I was specifically referring to the installation instructions. Motofab is a top down bolt installation and requires you to drop your ball joints to clear the CV axle during install. it sounds like RC is bottom up. Also RC is cast steel and Motofab is machined aluminum.
I can only speak to the accuracy of the Motofab info I'm posting as I don't have the RC.
Sent from my Nexus 6 using Tapatalk
I have the rough country 2" with stamped steel. It is also top down and requires you to drop the ball joints to install. My truck is 4wd also. Might be part of the issue.
Sent from my SAMSUNG-SM-G935A using Tapatalk
The RC lower 2" spacer is composite, not steel and the only reason one bolt needs to go from the bottom up is because the half shaft is in the way to prevent the longer bolt from being inserted from the top. I dropped the upper ball joint on one side while installing but couldn't get the other side to release. On the side I dropped, I still couldn't get the bolt in through the top. It doesn't make any difference anyway as long as they're torqued properly to 37 ft lbs. One guy pulled his axle to get the bolts in from the top but it's fine putting them in the other way. Edited by '17 Sierra
Sorry to keep asking questions. I don't see any pics of the trimmed carpet on this forum from yesterday, or the past few days. I even searched your name. Sorry if I sound like a stalker. Are they posted somewhere else?
I agree, I'm shocked too to hear it rubs, even if just a little. Not what I've been reading about 275 60 20's. With the trimming, would you do the same size tire again, or go down to stock 20's in a Duratrac?
Thanks again,
Klappy
No worries man, happy to help... this forum is how I got what I wanted!
I would definitely do it again. Biggest downer was the mpg hit... Lost 3 mpg even with the corrected speedo. I have a Diablo intune.
Tapatalk keeps freezing every time I try to post the pic now... Let me see if I can link it.
EDIT: Page 354
http://www.gm-trucks.com/forums/index.php?/topic/161228-Post-your-2014+-wheel/tire-set-up&do=findComment&comment=1945763
Edited by Sierra Jon
You don't have to pull the entire axle, just zap out the 15mm bolts holding the axles to the diff , push them aside and drop the bolts in. No need to mess with ball joints.
So I have a '17 1500 denali ultimate im planning on installing the suspension maxx 2.5 for the Magnetic ride but I was wondering what should I do with the rear and also what is the biggest tire I can use with the stock 22 wheels
Edited by dave8699
I have the same vehicle. My advice is to go with the 2" level and leave the back alone. That's what I did and it looks perfect. If you go with 2.5" you will probably need to go from a 1" to 2" block in the rear, and then you will have more rake than the 2" level alone. Also with the magneride, my dealer told me it's best to stay under 2" - he said the angles start to change a bit too much once you start going bigger.
In terms of tires, I stuck with the factory ones. They are not bad at all - quiet, nice looking, and wearing well. You could potentially go to 295s with the 2" level and some have managed to put 305's, but the limitation will be the upper control arms and sway bars, not the height of the wheel well.
Hope this helps...
Hope this helps...
Thanks for the advice what kit did you go with and did you have to recalibrate the mag suspension,do you have any pics
I went with the Rough Country 2" kit designed for Magneride. It comes with little brackets that you use to reposition the sensors, so that it calibrates correctly. Pics are on my profile gallery. The dealer installed it for me.
So im trying to decide between the rough country 1311 or the suspension maxx SMX-GM725M which kit will be the best
Edited by dave8699
^ Looks nice :)
The OP (dave8699) has 22's as he has the Denali Ultimate package. In that case, I'm guessing he can go with a 33" tire but mot much bigger.
Edited by Matt_UKTX
^ Looks nice :)
We'll stock tire is 285/45/22 that's like a 32.1/11.2/22 so the biggest tire is probably about 1inch taller and 1in wider correct me if I'm wrong but it doesn't seem like it's worth changing tire for that little bit of extra tire
Yes, conservatively, I would agree with that. You might be able to squeeze more, but it just depends. There seems to be some minor variation between individual trucks too. I was originally going to go with bigger tires, and when I saw the stock setup with the level, I thought it looks great as-is. Plus, unlike on the 20's and 18's, the factory tires on the 22's are larger (285 vs 275) and really nice. They are also an AT tire, not a regular tire, so unless you plan to go mudding (unlikely with 22's and a Denali) I don't think a change of tires is needed.
BTW, you should look up the piping mod and do it to your truck. Some blue piping would look sick that that blue exterior. I did the grey piping on mine and it looks amazing.
    • Hey everyone,   For anyone looking at roof-mounted lighting for the Hummer EV, we wanted to share our M&R Automotive 50" PRO Roof Light Bar for the 2022+ GMC Hummer EV.   The curved 50" bar sits close to the windshield rather than sticking way up above the roofline. The mounting position is designed to keep the setup relatively streamlined while minimizing wind noise and maintaining full use of the factory windshield wipers.   A few details:   50" curved PRO light bar Fits 2022–2026 GMC Hummer EV Spot + driving beam pattern TIR optics White main beam Amber DRL backglow Approximately 15,410 measured lumens through the lens Mounts to factory accessory locations No cutting or drilling required Wiring runs down the A-pillar toward the AUX connections Designed to minimize wind noise Lifetime warranty Off-road use only     The 50" is an interesting middle ground for anyone who wants the visibility and mounting position of a roof bar without stepping all the way up to the larger 60" setup. For the Hummer EV owners here, would you go with the 50" for the lower-profile look or step up to the full 60"?
    • My son got a hatchback withe the aero package for like 17k new. Great little car with amazing MPH
    • Yeah, I've given up years ago with that! I was able to load a few when I first joined the site sometime around '07. Then after maybe 20 pics, it said I exceeded the limit. Now every pic I try to post says I've "exceeded 1mb".   ONE MB??? That's Windows 95 ******, lol!!
    • I get the same results with pictures. Then I figure it out. Then I forget. Screw it.
    • I guess I'm the only one on this forum who can't get effing pics to load here! Do you have to resize them to post, or am I just blocked from uploads?   I have the same luck with automotive electronics ... but this is the ONLY site on the net that I have this problem!   I'd post pics of what I'm working on ... but I CAN'T! 🤬       Just fabbed up the kickdown cable (had to extend the cable mount WAAAY out from the throttle shaft to get a full pull), and parts arrived for the fuel lines on the 940 carb conversion project. Should be able to drive this thing by the end of the day. If not for work, I'd have had this thing done SIX weeks ago.   Got the jetting sorted out last week. Had a real bad tip-in bog that I couldn't seem to correct. Friggin float height was over 11mm too HIGH! eBay purchase, so no wonder everything is screwed up right out of the box! I ended up with a larger dual-squirt accelerator pump jet anyway instead of the single. Also moved the 70 primary idle jet (4 sizes too big out of the box) to the secondary idle circuit, and installed a 57 in the primary. Runs great on the fuel bottle!    Still using the computer for ignition. Going to drive it first and see if I want to go through the project of installing an intermediate shaft with a distributor drive gear, so I can install a block-mounted distributor and run points, 100% computer free. I should do that anyway just from a simplicity / reliability / tunability standpoint. The electronics left me stranded last year a couple times! I can't tweak the timing to my liking right now because of the computer. Tried twisting the cam-driven distributor already ... and the damned thing just reverts back to where it was! That's infuriating. But if it runs well enough I might save that for next season.   Just driving it in and out of the shop to work on other projects, it feels 1,000% more responsive with the carburetor. Also fires MUCH faster when cranking. Can't wait to drive it and see if I got more than 114 ponies, lolol.   Hopefully these don't go 404 like the last post ... https://postimg.cc/gallery/MjhrmZS   Seems like that site went back to dial-up internet! Maybe they'll fix that some day ...
