Just now, Jaychevy81 said:
Nice truck I have the exact same one lol
Haha awesome. Even tho it has a little red on them. It definitely makes it sexy.  I want to do something to it with keeping the redline rims even tho there’re just painted red stripes lol
My thought what I want to do is match the red on the rims and do 2 stripes on the hood in the indents. I think that would add to it and still look good. Man I love this truck everything about it.
Meh that would be too much. Lol but would be cool to see
Yea it may be to much lol. Not sure what else I wanna do really don’t need to do much to it lol.
That’s why I was thinking an aggressive all weather tire and maybe a level kit or at most 4 inch lift. And I don’t want a poor man lift
On 2/17/2018 at 12:47 PM, CradleyBooper said:
Just put a rough country 2.5” level in the front only and got some new wheels/rubber. Running pro comp 34 Rockwell with 295/70/18 Terra Grappler G2’s. It turned out pretty well I think. Although, I might install the rear block sometime this week. Tires rub slightly at full lock but I’ll get around to trimming that soon.
Truck looks great... I really like the looks of the Pro-Comp 34, so much  I picked up a set today. Since my truck runs the Bilsteins I'm .75 lower than you up front so I'm going to try for a 275/70r18.  Not sure on the tire, though. Ran the Nitto TGG2 on my Cummins and they were excellent. Might just go back to them for this truck.
Thanks man! I think it turned out well. These are the first set of TGG2’s I’ve run and I do like them. I was considering a more aggressive tire but I spend 95% of my time on concrete so I didn’t want to spend money just to turn around and spend more. They’re a little big for my lift but I’ll live with the rub if I get the look I wanted.
4 hours ago, goeb34 said:
Any pics of 2014 sierras with a leveling kit and no rear blocks?
gmc-2.thumb.jpg.c7ba01a61702e0eb762c8a4f2f29d703.jpg2" level kit and factory rear blocks.
305/55/20 Terra grapplers no rub at all with 1/4" spacers
intaled the rc 2in level... im happy with it... will look better with summer tire tho... very easy to instal your self just folow the instruction and its a piece of cakelarge.20180329_143426.jpg.f74756a79bb950
On 3/28/2018 at 6:43 AM, Lineman20 said:
I finally got my leveling kit installed and 275/65/20 firestone destination mt2. I love the new look.
Looks awesome. Any rub? How’s the ride?
Ride is great. Only rub is on the felt fender liner. All it will take is a simple zip tie to fix. Bout a quarter to half inch that the liner needs to be towards the frame. Only at full turn to the left in reverse does it rub
Probably 3/4 of the trucks in this thread are that set up... Or are you talking about removing the stock rear block and adding a leveling kit which is just dumb.
Tyler
Hey guys. New here to the forums. This may have been discussed... I have looked through some pages and honestly cant get past looking at the pictures of all the awesome trucks builds! I have a 2014 Sierra 1500 4WD Crew Cab. I want to level the truck by lowering the rear. I don't haul anything heavy or tow. However, I have to remember Mom & Dad need to get in sometimes. :lol: I was told removing the stock blocks under the leaf springs would level it with the front. Is this true? Or, is the better option to buy the lowering shackles? Thanks in advance!
Excited to have my truck leveled soon. 2.25" Procomp and I'll put on some 285/70/17 Mickey Thompson Atz p3 to match... Two weeks until I can post some pics.
    B07
    B07
  • Who's Online   3 Members, 0 Anonymous, 912 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
