rough country add a leaf which added a inch and a half the I put 3 inch supreme suspension leveling kit
2016 Silverado
2 1/4" Front Level Only
OEM GMC All Terrain Rims, Plasti dipped black with Glossifier
Midnight Edition Center Caps
275/60/20 BF KO2's
Zero Rub, Perfect Fit
2016 Silverado
275/60/20 BF KO2's
That looks really good.
Which kit did you go with? And how does it ride now compared with before? Do you still have the stock shocks?
I'm not sure what kit, the dealer put it in because they cover it under warranty even though I am extremely hands on person, I had that worked into the deal when I bought the truck. Its the stock rancho shocks. Been running the tires at 39psi cold. I personally think it rides better then the stock Goodyear's, handling has improved along with comfort. You can hear a little noise almost barely noticeable
2016 Silverado
275/60/20 BF KO2's
Exactly what I'm looking for. Thanks boss!!
Sent from my iPhone
Ok done tons of research. Want to go full lift later down the road. Still on stock sle 20s on my 2015 gmc 1500 and factory Goodyears at 30k are showing some good wear. Have the rc2.5" w/2" rear block. Looking at nitto trails on these wheels size 35x11.50r20 see a few guys doing 35x12.50r20 with levels also looking at 295/60r20 cooper stt pro and toyo at2 also 295/65r20 in the toyo at2
Any experience with these sizes. Have the front valence removed just don't want to rub metal. I do use truck Offroad lots.
I have been running 35x12.50x20 on stock rims with an RC 2.5" level front only for about 12,000 miles now. I did some minor plastic trimming but still rub at full lock. I have had it in mud, on medium trails, and on the beach for two years. I have Firestone Destination MT's and they run pretty true to size. They look great and are definitely worth it if you go offroad even semi regularly. You gotta love to scrub though.
Edited by Jfcampbell485
attachicon.gif20150713_170935 - Copy.jpgattachicon.gif20150630_200600 (2).jpg
I'm guessing your rubbing the sway bar pretty bad then?
    juggernautusa
    juggernautusa
  • Who's Online   4 Members, 0 Anonymous, 643 Guests (See full list)
