Are your wheels 18×9? I was just looking at discoverer st maxx 275/70/18 and was wondering if they would fit a 9" wide wheel?
Sent from my SAMSUNG-SM-G935A using Tapatalk
Based on his above post, he has 20in wheels, not 18s. He had stated his tire size was 275/60/r20. With that tire size, my assumption would be a common 20x9 wheel, but I don't know for sure.
Generally a 275mm tire would fit a 9in wide wheel, but all tires are different. I had just checked the Nitto G2 sizes and they don't recommend putting that size of G2 onto anything wider than 8.5.
I believe I've seen a couple people here mention having 275/70/18s though.
Edited by Big Red 'Rado
I have 20x9. I know you are looking for an 18". That's why I added I have a 34" overall tire.
Yes sir. 20x9
Regarding the 275/70/18, Cooper's website puts it at a 33.39in height. Awhile back I'd seen somebody mention running a 33.21in tall tire without a level. Not sure how close they were with that, but my guess would be that the extra .18 in height shouldn't be detrimental.
That was what somebody said, but who knows how closely they were monitoring for rub and such. Some people pay more attention than others when listening/feeling for small variations in their vehicles. Your best bet would be to ask your tire dealer if they can do a test fit.
This is very true. I if you want to fit a big tire under these trucks you have to balance wheel offset and tire width. I knew I couldn't go 33x12.5 or 305/55-20 without rubbing. When I saw on the test fit the issue was width and offset, we tried the slimmer tire and got another 1" of diameter. Increased my ground clearance which was my goal. So although I would love a wider tire my goal was ground clearance and that's what I got.
I have a 2014 silverado 1500 with a 2" rough country front only level. Just got myself a set of 18×9 xd hoss wheels with a +18 offset. Anyone think I would be able to clear either 275/70/18 or 285/65/18 without any rubbing or trimming? Greatly appreciate the help.
Yes, both will fit, no problem.
What height of level did you have (sorry if you've mentioned it before), and also what was your wheel offset? And did they actually toss up a 305/55/20 during the test fit?? I was thinking the 305/55/20 would be tight, but still clearable.
My wheels are 20x9 +15 offset on a '14 double cab with a 2" motofab level.
(this is all stuff that has gone through my head, I'm not making claims that it successfully fit, just thoughts that it could)
We test fit the same wheels 20x9+15 with both tires. The 305/55-20 just rubber slightly at full lock. The 275/65-20 just clears without rubbing at full lock. I have a RC 2" lower level block.
Was it just rubbing the liner, or did it look like it was going to hit UCA/Swaybar? Like, do you think zip tying the liner would have fixed it, or was it hitting something physically mechanical?
Fender liner only. The offset gives plenty of uca clearance. I'll take a picture of the uca with my current wheels and tires. The 305 tire is only 3cm wider on the inside of the wheel well.
So I have these factory 22's on the 16 silverado 1500 4x4 z71 lt, and put the readylift 2.25" on the front. I'll be damned it looks pretty good but I really want a more aggressive looking tire and one that fills up the wheel well and gives me even more ride height. I've read and read these posts and it's exhausting to scroll through them all looking for options I have. Does anyone run a taller beefier tire that gives them a taller ride height and can fit on the factory 22" wheels? Again I know the 2.25" ready lift level kit should help but I'd like to hear from someone with experience and see some pictures. Thanks in advance guys!! 0f143802ab13082a3cba9349a28dc4bf.jpg
Edited by Houseopayne
I would recommend 285/50/22 as a safe/"beefy" tire. That would put you around 33.3" tall tire. Or if you want to go a little wider, you could try the 305/45/22, which is like 32.9h and 11.93w, but it could be snug (possibly even requiring you to zip tie the liners).
Just got my 2016 all finished up a few weeks back - maintained about 3/4" of rake, but looks pretty level to the eye
Bilstein 5100 all around
OEM 20" GMC A/T wheels
stock tires for now - soon to be either 33x12.5 or 295/55 (33x12) Toyo M/T
20% tint all around/50% windshield
Front - 2.5 inch (combination of bilstein 5100 set to 1.25 and 1.25 top spacer)
Rear - 1 inch (replaced 1.25 stock with 2.25) w/bilstein 5100
F - 39"
R - 39.75"
Picture is the day I bought it vs. how it sits today :)
Edited by Travis1024
    Whit.the.COB
    Whit.the.COB
  • Who's Online   5 Members, 0 Anonymous, 1,371 Guests (See full list)
    • I gotta say, I'm enjoying your narration. The troubles you've been having are amusing as you describe them. It's good to see that you're finally getting some satisfaction out the old beast though.
    • Declaring victory would upset the demons that possess this Blazer, so I won't. But I did make progress today--after it put up a fight. Always a fight.   I had the day off so I spent the morning cleaning up the shop and I thought I'd get ahead of things by filling the cooling system in prep for the final part I needed to arrive: the driver's side knock sensor. Glug, glug, glug....and then the unmistakable sound of liquid hitting the shop floor. It induces the same chagrin when the sonar and targeting laser temporarily malfunction during a late night bladder evacuation over the toilet with the bathroom light off. D'OH!!! That made a mess...   Oh, hey, that knock sensor I removed? It threads into a wet port. Who knew?! Learn something new every day. Put a pin in that chore, I'll fill it the rest of the way later.   The knock sensor arrived at about 1pm. I threaded it in, connected the wire, filled up the coolant, checked for leaks, and... drumroll.... fingers crossed for a perfect start, excellent timing, model fuel trims, and ...no squeaks... Here goes.....   No, it didn't start. At all. I cranked it a few times and it wasn't sounding good. Furthermore, I heard leaking again. Jesus H Tapdancing Christ, stop leaking all over the dang floor. This time I had accidentally overfilled the coolant reservoir and the churn of the water pump via cranking caused a bit to burp out. Ok, just, breathe... Put the flamethrower down. Dang thing wouldn't burn anyway, leaks too much...   Did you know the rotation of a round crank sensor in a round hole, matters? I do now. Took me about half hour to retrace steps and realize what I had done. Then it started right up.   No squeaks. The squeak was the old balancer.   Once it entered closed loop, fuel trims are dead on, hovering right around zero at idle. No more -30%. I'll credit the injector rebuild on that one.   Timing? I think there's an OBD 1.5 translation error with my Actron scanner. It's anywhere from -20 to -30 at idle, sometimes as high as -40 cruising. Sorry, the engine just isn't running that smoothly at -40 degrees ignition advance. It's just not. It's smooth all through the rev range and has decent power. I'm going to have to trust the seat of my pants on this one.   The new exhaust is very quiet. The old catalytic converter? Not melted, but definitely not healthy. Rains glitter when you turn it on its end...all the precious metal is flaking out. Once the new exhaust system burned in/smoked off a bit, the engine's exhaust smell is normal again. Not that I'd recommend going around huffing car exhaust, but, you know what I mean?   One problem to correct. The new exhaust has the opposite problem of the old spliced up exhaust. It wants to hit the floor where the old one wanted to rest on the cross member. Happy medium, please? Still noodling on that one, need to look at how I can adjust some hangers.   I don't know what's next. On one hand I want to run away from this thing as far and as fast as I can -- there have been a lot of NOT fun moments. On the other, now that it kinda drives nice, maybe drive it around for a little bit?   Shhh... it's not currently dripping oil all over the floor. I can see just a little wet at the bottom of the timing cover where it meets the oil pan seal. It's not dripping multiple drops with every ignition cycle, in fact, after some driving this evening it has yet to even form a drop that could drip off yet. But the weekend is young... I fully expect this could turn into Exxon Valdez by Sunday. Because this Blazer hates me. LOL.
    • About that:   Once upon a time in a land far far away lived a car company that was shy about taking your money and wanted to be sure that they gave you more that you asked for so that you'd come back. No really, not a fairytale. 😱   But after the field got thinned out enough to limit the competition it seemed good enough to give you only what you asked for. Fair enough I say but in such a market you have to give something the others are not or they go to the one who does. Gimmicks or glitz. Oh, fins and chrome. Yea, shinny crow like cars. Yum.    Field narrows a bit more and 'brand loyalty' becomes a thing and the minute it does they start thinking to themselves, "Could we make more money if we gave them less than they expect and they will hang in there for brand and comfort with the known?" They gave it a try and da*n, it worked!!    Well, what if we teach them, groom them into believing that less is "Normal" and cut some more corners. Will that work? Oh heck yea!    🤔 I wonder, can we give then WAY less than they expect and make them mad enough to spit nails and STILL get them to pay up? Sure, if we get everyone else to do the same so that the choice is less or nothing at all. How would be do that? Platform sharing.  What a concept, right?  Steal like there is no tomorrow and it's legal too!    Truth is no one is going to give up driving, not for very long. The Gen Z crowd is fine with it and will be as long as someone not Gen Z will haul them around. At some point we all die.    Economic voting only works if you cast a NO vote now and again and enough of them to get dumb and dumber to wise up. Well, that's how I was taught anyway. And it should have worked. Would have worked. But the Bail out!!   Look, you have another choice if  you take that bag off your head. If the dumb it down to some predetermined expectation of how John Q Public will use it the, that is under design it to failure they you use it to a lower stress mode. D'ho!    A 1950 Royal Enfield Bullet 500 will go anywhere a Suzuki Hayabusa will and for just as long. But you will have to treat it for what it is and not for what you wish it was.
    • Maybe I was just too unlucky, but I had nothing but bad luck with Bridgestones. Out of 3 sets, they all started losing a lot of air when they got down to about 1/2 tread life, and at that point also wet traction suffered more than it should have. Also, the only tire I ever had in my 60 years of driving that had a side wall blow out was a Bridgestone.   I'm currently running Goodyear Wrangler Workhorse AT and am very happy with them.
    • maybe when the trip is over, check all the other joints in the front end, like all the ball joints, tie rods, pitman & idler arms, etc...
