I ended up giving up and busting one of mine up really good with a pickle fork (was putting on new UCAs anyway).
I've always broke themapart with a hammer on other trucks, but couldn't get this one to budge. I let it hang for an hour after hammering. Sprayed it with penetrating fluid. Cranked the wheel back and forth. Beat on it from every direction and every height (jacked the lca up and down at various heights) and never could get it to bust loose with a hammer. The passenger one came apart much easier. Not sure why this one was so much harder.
For those who've done their own leveling kit:
I've done several on my previous vehicles, and a fair amount of front end work in college, but.... I attempted to pop the upper ball joint this week, on my new Silverado, and it wouldn't budge. I used a pair of 3# hammers (one one the left side of the knuckle, the other swung from the right, and vis-versa.) Nothing! Puppy is holding fast!
A friend suggested that the knub on the back side of the knuckle was the appropriate target point... what's your experience?
Maybe try putting a jack under the knuckle and jack it up a little bit. Then try whacking it with a sledge.
Same here like the others have said. Right side popped off but the left side wouldn't no matter what I did. I was able to get the spacer in the left side without dropping the ball joint. PITA, but I got it. Also, I don't believe it's necessary to disconnect the electric steering connectors either. Those clips break super easy. Ask me how I know..
How did you install the spacer without popping the upper ball joint? I thought about trying to compress the strutt with a bottle jack while the suspension is at full droop.
With the opposite side still up in the air with both sway bar links disconnected, you can disconnect the bottom strut bolts and loosen the top strut bolts and just about get the spacer on without compressing. I tried that, it would have worked if I would have had a second jack or a second set of hands to help compress the shock or the coil/upper arm.
But getting the nut on the lower strut bolt that sits under the 4wd axle will be interesting if you don't drop the knuckle.
Edited by Mattvand
You put the bolt in from the bottom on the axle side.
Lots of persuasion! With the RC kits being polymer, once you get a corner of it started, they tap in the rest of the way fairly easily.
Edited by '17 Sierra
Nice setup. Love those tires! Any room for larger size?
Sorry never saw this, I think it can squeeze 35's just fine! Masbe with some slight trimming.
RANCHO RS999901
Has anyone used this to replace the entire strut assembly to level my truck? I can do this easily. Otherwise I was going to go with the Bilstein shock replacement and have to get a spring compressor and all. Thanks.
RANCHO RS999901
I have heard good things about the rancho quick lift other than they get rusty fast.
I want to get them as well but not sure if I'd rather get the fox ones.
Ordered the Rancho Quick lifts and matching rear shocks. I like the ease of install and not having to dismantle the strut. Should have them tomorrow and install them over the weekend if I have time. I've switched out strut assemblies before on many GM trucks. Shouldn't take more than a couple of hours.
Edited by raress9596
Hello everyone, I have a 2014 Sierra 1500 SLE and installed the Bilstein 5100's on all four corners. You don't have to change the rear shocks if you don't want to but that's up to you. You will need an alignment. The stance to perfect with an 1/8 of inch. Ride has since gotten better and more comfortable. Hope this helps.
Ordered the Rancho Quick lifts and matching rear shocks. I like the ease of install and not having to dismantle the strut. Should have them tomorrow and install them over the weekend if I have time. I've switched out strut assemblys before on many GM trucks. Shouldn't take more than a couple of hours.
Can you do measurements of the amount of lift it adds, the rancho page says that it will make your truck able to run 35s but doesn't say what it needs to be paired with if anything.
I found only one video of a guy running 35s with them.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
