I have a 2016 silverado 1500 4x4 Z71 Crew Cab 5.3 with a lift/level kit, 2.75" block on struts up front and added leaf spring in the rear. Also has an aftermarket front bumper (not sure if that matter much for clearance issues as it seems most issues occur on the cab side of the fender) current tires are 285/65r18 Kelly Safari TSRs. Due for a new set of shoes here soon and I'm curious if I would be able to clear a 295/70r18 Cooper Evolution A/T..specs on the Coopers say it is a 12.0" wide and 34.3" tall tire. I would be adding 2" KSP Hubcentric wheel spacers on my stock 18s. Thanks in advance for any help! Looking to order new tires within the next 2 weeks here.
https://photos.google.com/photo/AF1QipPg5j2OoZvI9TsT7rXTzGhS-WB-_SehFNB-SC17
https://photos.google.com/photo/AF1QipP5aumkLVL3ahqFSDY76mRE4KpnT_7KbAk2f01H
https://photos.google.com/photo/AF1QipMPsdsLkgU9AENV4oIzVqKC2JS6NFkLk86v4rYw
Sometimes in life - you just gotta send it.....
2015 Chevy Silverado 1500 5.3L V8 Z71 with newly installed Toyo Open Country AT3 35x11.5r20s on just a 2.5" RC Level.  Yea I said it - just the level - no RUB.  And no difference in ride quality on highway or just intermediate roads.  AT3s run smooth and are way quieter than Ridge Grapplers.
On 2/5/2022 at 4:24 PM, Jake2017AT said:
Figured I’d share. 2.5” Rough Country level and 285/60/20 Toyo AT3’s. Love this look!B67A4FB4-027B-49C7-BA80-B95F21DD96C8.thumb.jpeg.454d046a3cd431da17e4daebd20ca500.jpeg
is this the RC 2.5 front only or rear too? Truck looks great!!
this would be front only
This is my ‘17 Sierra Z71 SLT crew short bed. 2” HaloLifts coilovers in the front with their rear shocks on a stock block.  I have the +1” block if I do ever decide to throw a shell on the back or find myself hauling more. Running 275/70R18 ko2s on 18” Raceline 946 Boost wheel with -12 offset.  Really wanting to go 295/70 on my next set of tires but really don’t want to worry about having to trim anything. Also have the Diablo tuner set to their 87+ tune. I think the next item on my list will be to replace my aluminum running boards with Go Rhino RB 20 running boards, probably sometime in the spring.
  • 7 months later...
I need to take some pics.
I finally got around to putting on the Bilstein 5100s fronts and rears. I adjusted the front to the highest setting, 1.85”. I’m running Nitto Recon Grapplers and I still have some rubbing at full lock on the UCAs, especially in reverse.
Bought this truck a month ago
Installed rc 2.5 level with m1 monotube shocks all around.
Put on 265 70 17s ridge grapples to replace the stock 20s.
  • 4 months later...
Fuel Lockdown wheels 20x9
LT295/60R20 NIT Recon Grappler A/T
Added 1 inch front spacer to front King Racing shocks and level as can be, rides nice.
  • 8 months later...
IMG_0388.thumb.jpeg.f2416194efa390577f81d10b92982528.jpegI have a 2018 Silverado LT which had a 3” rake and used a 2” front end lift by Moto Fab. I run stock 17 wheels and Yokohama X-AT 265/70R17 OW:10.50.
Next tire change I will go to 275/70.
Edited by David 2018 Chevsil
  • 7 months later...
'14 Silverado LT with 2" RC leveling kit on the front. Has 18X9 +18 Ultra Motorsport Warlock rims with Toyo Open Country 285/65/18. No rubs and did not rub without the level kit.
Owned this truck for 8-9 yrs, then traded in 2022.
Hello everyone, I have a 2018 Silverado Ltz Z71. Currently has stock 20s on it. I have a 2.5 Inch leveling kit with add a leaf in the rear form Auto Spring, as well ordered a set of Bilstein 5100 for the front  to swap out. Id like to run a set of Trail boss rims on my truck, preferably 18s but would run the 20s if i have to. I have had a few people recommend me to run new upper control arms due to the lift. Anyone have recommendations on Ucas? I'm planning on running 275/70r18 or 275/60r20 depending on rim size. I'm relatively new to backspacing/offset stuff. Looking at different Uca's most say you cant run stock rims with some others make no mention. Thanks for the help everyone.
Hey all, I've got a 2015 LTZ 4x4 and have been running a Readylift 2.25" level with the top and bottom spacers. Just ordered the Eibach pro kit this morning after finding a leaky shock. I'll be leaving the clip on the lowest setting for 2.5" and am looking at/wondering if I should also do UCA's. I'd like to improve the ride but more so want to keep my angles right and help preserve ball joints. I've got stock 20" wheels with 305/55 and know I'll more than likely have to throw in a 1" spacer until I get new wheels/tires to clear almost any of them. I've really been looking at Kryptonite and Readylift, also Motofab/KSP/Cognito but the Cognito instructions look like a warning label with max shock measurement, limiting straps, trimming shock tower etc. just so much more than the other companies for whatever reason. I don't care about the price just want the right one that's going to last, if that's a Motofab with Moog's in it, so be it. Any experience greatly appreciated, TIA.
I have the Eibach Pro Truck stage 1 kit on my truck. I have roughly 50k miles on them with the stock aluminum UCA and my ball joints are still tight at 104k miles.
When/ if my upper ball joints need replacing I plan to go with the Superlift UCAs. They are an aluminum arm similar to my factory arms but with increased ball joint angle. Be careful with some of the fabricated arms. They won’t clear positive offset wheels.
    Tonwantonga
    Tonwantonga
  • Who's Online   5 Members, 0 Anonymous, 398 Guests (See full list)
    • What I think you're saying is there is supply here at home, and in Venezuela, and we could ease pricing if only it were favorable to do so.   Well, yes?   But that's not the current market. Supply isn't what could someday exist, if only, it's what producers are willing to produce and sell at a certain price point.   The national price of single family homes would come way down if we'd just slap together a few million homes this summer.   RAM and GPUs would get a lot cheaper if we just set up some factories to produce a bunch more and stopped using it to build out AI data centers.
    • The turn signal/multifunction switch is faulty.  I've seen a few of these go bad at work.
    • I am experiecing the same issue, I have gone in the setting and disabled rain sensing function but I am still experiencing this. Whe i use my turn signal they will redomly turn on. Sometime they stay on and others times we swipe 2 or 3 times and stop. Its super anoying, escpecially after a fresh wash. Anyone have any advice? . rain-sensing function, but I am still experiencing this issue Sometimes they stay on, and other times we swipe 2 or 3 times and stop.It's super annoying, especially after a fresh wash.When I use my turn signal, they will randomly turn on. I am experiencing the same issue. I have gone into the settings and disabled the rain sensing function, but I am still experiencing this.
    • If we actually used any significant amount of that source in the USA then I'd agree but we don't. We've had that discussion before. We drill and pump more than we use. Thing is, we sell. We export. Gas and Crude. It's more profitable so any shortage here is self inflicted and LEGAL.    I worked a gas plant that has multiple fuel sources available and I worked in the furnace and boiler plant in that facility. I'd had days we swapped fuel types four times in a twelve hour shift which isn't done on supply but on margin. Two of the fuel sources are internally generated. Tail gas and DAK, both of which are sold as well a consumed. We always had more than we needed to run the process but we chose the fuel that produced the best margin not bought at the cheapest price always. A good bit of math to that and back in the time that was done on a slide rule.     I worked the Shale Oil Semiworks of Chevron Research and CONOCO Research in Salt Lake City. That process never went into production although it was very successful. Why? Did we lack oil bearing shale? Nope. Price of crude never made the margins work. That was in the late 70's early 80's. Remember history? What was happening then was a reaction to that situation. It didn't drive it. If so then it's easy. This isn't a supply and demand thing. This is a profit and margin thing and AI rules that now.    In no refining situation that I was ever in would a bomb hitting a well anywhere in the world 'instantly' interrupt or even distress the supply. Most plants have more than a months worth of crude in the tank field and more in pumping stations. That yo-yo could play out over days, weeks and maybe months and have zero impact on plant operations. How many times has this been off and on in the last few months? These people and not stupid. These plants measure down time in hundreds of thousands of dollars per day. They are not sucking fumes or waiting on the next truckload with baited breath. Besides, as I noted, they are for the most part 'vertically integrated'. They own it from the dirt is sits in to the delivery rack and sometimes to the pump. It has a HUGE shock absorber built in. When production suffers, refining wins and when refining is winning exploration is killing. The rest of that crap in the news is a 'news cycle'. Government dipping in to reserves? Oil is stealing their milk money. There's a reason Chevron abandon Venezuela infrastructure and it had nothing to do with security of US citizens. Nationals run those plants. it has to do with MARGINS disappearing to corruption. They are in no hurry to return. Is there supply there? Oh yea. More than enough to offset what is bought in the middle east. Just isn't ???? Profitable.    We have supply. There are places in Illinois you can drive a pipe into the ground and run your homes natural gas furnace on it.    A refinery fire will gum up the supply works but not a localized war where the market is using a limited supply from. Now Europe, that's something other....
    • $4.00 a gallon here now.   Diesel nearly $5.00 again.
