging designation at the same time as I wonder what oil formulation I would have bought in May, of course I don't know when it was packaged at the factory vs how long it was in storage at the Edmonton warehouse. I know its been said at least in the past that the big players switch over to a reformulated oil but the packaging has not changed until they make that move as well so there is that cross over time where its a new formulation in a predated formula marked package.
    • Hmm. A real reason to not just use the odometer to determine OCI?
    • Sad thing is that this doesn't have to be the case. LSPI can be solved without a reduction in TBN. Swap Ca for Mg.  Cats are not a issue if the OEM can get a ring and valve guide seal even at SN levels of SAPS. Dizzy is purring like a kitten with a bowl of warm milk. 200K of Full SAPS oil and zero detonation issues and nice a clean inside and out. This shouldn't be an issue. It isn't 1920.    Tell ya what AMSOIL SS is excellent at, internal cleanliness. The new formula is even a step up from their already outstanding cleanliness levels. Can't say the OEM offering is quite that clean. There marketing suggest the SS is cleaner.     That is the only defense with at shelf oil. Nothing wrong with them if you ignore the marketing and OEM 'recommended' OCI and use a thimble full of common sense. 😉 You go sir.
    • I started with a folding cover by BAK PAC on my 2500. It went bad after close to 5 years. Bent and vinyl coming loose. Contacted BAK and they gave me a very good discount on a Revolver. Had it a number of years. Mostly outdoor storage. Some garage storage. Vinyl started to come loose. Still under warranty so they replaced to cover. Sold the 2500, bought the 1500 and got another revolver for it. Had it a couple years now and no issues. I store it indoors. Got a bit of discount when buying it as well. If you are seeing problems, contact BAK or real truck and let them know. Customer service was pretty good. But I think they changed their warranty.
