I went from stock rims to a -12 offset little rub full lock. 305-65-18
What type of lift/level do you have?
305/55/R20 2 inch Rancho quick lift
What tires are these and any more pics? Looks great! Also any rubbing?
Edited by JPX
There the Pathfinder tires I bought them at discount tire they were highly recommended and very cheap and they rub a little at full turn going up or down a driveway
SuperAllTerrain
Has anyone installed a MotoFab 2.5" leveling kit? I bought one for my 2015 all terrain and want to install it but is it a job better left for the pros?
2.5" Rough country suspension leveling/lit kit includes 1" lift in the back.
Stock tires?
Stock tires?
Unfortunately they are, changing up to bigger tires will be next.
Really doesn't look bad to me, size wise that is. Do you know what tire and size you are going with?
Edited by MOhunter92
Not sure yet, I'd like to put some 33" but worried about rubbing. Going to ask the shop to see if we can figure out the largest we can go without any issues.
Depending on the offset of the wheel and the width of the tire. 34" is about it.
275/65-20 doesn't rub on my 20x9 +15 wheels (2" level)
So as long as you don't go much higher than 2" with a level, you won't have issues with your ball joints or any of that stuff wearing out prematurely?
