Just installed a 2in MotoFab bottom spacer last night. Love the look of a leveled truck. It just seemed to lack the aggressive look with the rake.
Next will be new tires. I wanna keep the stock 18in wheels.
I’m stuck between 285/65 and 275/70.
I know a lot of people run the 285s, and I saw one guy in here with a 275/70, messaged and haven’t gotten a response yet. Anyone have any experience with the 275? Was there any rubbing? Here’s some picks of the truck before and after and the wheel sizes I’m looking at.
55db52f1c5e0616a37a2e585e055c998.jpga3308adf09a195877205ecabb886f1d5.jpg353979768992353dc8009bb441d83c5a.jpgbc81aa93eec84f373ba8c94474515802.jpgf0f42d49c99f98b4fdd54eae95f2e578.jpg8ab246b70f662a6b8fc295f98be0aa79.jpg58c78ab8ed03635410771bbbd386003e.jpg97977aefb3ead81e054a84962e3fcd8c.jpgbece64fe0fb963842440c636939641c8.jpg
I ran 285/65r18 ko2 on my stock 18s. No rubbing as far as i could tell60012f78c8160467a5af27f17d179a5f.jpg
Sent from my SM-G973W using Tapatalk
2 hours ago, Slick66 said:
I am running 285/60 R20 Toyo Open Country RT with a 2 1/2 leveling kit and I had to add the RC 1/4 spacers behind the stock snowflake wheels on my 2018 GMC to stop the rubbing on both the UC Arm and the sway bar.
any vibration after adding the spacer, i have the same setup just with Ridge Grapplers
Zero issues from the spacers but prior to adding them I also added a 1inch differential drop because I was having some vibration issues because of the cv angles after leveling.
what brand
I used one from American Automotive purchased through Amazon.  The instructions were fairly simple but you will have to do a little grinding to remove a couple of the cooling fins. It can be done without dropping the diff fully out like instructions tell you.
Ok thanks
    Tbhats2130
    Tbhats2130
  • Who's Online   1 Member, 0 Anonymous, 912 Guests (See full list)
