That looks awesome! Going to do the same setup but with a 2" level until I can afford coilovers, and bronze NV with nitto g2s. Do you have any pics from the side? Truck looks great
18 minutes ago, Slatemetal15 said:
This is the only pic I have at the moment. 25fdecb52844c9dbab60a15e7da5c911.jpg
Can you get pictures of you bj angles and tie rod angle? Also what is the measurement in front center of hub to top of wherl well
Yes I will get pictures tomorrow, sorry it’s already dark outside. I did go out and measure center hub to fender though.
Before-21.25”
After-24.00”
On 4/29/2018 at 4:52 PM, MHardiman90 said:
Thanks brother! Motofab 2.5" level, rear is stock. BORA 1.25" wheel spacers. Toyo R/Ts 33x12.5.
Man, your trucks looks awesome! Perfect setup.
How much of a power/mpg hit did you take? Any rubbing?
So...I see people post (here and other places) shots of their trucks with 2", 2.25", or 2.5" and each will claim it sits perfectly level...sometimes I see a post of one with a 2" and I think it looks great then I'll scroll down and see one with 2.5" and think it looks great.  I do not want my '15 Silverado Crew z71 to look like the front is higher than the rear.  A buddy of mine said a 2.5" Motofab had his sitting perfectly level (by looks and measurement) but then I see Ron505's post of his 2" BDS and it almost looks like the front is slightly higher. lol
All that to say...I'm not going to be disappointed with a 2.5" Motofab on the front, am I?  I.e. it'll sit level?  Stock wheels/tires for now...will go slightly bigger on tires when I replace 'em down the road.
MHardiman90's looks great to me (looks level, etc.) but I guess I'm just on the fence and wanting to make sure I'm not going to show up when they finish installing it and regret something.
I have the 3/2 MotoFab kit on my 15 LT. I took measurements from level ground to outer fender lip. These pics are before I went up to 285/70/17. As you can see by the measurements I still have roughly 1” rake. I still need to get measurements since I got the bigger tires.
Before 3/2 level
RF 35 3/8
LF 35 3/8
LR 38 3/8
RR 38 3/8
After 3/2 level
RF 39 1/8
LF 38 3/8
LR 40
RR 40 1/8
Delivered via my cellular device using a mobile chat forum thingy.
I wish I had the factory 17's instead of 18's.
You went up to a 32.6" tire which is probably all you'll need to give it that balanced look.  Pics with the 285's would be great.
I’m actually looking for the black Police Tahoe wheels to get rid of my shiny ones. It looks more raked because it’s on my sloped driveway. a612550882444552f54b3ae905e73511.jpg
That right there is the look I'm going for.  Go up in tire size just enough to look right and to keep the mpgs close to stock.  Ive got stamped steel control arms so Ima go with a 3.5" lift but with new knuckles.
3 minutes ago, Slatemetal15 said:
Everything looks perfect
https://tiresize.com/comparison/
285/55R20 are smaller than 285/65R18 (by 1/3 inch tall)
check this out...that size is really close to 285/65R18...i think it would be fine...but as far as Duratracs...many people love them, I am not a fan...when I got my truck, I swapped them out for KO2s within a month...
I have 20’s, so I won’t be getting an 18” sized tire. Any one have input on 275/60/20 and the ‘look’ factor of them? Not a huge change from stock but enough from a side
Profile that I think it fills the wheel wells better than a 55 sized tire.
Thanks bud! I lost about 2 miles per gallon. I'm averaging about 16-17 now but on highway I get up to 21mpg. Very happy! Only rubbing fender liners on full lock and a little more in reverse. No big deal though, either go to trim or pin back.
Edited by MHardiman90
    • Compression test? Weird noises? Fuel trims?
    • I suspect at some point in the near future, the hardware will be free and you pay a subscription to access the vehicle - alldata style.
    • I've been eyeing an upgrade to my tonneau cover for a bit now.  Intrigued by the BAK MX4 EZ-Lift with the torsion spring and went for the upgrade.  Thoughts and musings during unpacking, install and a few days of usage.   Once my order went into Realtruck, it took about 4 days to ship.  Unfortunately, FedEx Ground destroyed the box and contents and it was unusable upon receipt.  To Realtruck's credit, one email with pictures and an RMA was sent to me to send the first one back, and another unit was shipped out.  It arrived 3 days later, unscathed.   I opened the box and it looked like every other BAK MX4.   Biggest differences are the rails and retaining clamps, and of course the spring attached to the cover itself.     NOTE - if you are upgrading from a MX4 to the EZ-Lift, you will have to replace the rails.  The EZ-Lift rails have a notch cut in them to allow the new style retaining clamps to fit properly.  The new retaining clamps also have 2 knobs/carriage bolts and there are two tracks underneath the front panel. The strap clips are mildly different (more like the Undercover Flex clamps) in that the screws go in from the underside.  Personally I prefer these over the BAK clamps that use the nutserts that are a nuisance to install.  The remainder of the parts in the box (drain tubes, rail clamps, and bumper pads) are standard issue BAK.     I did not replace my front bed seal at the time because it seemed to be in decent shape.   BAK recommends shims on the GM trucks unless you place the clamps on the flanges about 1/3 of the way in from both the front and rear of the bed.  I shimmed the front and the middle, and initially placed the clamps equidistant.  This also turned out to be a mistake, because when I set the cover in place, the new style retaining clamps wouldn't clear the front clamp.   New style clamp inserted in the track:     And the issue which occurred because the front rail clamp was too far forward:     Once I removed the shim from the front of the bed, and slid the clamp back to the front flange, everything cleared fine.     The cover set on the rails without issue and I installed the strap clamps.  After I completed my adjustments, I pulled the pin to activate the torsion spring.  Mistake #3 on my part.  PULL THE PIN AS THE VERY VERY VERY LAST STEP!  The reason is, once you pull the pin, the torsion spring is activated.  If you have to loosen the front clamps and adjust the cover, the front panel will - by virtue of the spring, refuse to lay down.  The only way to get it to lay down so you can reinstall and tighten the clamps is to fully open the panel against the back of the cab, which will then allow the front panel of the cover to lay down and be tightened.  Not a big deal unless you haven't installed the foam pads yet (typically the last step) because minus the foam pads, you will need to place something between the frame of the cover and the back window so it doesn't get scratched.  The next time I install one I will install the foam pads before I pull the pin and activate the spring.   After using it for a few days:   The spring assist is great.  You literally can open it with one hand.  My shoulders aren't getting any younger and this was part of my motivation to swap out. The second panel latches and unlatches itself as you open and close the cover.  Neat in concept, however it took me a minute to get used to closing the cover and not hearing the "latching" sound that would tell me it was locked in place. The paddle handles are a huge upgrade and I wouldn't be surprised to see them become the standard across the Realtruck line.  They effectively eliminate the concern that a thief could coat hanger the cover open and get to the contents in the bed. I'm not sure why the very front panel on my cover has a different finish from the other 3 panels.  I have a request into Realtruck to find out if mine was not manufactured properly or if it was by design.   All in all I'm pleased.  Same level of protection, looks good, keeps stuff mostly dry (they all leak around the tailgate) and easy to install.
