Zone level kit ko2 in 305/65-18
That's awesome. Would love some more pictures of this truck and some of the wheelwell clearances at full lock. I haven't seen anyone else try a 305/65r18 on stockers but always thought a BFG would work because they aren't as wide as the rest of the mfg.
Can you put a tape measure to the tire and give the true overall height and width for us?
Rough Country 2.5 Level
Toyo RT 33x12.5x20
I like my set up, but am already wanting to go with a 4.5 Suspension lift with bigger tires. Wouldnt look right if i used these tires lol
Edited by lemmuhj
Thank you. I sure can I will get them pics for ya tomorrow.
looking to do a 1.5" Readylift and trying to finalize a tire and size for my factory 20x9 wheels. I want the biggest i can fit with minimal to no rubbing. after the posts i have ready i seem to be able to for sure do a few different sizes in 275, 285, and even some shorter 305 widths. anybody running something similar with pics?
I have a 2.25 Ready Lift that was installed by the dealer, has anyone experienced a slight shake or rumble around 60-65? I brought it into the dealer and the answer they gave me was that the blocks make the steering lighter and it causes wandering leading to the rumble. Their solution was to rotate the tires. Anybody have input on this?
Makes no sense that rotating tires would fix that unless your tires were never rotated in over 10K miles and cupped, or way too much or too little PSI. I'm betting you probably have stamped steel control arms based off your username 16 silv, and any level kit over 2 inches creates problems with those arms.
Rough country made a kit specifically for these arms now with their 2.5 kit, it uses a preload spacer now for them instead of the bottom and top spacers used in all the other kits over 2 inches. I would install that kit or remove the 1/4 inch spacer from yours, AND make sure your tires are balanced correctly and alignment is correct. If all of the above have been checked, it's most definitely the kit being too much for those stamped arms.
Edited by MOhunter92
Where dem pics??? Need to see more of these 305s!!!
Here is my 2015 Silverado with RC 2.5 lift with rear block. Tires are Pathfinder A/T 275/60/20 (33x10.8). Wheels are 20x9 +12 offset.
Bilsteins at top setting with 275/65/20s on stock rims. BFG KO2s No rubbing...post-163370-0-43838100-1475333600.jpg
Edited by Lvplr
Question for all you 2.5 RC enthusiasts. What are your thoughts on doing the the front 2.5 setup and putting the universal 5 inch blocks in the rear instead on the supplied 2 inch blocks?
Currently I have a 3" rake going on and figure it would only take .5" out of my rake but give me 4" in the back and 2.5" in the front.
Also curious going up to a 5" block with that kit and the u bolts wont work so what length u bolts I would have to go with?
Thoughts?
Thoughts?
If you still want a rake use the bigger block. I used the 2" block that came with the kit, my measurements after install (including tires) are 39.5 at front fender and 40 in rear.
    • I have seen different people in different places post different sizes of exhaust as stock for my 2014 Sierra L83. Some say 2.5 some say 2.75. I am considering replacing the muffler with a Dynomax Super Turbo, perhaps 17739.  I had the factory L83 5.3 replaced with another L83 5.3 from Jasper Engines. I also put new Walker Cat / Y pipe on. I would appreciate opinions suggestions about what would be a good muffler setup. My main interest is a low rumble and the best flow / fuel mileage I can get. Not interested in straight through glass packs or loud exhaust. Those days are way behind me now.  Thanks Guys.
    • Its coolant disguised as oil.   TSB 20-NA-166 -  20-NA-166 1..3   "To inspect for this concern, add coolant dye to the system, run the engine through warm up, pressurize the cooling system after warming the engine to operating temperature (let the engine cool overnight) and inspect the suspect cylinder with a borescope for coolant dye evidence. At times it may be necessary to remove the head for inspection. If the head casting line is the concern, the intake port will be wet with a coolant oil mix"     I'd say its the head, and its either leaking at the casting line and dripping down the intake into the cylinder, or its another spot on the casting itself at the cylinder that is getting wet.
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
    • Good information!  I didn't know about the dementia aspect and asked for a general for my second knee. I'd heard that recovery room time is usually shorter with a general.   The anesthesiologist talked me out of it and I had the spinal.  Inconvenience and/or discomfort is a small price to pay for reduced risk!
    • This is for those over 70 years of age contemplating joint replacement surgery involving general anesthesia. Even some 55 yrs. ago when I took my pharmacology class the dangers of developing dementia in the elderly that had general anesthesia were beginning to be recognized. Over the years there has been some refinement in the cautionary warnings, avoid general anesthesia if possible if you've had close to 10 priors, especially over the age of 70 and/or a family history of dementia. I'm not including the twilight anesthesia induced by propofol often used in cytoscopies or colonscopies. Seriously think about seeing a neurologist and undergo cognitive testing before proceeding if any of those criteria apply to you. Spinal anesthesia may be an option in some cases. I'm in the above camp and although I could use a new right knee, I get fidgety according to a prior orthopedic surgeon when the bone saw spools up or maybe it was the smell of saw blade meeting bone, anyhow I may have one general anesthesia left in me which I will pocket for now and I'm choosing mind over mobility, anyway where did I leave my damn cane!
