Here is my 17 Sierra Elevation with a 2" level I got from Amazon (aluminum blocks for under the struts) and Nitto Ridge Grappler 295/60/20 on stock wheels.  I can turn lock to lock with no contact to the liners, but I suspect under load it will rub a little.  It does hit the sway bar at full lock, but not too bad.
Edited by 24v
After installing a Top Gun Customz 2.5” front level and an add a leaf in the rear, I’m taking the front back down to only 1” today. Reason is the ride up front bangs around more than I like for a truck with only 22k, and I believe GMC-AT who’s tried many level combos and recommends not going over 1.5” (and doing so only with under strut plates). If the rake is too much I’ll also remove the add a leaf but I’m about to haul a 4K lb trailer 1000 mi so I may hold off on the add a leaf removal.
I really like the stance but the ride and other guys’ issues with ball joints and other wear have pointed me toward a Zone 1.5” body lift—if I want to get back to this look after removing most of the front leveling kit.
Anyone else have ride quality issues resolved by using less of a leveling kit?
Edited by Shredder15
Clarification
I asked a ton of questions on this forum so I figure I owe everyone a report-out....
I was very hesitant and pretty skeptical, but finally installed Billy 5100s all around on top setting in front along with the ReadyLift rear 2.25 blocks and had aligned. I immediately notice the difference visually from about 30 yards away and is exactly what I hoped for; looks good and noticeable increase in wheel well space. Fitting slightly bigger AT tires shouldnt be a problem. I measured but pretty roughly as I wasn't too concerned about the fractions. I got 2" min. up front and obviously a solid inch in back. 1" of rake left. Wouldn't of minded a little more rake either. You can also feel the height difference sitting in the truck. I've owned a couple 2500s, one of which was lifted on 35s so I'm used to the height difference. I do believe I'll need to adjust the headlights down just to be safe. Haven't been flashed yet but can tell they're pointing slightly higher.
Driving is where this leveling setup really impressed me.  My round trip commute is 80 miles and includes roads of every type from highway to gravel.  I'd read all the reviews about a much firmer ride and feeling more of the small stuff in the road. You can feel a little more in the road, maybe, but not at all in a bad way.  To me It really feels really planted and just right.  Better grip, less bouncy at the same time.  Body roll is almost eliminated around bends with speeds in the low-mid range, still noticeable at higher speeds but improved nonetheless. Obviously it doesn't nose dive quite as bad during the quicker stops either.
My biggest fear was driveline caused vibrations due to the 3 degree rear block taper. Cross my fingers I haven't felt anything yet. Would still like to get on a much smoother highway to be absolutely sure though and stop worrying about it.
I do tow a 3 place but very light snowmobile trailer at the max; hoping it doesn't squat much if it all.
I too needed a leveling kit and researched and found Moto-Fab, they had great reviews and these were only $35.00 Dollars. Installation was pretty straight forward requiring the removal of tie rod end and the upper and lower control arms.  But I was a little nervous as the kit blocks measured only a tad over 1 inch but somehow i missed the day they taught Geometry in school but it raised my front end exactly 2 inches, had the alignment done and i love the way the truck sits and it didn't change the ride that much, in fact it stiffened it up a little which i like instead of the cushy ride.   I still have just a small amount of rake but i am please overall, and didn't spend a lot of money.
2 hours ago, Fall Sniper said:
Would like to level my 2018 Denali but unsure about messing with the magna ride and don’t want a harsh ride.
I installed a 2.5" Level from Suspensionmaxx with 2" Blocks in rear of my 2017 Denali. It rode just like factory before I put the 10Ply Ridge Grapplers on and it still rides great. I rode around for 2 weeks before tires and couldn't tell a difference except truck looked like it skipped leg day..lol
  • Like 4
Thanks for that info. Truck looks great.
With the 2” in the back and 2.5 in the front, do you still have a slight rake down in the front?
Yes it is a little less than factory but I pull a boat year round and didn't want the squat. I'm glad I did as some look like they are a little high in the front. The suspensionmaxx has the bracket relocator for the magneride and have great instructions. If you decide to do it yourself let me know and I can give you a few tips to make it go quick! Here is a side and front shot
Truck looks good!  What size Ridge Grapplers?
Thank you. The side shot shows it well. Did you reprogram your speedo when you switched to taller tire? I had a bully dog in my last truck which was a diesel.
Thanks! 285/55r22 and get a small rub on full lock on liner only
No not yet as I can't decide if I want to void warranty with a full blown tune or just go to dealer have them recalibrate speedo. These things are addictive as I already have a new grill being made and can't stop mods..lol
[emoji106]
    250.6k
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 162 Guests (See full list)
    • I don't wanna do major surgery/upgrades, behind-the-dash work, add amps, change radio etc. on my '26 std cab WT. On the WT, it has the base 7" IOR infotainment setup, and only two speakers (doors). Since I listen to classical, looked around for speakers that do well and dug thru reviews. Two-way speakers were found to be better than 3-way. So I've ordered a pair of  Infinity Reference REF-9632IX 2 way speakers.  [These may  or may not have been discontinued / succeeded by the 3-way ...9633 ones.]    These speakers are lauded for 3 ohm and 94db sensitivity spec so they'll work well for ordinary base car radios without amps and offer better performance (quality,  strength) than  default base paper-cone speakers. They'll be installed in a few days and I'll let y'all know what I think. Bill W San Jose
    • Thanks!   Changed out the rear shocks today to Bilstein 5100s.  So far feel much better. The stock Rancho were wore out.  Lots of heavy hauling (2 moves, home renovations, etc).  Next up is new BFG tires Monday.  Cant wait the current tires have little to no wet traction and are super loud (hum)
    • Ok, I got the all the codes. What do you all think would be a place to start?
    • How about I just point to the factory pans stand pipe little drain plug and claim its a pan with a real drain plug !. I just couldn't swallow the fact that a Dorman pan which at this point is probably the only pan out there that fits the gas version truck cost that much up here in Canada so I decided initially anyway to skip it and see what I thought of pulling the pan method and down the road if I felt inclined enough then I would either install a drain plug kit in the factory pan if there is enough room for it, or have a bung welded onto it, or put an aftermarket pan on. The thing is if the pan is not pulled then the magnets in the pan can't be inspected and cleaned or if wanting to change out the filter. However of course it certainly would make the job easier to be able to drop the oil first before having to handle the pan if dropping the pan that go around was the goal.    I knew a guy locally that was doing custom field spraying years ago with a pickup pulling a ground driven sprayer, I believe it was a GM pickup with an automatic trans. He had a drain plug in his pan and would drop the oil out of it once a week and top it back up through the dipstick tube to keep refreshing a portion of the oil often and that made the transmission last far longer than had he done nothing. Soft fields pulling 500 gallons of water at the start of each mixed up sprayer tank batch and in low range sucking along. I imagine he got some tips from other custom sprayer outfits doing the same thing at the time and learning from their blown up tranny mistakes. Transmissions then had no lock up converter so would cook the crap out of the fluid slipping that much and it would not have been synthetic fluid either.
    • 3.39 Kroger’s in Montgomery Texas.
