How does the ride get impacted with the body lift?
Rides no different. Actually it seems to ride better. This is either in my head, or the body lift blocks take out some of the vibration felt in the seat of my pants. Either way, for a truck that sits up higher than stock, it rides like factory.
Cool. How much does a body lift cost and what actually do they do? Does the whole cab & bed just move up 1.5"?
Roughly $180. Yes, the cab and bed move up 1.5". The bumpers are also relocated to match. The Zone kit is very well thought out and includes everything needed. The instructions are good and there are YouTube videos as well.
Nice... Do the trailer hitch and exhaust get adjusted too? Also did you notice any additional impact to fuel economy or noise?
The hitch stays put. It isn't noticeable due to the design (I'll try to snap you a pic). I have a muffler shop that can adjust the pipe. No added noise or noticeable effect on mpg.
Edited by Salty315
Did you install yourself? What's a rough estimate for install time?
2" RC level with Zone 1.5" Body Lift. RC steps added for the wife. Having exhaust pipe raised next week.
Nice looking level and body lift. I want to do the 2" RC level. What are the advantages with the body lift? And what do you mean you are having you exhaust pipe raised?
Yes, installed it myself. It took me two days. Mainly because I had no help. I also had 70 degree weather and a case of IPA.
The body lift is to get a little extra height without affecting suspension angles or ride quality. The exhaust pipe now exits 1.5" lower (notice the gap between it and the body). It bugs me, so I'll have my muffler shop change the angle so that it sits close to the body again.
Progression of my 2016 Z71. Hopefully this helps some members decide on how far to go.
Stock
2" RC Level with stock wheels/tires
2" RC Level with Gear Alloy 20x9 and Toyo ATII 295/55/20 (Very smoky that day due to wildfires in our area).
Cleaned up
How bad did it rub with just the 2" level?
It didn't rub with 2" level.
That's is a good looking truck man! I love white, but my brother in law bought a white one so I had to be different haha.
Stock
Cleaned up
Wow even just the level kit really improves the look of the truck! Man, I'm pumped to get some rims, but shoot as cheap as the level is I'll probably do that and finish buying the other things I wanted to do to the truck before I buy them. Edited by 17silverado2248
I have to KO2's and really like them. Once you get them on your truck they look more aggressive than you would think, and for highway driving they are really quiet.
Is your set up 275/65/20's on a 2.5" level? I have stock 20 with +27mm offset. Looking to do this set up. Any issues with running? Any trimming? How's the ride quality. Thanks!
Pics of the hitch after Zone 1.5" body lift
    • First time it really happened to me was when I was 69 yrs old and I was called "Old Timer" by a complete stranger. Then in rapid succession came the aforementioned "Old Man" and my favorite of all "Pops".
    • Yea that's pretty normal to be off a few degrees.  Usually 2-4 degrees from say a weather app or thermometer.
    • I just replaced the ambient air temperature sensor.  Easy as pie. I simply had to remove about 10-12 clips on the plastic cover over the radiator and remove two T-10 torx screws on the hood release lever to liberate the cover (Amazingly, none of the clips broke.  All came out and went back in with zero problems). Once the cover was removed, the temp sensor is easily accessible. The sensor cable snakes through a few guides and can be pulled out for even easier access to the sensor. I was able to work the sensor out of the mounting hole.  There is a red sliding catch on the plug that must be pulled back to disconnect the cable.  The plug was quite tight.  I had to use a screwdriver to pry it out. I plugged in the new sensor ($6.45 from RockAuto), snapped it into the mounting hole and re-snaked the cable. I put the radiator cover back on and reattached the lever arm to the hood release.  All done!     I started up my Suburban.  The temperature read 82 °F. Other thermometers at my house read 80 °F.  Close enough.  It might be reading high as my vehicle was sitting in the sun.
    • Remember when you were 50 and they called you Old Man?
    • That one looks decent for the price   BUT..I want something that also supports OBDI/1.5. A lot of the prosumer-grade scanners don't have legacy support in order to keep costs low. I believe the Autel does if you go higher end with them.   For fun, I reached out to a local Snap-On rep because I was interested in the 2600. $1895 MSRP, says he can do $1595. That's still a lot, but then again, that's not a horrible discount for just asking out of the blue. Could probably do better if I was a regular buying off his truck, but I'm not.   Not sure if I mentioned but I didn't realize with USED scanners from Snap On that you need to make sure a) the serial number isn't flagged as stolen. On the newer ones, SnapOn can remotely disable the device if it's flagged in their system. And, customer service can tell you if it is, if you're thinking about buying used. B) Make sure it's paid off. If the seller still owes money to the truck or if they financed through Snap On, the device can be remotely disabled until the balance is paid. It's less clear if SnapOn will tell you if a balance is still owed; I didn't make it that far with the used model I was considering. I did read that SnapOn has no way of tracking any "truck financing" deals between the SnapOn rep and buyer, only if they financed through corporate. So there's that extra caution needed.   Still waffling on whether I go with a ~$500ish Autel/TopDon or spend bigger money. The value seems to be in the prosumer brands. I'm not giving them enough credit TBH, actual production repair shops use them daily BUT I'm still allergic to certain kinds of underdog products trying to unseat American companies with solid reputations. SnapOn's scanner isn't wholly made in the US, but it is assembled here and they have US support and probably the most proven/ robust legacy support.   Something to think about. Value, or principles? There's a $1k difference.
