Lol none of that i have. But youre def right im sure itd save me a lot in the long run for things that are DIY doable/fixable. At the same time I always worry about things that arent 100% cosmetic that are done outside of a business in case something happens ya know.
Yep used to be there, I just started turning wrenches in high school on my Camaro nearly 10 years ago. My dad was a Machine Repairman so I had some backup when needed. Its a great feeling though doing that stuff yourself and growing skills. I highly recommend it, if you were local Id lend a hand. Might be able to find another local member.
If you cant, buying the level yourself and just showing up/calling around to local mom and pop shops may get you a better install price.
Edited by jrob56
post-157391-0-05024700-1462396980_thumb.jpgpost-157391-0-56235400-1462397003_thumb.jpgpost-157391-0-10680300-1462397014_thumb.jpg
2014 Lt 3.5in Rough Country, 305-55-20 Destinations, 20x9 Moto Metal 970,
This is my plan. Have been calling around and so far between local shops, chains, and custom shops theyre saying around 450-550.
I got a cpl more places to get ahold of though.
1 question i do have is .. whats the difference between RC and Pro Comp besides the $100 proce differencr. Is Pro Comp or any higher priced brand a better quality?
For that price I'd do the Bilstein 5100 shocks and level it that way.
Edited by cbrsilv15
Never seen pro comp but over 100 for a spacer and bolts seems nuts. I'd look at motofabs kit. 50 bucks for lower spacer and solid aluminum. Instructions were good as well.
I'm amazed they charge that much, you could probably drive to me for less haha. Should try to find a local member willing to help and buy him a case of beer.
Edited by jrob56
Just got a call back from the shop down the street from my work, asking 365 for labor/alignment. Much better than the $500 places.
I'm confused is this for a leveling kit?
Sent from my SAMSUNG-SM-G930A using Tapatalk
Nice. Did you do anything to the rear?
Nope not at all. Just the front plastic bottom mount spacer from rough country. Sits much better than it did before.
Sent from my SM-G920V using Tapatalk
Ok cool i dont think i wanna do anything to the back if i dont have to so thats why i asked. Thanks for the reply
I wonder why I paid so little on my installation? I seriously paid $150 for it.
Guess really just depends where you live. Montana, especially where I live is expensive. I have found a shop for $300 though so thats better. Id love to find somewhere for 150 even 250, but i think 300 is cheapest ill find and i dont have any friends that could do it
Debating whether to go with RC level kit or bilstein ride height adjustable. Is there a big difference in handle either way I go to justify the extra expense of the bilstein shocks?
    • Any joy with this truck seems to be short-lived.   The CEL for P0172 ("bank 1" too rich) is now "intermittent".   I'm not sure where to check, or re-check, and my energy to keep chasing problems with junk is wearing thin. The P0172 seems to set as I'm coming to a stop, completely off the throttle, when fully warm. At least, that's what it's done the 3? times it's set.   Everything appears normal on the scanner EXCEPT long term fuel trim. There's only one bank on this vehicle because it's an OBD 1.5 with only one upstream O2 sensor. At idle, it's around -16.4% and will dip to -18% occasionally at idle or off-throttle. LTFT approaches 0 when throttle is held at 2500rpm. Short term appears normal, much closer to zero all the time. The LTFT tells me the engine is running rich at idle but compensating at higher load. But, why?   The EVAP purge valve doesn't appear to be leaking/sucking fuel vapor continuously. Is it sticking just as I come to a stop and the engine is choking on fuel vapor and sets the P0172? But that doesn't explain the persistently negative LTFT. Disconnecting the purge valve doesn't seem to make any difference.   I suppose that leaves another dang issue with the fuel injector. A leaking fuel pressure regulator, a new leak in the spider, or a leaking fuel injector/poppet valve I didn't see, or a small crack in one of the spider legs.   The vacuum line leading to the fuel pressure regulator doesn't have raw fuel in it. It doesn't even smell like fuel when it's pulled off, not until you suck air through it, then you can tell it leads to a fuel component. I'd consider that normal? Nothing is signaling this is a FPR issue from the outside, at least.   The oil smells like fuel but it's not building volume. I've noticed most oil in most engines smells like fuel to some degree so it's hard to say if the smell is an issue or not. Or if the engine just still smells like fuel because the crankcase was full of it a few hundred miles ago. But it's been changed twice since that original issue of the leaking fuel line dumping fuel into the intake.   Patience is running very thin. Every win seems to be accompanied by two steps backwards, or another issue that leads to removing at least the top half of the intake manifold. Enough! LOL
    • First off you mentioned "Toyo Says" and then gave the pressures 45/50, was this some person at the tire shop that pulled those numbers out of his head ?   Now of course I can't know your exact axle weights front and rear, however I have much the same pickup as yourself other than not knowing your starting weight as per the pounds the truck rolled out of the factory at due to the options yours did or didn't come with or what you have added beyond the extra tire weight. The correct way to know 100% where a person is at is by weighing each axle with the typical weight the vehicle is driven with and that means taking into account passengers and making sure you figure in a full tank of fuel and a little grace for whatever you may put in the bed "groceries" !    I am looking at and not that it really matters as all the tire companies use the same charts anyway, but I am looking at the comprehensive Toyo tire chart in the section that your tire falls under and I know it sounds confusing but your tire is not an LT metric tire like your factory tire but instead because its a standard inch measured tire its under a different category called an LT floatation series tire. That makes a difference as LT metric tires they don't want to see run below 35 psi at highway speed where as with the LT floatation series it can be run down to 25 psi on the highway as long as the weight on the said size of tire is agreeable with or less than that minimum 25 psi. It blows many people away that how is this physically possible, an empty truck for one thing and larger tires with the same size wheel diameter have a lot more air volume so they can carry the same weight as the smaller tire with less air pressure.    So my truck, I have the stock 275/65R20 wheels and tires and I have a bit of weight in the box with a bak flip cover and a rubber bed mat and some tools and spare gas. The front of my gas truck weighs a bit more than some trucks of the similar spec due to double batteries and alternators. However with full fuel and just me in the truck I am weighted such that I can run 40 front and 35 rear and so that is what I have done since day one.    If I base your truck at or slightly below the weight of my truck, in theory with your tires going by the tire chart you might be right around a minimum of 30 pounds front and 25 pounds rear. Of course that would hit pretty much minimum cold inflation pressure one could run with that tire size and a near empty truck. If you have access to an accurate weigh scale to do individual front and rear axle weights I would suggest you do that and make sure your topped up with fuel and whatever else in the truck before you weigh it and then you will have a great starting point to work off of and figure out what your bare minimum pressures are you can safely run. If you do much in the way of hot weather high speed driving, bumping up a bit for a safety margin is never a bad idea but just depends on what type of driving you do. I will include the Toyo chart and the floatation series sizes start on page 31. Without a doubt at these pressures I am speculating at minimum wise for your truck, it would most certainly ride very different then it did when you were using 55 lb front and rear.     https://www.toyotires.com/media/pxcjubjs/application_of_load_inflation_tables_20200723.pdf
    • Take an automotive stethoscope to the vacuum pump. Iirc those tick as well.
    • This landing is worse than most. Patchy blacktop with washouts, soft gravel/sand at bottom that washes out with every heavy rain. I tell everyone to put it in 4WD. A lot of them think they can pull out their trailer in 2WD. They end up digging a hole and then putting it in 4WD.  The lake is a pristine lake and has a lot of money on it. There are several wake boats and lot of large tritoons. The people with the money don't want it improved because they don't want more traffic.    Boat Landing 1.jfif Boat Landing 2.jfif Boat Landing 3.jfif
    • How wide are your rims?   Toyo specs 8.5-10.0-11.0 inches. My thought would be rim might be pulling the tire inwards creating a center that is more pronounced.    I also noticed that the spec sheet says max 65psi. So you could be right lowering the pressure to ~40 psi.
