Thanks! I used a 2.5" Motofab kit (2" bottom of shock and 1/2" on top) and 3" rear motofab blocks! Originally had a 2" on it only and looked small. Really like the look now. Here's a front stance pic b9d6d86918feffe7081760f6980c507d.jpg
thanks!!
thanks!!
Is this the one you purchased?
No I used these, b/c I had s 2" in the front and wanted to go to 2 1/2" so I just added the top plate and rear blocks.
Hey bro I pmd you check your mssgs thanks Edited by ElectricRocker
Thank you soooooo much. I'm going to purchase them now. I appreciate your help. Your truck looks amazing. Here's mine with a 2" leveling kit.
2016 Silverado LTZ Z71.
OEM GM 20x9 +24 offset wheels. Clear coated PVD Black Chrome.
Nitto Terra Grappler G2 285/55-20.
Bilstein 5100 Ride Height Adjustable shocks on highest setting. No rubbing. No trimming.
Nice looking truck there sir! What color is that?
BNish97.what are your wheel specs man.that is the stance i am looking for.
Cleaned it up before the rain...
That looks awesome! I wish I could take my steps off... not family approved/friendly.
Sent from my Nexus 6 using Tapatalk
Thanks! I debate about getting steps but really like the look without. My seats will show the wear in sure. It seems I could've gotten away with 305/55 with this kit
Not on stock wheels, it would would have rubbed your sway bar and control arms bad
Get the Amp retractable bars...they are awesome!
also what brand/size are those tires? imitation is the most sincere form of flattery :cheers:
285/60-20 Goodyear duratracs
beautiful truck!!! love it without the steps!
Bare with me...I'm new here. I wanted to post a few pics since this forum has helped me figure out what I wanted to go with. Hopefully, this will help someone else out. I was looking to level my front end without giving up any ride quality, as well as get a little bit bigger tire without losing any gas mileage. I wanted to/and will eventually go with a 295/55, but going from about 42 lbs per tire to about 61 lbs per tire seemed like a big jump. I was going to get a programmer, but I read that with these newer trucks, the dealership can tell if you had programmed it, even if you programmed back to stock, and it could void the warranty. So, I decided I'll wait until my warranty is up before I go with a heavier tire and a programmer. I went with the Bilstein 5100 Adjustable Ride Height Shocks at highest setting (about 1.86) and 275/60 Nitto Terra Grappler G2 on stock 20x9 GMC Wheels. The tires are not an LT, but are an XL, which means they are a 4-ply tire with an extra load rating. They ride about the same as the tires that came on the truck and are the same weight. I do a lot of highway driving with very little off road driving or towing, so I was ok with not going to an LT tire. As far as the 5100's go, couldn't be happier. I read that the ride would be stiffer, but better. Didn't understand what that would feel like until I drove it. Much better...no more bounce. Even my wife thinks it rides better. No rub at all.
    B07
    B07
  • Who's Online   6 Members, 0 Anonymous, 974 Guests (See full list)
