It's not that bad..... Just a tiny but of rubbing.
Sent from my Note 4 on Tapashit
Txjose, what tires and leveling kit are you running?
Generic 2" level i think its a pro comp
Tires are Mastercraft Courser MXTs
Just got my wheels on today.
Mayhem Warrior 18x9 18mm offset with LT275/70R18
  • Like 4
I'm wanting to put a 275 65r20 on the stock chevy 20s with a 2.5 in on the front which will bring my front to 39 in on a stock 275 55r20, is anyone running a 275 65r20 toyo open country mt with no rubbing or triming?
My 2016 All Terrain 6.2. 2.25" level with 285/55r20 toyo at2 on oem all Terrain wheels. I love it.attachicon.gifDSC_0039.JPGattachicon.gifDSC_0038.JPG
Sent from my E6853 using Tapatalk
Any rubbing? Just got the 295 and they are rubbing the sway bar
Nope not with 285. 295 are a bit wider that's likely why their rubbing.
Just purchased a 2015 silverado LS. Same as photo except I have mud gaurds.
I plan on running a 1.5" front motofab level. With this set up can I run 275/60/20 ko2s?
My buddy has a sierra with 2" front level and running 275/65/20 with no rub.
Just thought I'd check before I purchase?
I think you should be fine. My girls truck is leveled 2" with that tire and size and she has no rub but 1.5" im not sure.
Just leveled nicely with Pro Comp ZX2108 lift struts. They are designed for 2.75" lift. Thanks to some local guys at Socal suspension in El Cajon. In and out with alignment.
Next are 17" methods flat black on 285's
Edited by Csjumper2003
285 what? The next number is the most important one! lol
285/70/17 or 75/17
I think 75 will have issues
Also looked into 295s but I think there will be an issue until I get my 4.5 lift done
I see a lot running the 275/65/20 with a 2" level. So really 275/60/20 with a 1.5" should work just fine.
I guess I'll know soon enough.
Txjose thanks.
Txjose thanks.
I have a 1.5in level and really wanted a 33x11 tire. I couldn't find a for sure yes answer on here so I went with a 32.6x10.7 on stock 18s. The 33x11 will be close, if you stay on stock rims I think you will be okay though. Def interested in your outcome, pics please
I'm running 275/65R18 Terra Grappler G2s that the dealer put on my truck when I bought it without a level....no issues. Some are running the 275/70r18 and the 285/65R18 without a level, but that would be pushing it.
Edited by bcbz71
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
    • Is it an optical illusion in the pic or is the truck really squatting that much horribly?
    • My initial introduction was here.  It's hard to believe that I last posted in February 2013, having just deployed to Kyrgyzstan.  Since then, I've retired from the military and the 2006 Sierra SLT Z71 that first brought me to these pages was lost.  I went forward to Afghanistan in March 2013 and did a lot of sitting behind a computer on brigade staff.  Within 18 months of getting back to the States, I was selected for Drill Sergeant duty, after which I moved back to Virginia (my home state and where I served from 2004-2008).  That '06 Sierra did a lot of driving between Louisiana, Georgia, and Virginia, and ended up with nearly 320k miles by 2022.  By then, the registration had been expired for a couple of years, but the pandemic had all but eliminated tickets for such transgressions.  Admittedly too, I usually drove my wife's SUV or son's car the 2-3 times a week I had to report to work.  Teleworking sure was fun while it lasted.   I started my retirement leave four years ago and stored the Sierra at my sister's house.  A big mess was made when her fiancé passed while she was taking care of business out-of-state in late-2024, and his son pretty much mismanaged everything to do with the estate.  Even so, I was assured that my truck was safe... until it wasn't.  I found out that my truck had been scrapped about four months after the son took over everything.  There's nothing I could do; I'm 1000 miles away and it was technically abandoned property since he'd even trespassed my sister from her own house (she had no claim to it as she wasn't married, and the fiancé was the sole owner).     Anyway, today I got my second Sierra.  This is a 2010 SLE 2WB CCSB with a little over 200k miles on it.  It's got the 5.3L I'm familiar with and should handle what I need it for.  Hauling stuff that won't fit in the Transit Connect (yep, I sold out, but that's the wife's vehicle) and towing a few times a year tops.  The price seemed decent, considering how much people sell their trucks for in the Deep South: $4500.  I've seen similar trucks listed for more than double that.  I got it from a coworker who left his tag on until we transfer the title next week (Louisiana requires a notary for transfers), so I've been driving it all day.  The rear speakers don't work, which is one of the things that brought me back to these forums earlier.  I can't say how active I'll be as a poster, but I'll be scouring the archives while I find out every little thing I can about the 2010s and particular nuances/problems with my truck.   It's definitely not a GMC, but I got another Willys Jeep a few months back as well, so I'm almost at the same place I was when I first joined gm-trucks.com.  My old 1960 DJ3A was sold back around 2010 or 2011; my current Jeep is a 1946 CJ2A.  So, I've got a slightly newer GMC and a much older Jeep.  I kind of wish I still had that F-250 I had way back when too.  The Dakota is long gone and was technically my brother's truck, though I had it registered and insured.  The F-250 had to go when my grandmother's house was foreclosed on due to mismanagement around 2012 or so.     Hopefully anyone that made it this far isn't too annoyed.  I tend to be long-winded, but I'll be doing more reading than posting in the coming months.
