Kept it simple, went with Fox 2.0 on all four corners, adjusted to just shy of 1.5” in the front to keep a little rake. Added Ridge Grapplers in 275/55/20. I’m a little old school, I like to keep it looking a little stock.
How's the ride compared to stock? And where'd you buy the shocks? Debating between this and Bilstein 5100s. Truck looks good
Love this set up, looking at the same tire and size, any rub and hows the MPG? Ride?
Thanks! It rides just as smooth, but gets rid of that typical “over reaction” to bumps/rough road. Handles bumps/potholes in turns a lot smoother and got rid of that Cadillac float feeling on the highway.
No experience here with Bilstein’s, so I can’t tell you one way over the other, but you can feel the quality of the Fox’s.
I ordered from 4wheelparts, but even amazon has them for $370.
No rub, it’s actually the stock size tire, but is actually a little taller. MPG didn’t change, still getting 19-20 mpg after 200 miles.
Sweet! Im looking to go the same route but was affraid they might be heavy and cause me lose my MPG
My young brothers set up
3” level up front nothing in the rear
22” factory chevy wheels
35x12.50r22 toyo mt
1/2” wheel spacers in the front
Minor trimming on front
Looks pretty clean if you ask me
35x12.50r22 toyo mt
Very nice. You don't see many leveled regular cabs. I thought about leveling mine but now I think I'm leaning towards a 4/7 drop
Sent from my SAMSUNG-SM-N920A using Tapatalk
So fellas, I really like the trucks I come across on the forum and am trying to make a decision on a leveling kit for my 2015. I was initially set on the Rough country 2.5 up front with the 1 in in the back but have recently come across a few issues that people have made about it. I've read that RC tends to give a creeking/popping noise to the suspension up front during full turn, or just turning at that matter. I'd like to avoid running into that issue. So...from the people who have had the kit, or any other kit for that matter, can we get some reviews on your personal experience with your current kit and how long you've been riding it?
I know when I get new upgrades I really dig them straight off the bat, but as time passes and the honeymoon phase tends to fade I start seeing the issues I could really do without. So any experience which you guys have run into as time has passed with your kit would be greatly appreciated. Also please give recommendations which you have liked and what kits you guys would recommend due to no issues at all. I don't just want to hear the bad, but also the good. Thanks folks!!
+1  Was hoping to here the same type of review.  Looking to put a 2.5 leveling kit on my 2018 and was going back and forth between Zone and RC...
From all the research I've done in the past couple weeks, I would go with the Bilstein 5100 leveling shocks, and leave the rear alone. Will give you a little bit of rake for towing/bed loads, but much better than a spring spacer
35x12.50r22 toyo mt
Does it clear the UCAs with the 1/2” spacers at full lock?
Anyone running 20x10 -19 and 33’s with just a leveling kit?
Trying to figure out which kit to go with for minimal trimming
Before he installed the 1/2” spacer he would rub at about 90% turn (give or take) after the install he rubs after like 98% turning (again give or take) im just not sure if its from the uca or the sway bar. wen i see my young brother again ill check where the rubbing is coming from
Hope this helped
    • Apologies in advance, this is a long post, there's a lot to explain.   A friend had a 2010 Avalanche with a 5.3 (LMG) that blew the head gaskets (amount other problems). He gave me a donor motor out of a 2007 suburban (LC9). I got it all installed, and everything hooked up. Went to go start it, and it stumbled a bit at first and died a couple times, but after trying a few times it sounded like it was running very well. Went out to go get some coolant, and came back the next day.    Upon trying to start it, the truck will crank and fire normally and the RPMs will raise to around 1,200 or 1,500, sounding great, and then the RPMs will decrease and it will just die. Repeat that a dozen or two dozen times, and eventually it will fire and idle beautifully. As soon as you touch the throttle, it will start misfiring and sound like absolute trash. When you let off the throttle it will come down and hunt around shaking and misfiring like crazy. A message will come up on the dash saying reduced engine power.    It is throwing codes for a map sensor circuit voltage High, as well as MAF sensor low frequency. With key on engine off, the map sensor reads about 4.8 volts on the vout pin, which the PCM interprets as about 17.8 PSI, contrasted to the barometer which my scan tool tells me reads about 13.5 PSI. However, once the engine starts and is idling this reading drops to about 5-6 PSI at a stable idle, and varies significantly when the engine is misfiring/ hunting like I said before. I should note that I used the intake and MAP sensor from the LC9 engine. I changed the connector on the 2010 harness to The 2007 connector. The pinouts for the sensors were printed right on the top, and I triple-checked that I put the correct wire into the correct place.   On the other hand, the MAF sensor reads consistently 0.0 g/s regardless of State. I have pulled my hair out trying to figure out this last detail. I have tried three different sensors, (all of which should be good, one of which was new), I have verified all the wiring from the sensor going back to the PCM, and have verified that the readings at the PCM are the same readings as at the sensor itself. The intake air temperature sensor is also functioning as normal. I verified all the voltages and grounds etc, and everything is as it should be. I don't have an oscilloscope to verify, but I probed with my multimeter (Klein mm720) on frequency Mode, and it reads that on initial cranking, the maf is producing between 3000 and 7000 HZ, and as soon as the engine fires that falls off to below, 1000, and if the engine continues to run, it will produce somewhat erratic readings between 5 and 100-200 HZ. It does increase notably when the engine is revved despite the misfirings. As I said before, I have verified all of the wires going to the PCM, and I have tried multiple known good sensors. I've tested all the pins and voltages from the sensor and verified them against the manual that they are what they should be. I tested all the wiring for both ohms and voltage drop, and everything tested fine. Like I said I tested at the sensor as well as right at the PCM, everything checked out.   The only other thing of note at least I think is the fact that the engine originally in the truck had VVT, but the engine I put in, the lc9, does not have VVT. I modified the cam sensor plug to work. I reference the wiring diagrams and double-checked that I modified the harness correctly to adapt it. There is obviously a code for the VVT solenoid, but I don't think that's the cause of my problems, and this friend will probably have the PCM sent off to tune out the codes at some point.   I'm writing this for my bed so I don't recall the exact codes, but I'll update the post tomorrow morning with the exact codes. And ideas or feedback much appreciated.
    • It's possible the two trucks are using different body control modules which is why yours works and the OP's doesn't.   So much in these newer vehicles depends on model/trim configurations, production date. They don't all use the same modules like back in the day.
    • I forgot to answer the question as per what market mine is set to and yes I finally found that area on mine and yes its also set to America.   So here's something I realized as I wasn't looking at that part in the Sierra section until now, your right that what I see here as choice 3 under Sierra which says 07/2023-06/2026 ( 433 MHz 13542523 ) it has no choice 5 for tire pressure selection. Where as it does under the Chev choice. However I kept going down the list within the Sierra and I am really wondering if choice 9 will work for your truck as it has the same model number and hertz sensor as my truck. I would say try that choice first, if that doesn't work then jump over to the Chev section and again choose that same model and hertz choice as for some reason the Chev section gives the choice 5 of tire type/pressure selection for going back a number of years. Could very well be an Autel thing that they just didn't get the updates all done properly under Sierra but anyway first try that selection 9 I suggested under Sierra and then go from there.
    • Looking for this piece that holds the hose clamp in place. I have the hose clamp just not that other piece. Dealers and wrecking yards in my area will not sell just that piece. They want you to buy the whole air tube $100 +/- to get that $5 part.  that piece isn't molded to the air tube as I looked at my friends truck. It's held on by a screw and nut. I'm trying to put the OEM parts on the truck as the previous owner butchered things up installing an aftermarket CAI. It really looked homemade. 🤣 Thanks
    • Ok I missed that part that yours is a GM. The strange part is that the choice for year ranges and within the year of 2026 is different on the Sierra then on the Chev for some reason as I am looking at my tool at the Sierra choices. Now I am guessing you see as to your sensor part number as it may be different on your truck for some reason and a call to GM should get you the part model number of the sensors you should have as well as which MHz your sensors are. I know mine are the ones as per what I listed but there are other choices in the Autel and got me wondering if by some chance they put different ones in your truck. Having said that, did you try using each of the choices starting from No 1 and going on down the list, not sure if that would mean shutting off the engine each time and resetting the tool and going at it again each time. Also I thought of something else which may sound retarded but if there was some stupid chance that the chev choice would work. The reason I say that is that the Sierra is showing a range up to 06/2026 for the various choices of sensors it could be where as the Chev has one choice that has that 12/2026. By the way it is possible to not run the truck and you may know that as per not pressing the brake but pressing and holding the start button for a few seconds and it lights up the dash ( its called service mode ) but that sucks battery power and if it were me doing it that way I would be throwing on a decent sized battery charger before doing it that way as killing your battery won't make you happy at me at all !.    Like I say, just a thought to try the Chev choices if you have already exhausted the Sierra choices but first it would be nice to know for sure what exact sensor model and hertz your truck uses as I assume only those choices that mention the sensor would work unless a choice that does not mention the sensor model would somehow work. Its frustrating when one is trying to use tools like this without the experience of the tool and the vehicle, as I am sure dealer techs themselves struggle with it when starting out or a new model year comes along that is slightly different.
