Did you use your stock U bolts or get new ones?
Edited by Coles5515
Good evening Gentleman. Long time lurker, first time poster. I bought my 2016 LT CC in June of 2016. I'm currently stuck between a 2.25" procomp leveling kit or the 4" procomp lift. I'm looking at running at 20x10 -24 offset wheel on 33s. Not sure of a tire yet. Does anyone know if this will rub? I'm okay with trimming the front valance some but really not comfortable with the idea of metal trimming. If I need to go down to a 20x9 0 offset without having too many issues so be it. I'm willing to compromise...to an extent lol. Thanks ahead of time!
go with a -12 offset and it will rub very little no trim will be needed
SuperAllTerrain
Yeah true. Not a fan of all that either. I've decided on the motofab 2.5" front kit but I'm going back and forth between the 1" and 2" blocks to go in the rear. Do you have any pics of your setup?
2.5 is a great safe bet for sure, and will Look awesome. Not sure if all factory blocks are 1.25, but mine were. 2.25 left me with about 1 inch of rake.
These are some pics I could dig up real quick. Hope this helps!
Edited by Travis1024
Whats your tire size? Any rubbing? Nice ride for sure
Thanks man! I'm running 33x12.50r20. I have a slight rub on the UCA at around 85%+ lock due to the width of the tires.
Planned on an 11.5 or so inch wide tire, but got an absolute steal on these
Woychc- am I missing it on their website? I just see the blocks or do they come with u bolts?
My buddy ordered it for me when he was ordering his kit. I think he called in cause it wasn't on their website.
Removed the RC 2 in level and installed Bilstein 5100 all around with the front set at the highest setting.14b2b255671860c5f92c49611a4da9a3.jpg
Sent from my LG-H820 using Tapatalk
I'm...yeah. That settles it. I have an identical truck, and that's just the look I'm after. Sweet ride.
Good Looking truck for sure man! How'd you black out your ambers in the front?
Also, do you happen to have fender height measurements? Yours looks about the same height as mine, but i've got 2.5 front and 1 rear
EDIT - sorry, quoted the wrong post and dont know how to delete hahah
Also, do you happen to have fender height measurements? Yours looks about the same height as mine, but i've got 2.5 front and 1 rear with a full 33
Do you know how the front to back now measures? How's the ride? I would like to go this route.
Front is at 39 and rear at 39.5. Ride is a better than the stock Rancho
So through all the pages of this thread I know some guys are running the 2.5" front with a 3" block. What is your rake like? Pictures would be great!
Here's another one with 2.5" front and 3" rear with 305/55R20's. I got my 3" from RC and the ubolts had to be purchased separately.
Part #'s:
9/16-inch Square U-bolts (2.5 x 10.5)
7652
$29.95
3-inch Rear Lift Blocks
6594
$33.95
IMG 0336
I have a difference of almost 1" at the rear fenders.
Driver side fenders are 37 1/4" front and 38 3/4" in the rear; 1.5" difference.
Passenger side fenders are 37 3/8" front and 37 7/8" in the rear; 0.5"
This is after I just put Bilstein 5100s at the highest setting on the front and no change to the back.
I know the rake in these trucks aren't always consistent but has anyone seen the difference of almost 1" in the rear? Do you think my rear passenger shock is shot causing the 1" sag? Seems weird to me at only 20,000 miles but they are the stock shocks on an LT.
    • Declaring victory would upset the demons that possess this Blazer, so I won't. But I did make progress today--after it put up a fight. Always a fight.   I had the day off so I spent the morning cleaning up the shop and I thought I'd get ahead of things by filling the cooling system in prep for the final part I needed to arrive: the driver's side knock sensor. Glug, glug, glug....and then the unmistakable sound of liquid hitting the shop floor. It induces the same chagrin when the sonar and targeting laser temporarily malfunction during a late night bladder evacuation over the toilet with the bathroom light off. D'OH!!! That made a mess...   Oh, hey, that knock sensor I removed? It threads into a wet port. Who knew?! Learn something new every day. Put a pin in that chore, I'll fill it the rest of the way later.   The knock sensor arrived at about 1pm. I threaded it in, connected the wire, filled up the coolant, checked for leaks, and... drumroll.... fingers crossed for a perfect start, excellent timing, model fuel trims, and ...no squeaks... Here goes.....   No, it didn't start. At all. I cranked it a few times and it wasn't sounding good. Furthermore, I heard leaking again. Jesus H Tapdancing Christ, stop leaking all over the dang floor. This time I had accidentally overfilled the coolant reservoir and the churn of the water pump via cranking caused a bit to burp out. Ok, just, breathe... Put the flamethrower down. Dang thing wouldn't burn anyway, leaks too much...   Did you know the rotation of a round crank sensor in a round hole, matters? I do now. Took me about half hour to retrace steps and realize what I had done. Then it started right up.   No squeaks. The squeak was the old balancer.   Once it entered closed loop, fuel trims are dead on, hovering right around zero at idle. No more -30%. I'll credit the injector rebuild on that one.   Timing? I think there's an OBD 1.5 translation error with my Actron scanner. It's anywhere from -20 to -30 at idle, sometimes as high as -40 cruising. Sorry, the engine just isn't running that smoothly at -40 degrees ignition advance. It's just not. It's smooth all through the rev range and has decent power. I'm going to have to trust the seat of my pants on this one.   The new exhaust is very quiet. The old catalytic converter? Not melted, but definitely not healthy. Rains glitter when you turn it on its end...all the precious metal is flaking out. Once the new exhaust system burned in/smoked off a bit, the engine's exhaust smell is normal again. Not that I'd recommend going around huffing car exhaust, but, you know what I mean?   One problem to correct. The new exhaust has the opposite problem of the old spliced up exhaust. It wants to hit the floor where the old one wanted to rest on the cross member. Happy medium, please? Still noodling on that one, need to look at how I can adjust some hangers.   I don't know what's next. On one hand I want to run away from this thing as far and as fast as I can -- there have been a lot of NOT fun moments. On the other, now that it kinda drives nice, maybe drive it around for a little bit?   Shhh... it's not currently dripping oil all over the floor. I can see just a little wet at the bottom of the timing cover where it meets the oil pan seal. It's not dripping multiple drops with every ignition cycle, in fact, after some driving this evening it has yet to even form a drop that could drip off yet. But the weekend is young... I fully expect this could turn into Exxon Valdez by Sunday. Because this Blazer hates me. LOL.
    • About that:   Once upon a time in a land far far away lived a car company that was shy about taking your money and wanted to be sure that they gave you more that you asked for so that you'd come back. No really, not a fairytale. 😱   But after the field got thinned out enough to limit the competition it seemed good enough to give you only what you asked for. Fair enough I say but in such a market you have to give something the others are not or they go to the one who does. Gimmicks or glitz. Oh, fins and chrome. Yea, shinny crow like cars. Yum.    Field narrows a bit more and 'brand loyalty' becomes a thing and the minute it does they start thinking to themselves, "Could we make more money if we gave them less than they expect and they will hang in there for brand and comfort with the known?" They gave it a try and da*n, it worked!!    Well, what if we teach them, groom them into believing that less is "Normal" and cut some more corners. Will that work? Oh heck yea!    🤔 I wonder, can we give then WAY less than they expect and make them mad enough to spit nails and STILL get them to pay up? Sure, if we get everyone else to do the same so that the choice is less or nothing at all. How would be do that? Platform sharing.  What a concept, right?  Steal like there is no tomorrow and it's legal too!    Truth is no one is going to give up driving, not for very long. The Gen Z crowd is fine with it and will be as long as someone not Gen Z will haul them around. At some point we all die.    Economic voting only works if you cast a NO vote now and again and enough of them to get dumb and dumber to wise up. Well, that's how I was taught anyway. And it should have worked. Would have worked. But the Bail out!!   Look, you have another choice if  you take that bag off your head. If the dumb it down to some predetermined expectation of how John Q Public will use it the, that is under design it to failure they you use it to a lower stress mode. D'ho!    A 1950 Royal Enfield Bullet 500 will go anywhere a Suzuki Hayabusa will and for just as long. But you will have to treat it for what it is and not for what you wish it was.
    • Maybe I was just too unlucky, but I had nothing but bad luck with Bridgestones. Out of 3 sets, they all started losing a lot of air when they got down to about 1/2 tread life, and at that point also wet traction suffered more than it should have. Also, the only tire I ever had in my 60 years of driving that had a side wall blow out was a Bridgestone.   I'm currently running Goodyear Wrangler Workhorse AT and am very happy with them.
    • maybe when the trip is over, check all the other joints in the front end, like all the ball joints, tie rods, pitman & idler arms, etc...
    • Thks, and actually it was my bad, because here in this post there is someone showing the correct wire position as well. My bad... But thank you a lot with the help as well. I was able to find and buy a 10 channel VPM that came from a sister silverado of mine. The same year, same mode, same trim, same everything. 2022 Silverado 1500 LTD LTZ (pre-refresh). I also found to buy just the bottom mirror part that has the cameras, so way cheap than the full mirror. + a used front camera. I did test everything together, cameras, cables and the VPM.... everything worked EXCEPT my original Bed camera and the backup grid lines. I think the reason is because now I need to do the VPM reprogram. I sent a msg White Automotive & Media Service to confirm that it is the problem and that they can do it service for me case.   Once I get it 100% done I will post here result....
