2" is good enough to level out the rake.
I think either it has some sort of level under there that you don't know about... or you are rubbing on your UCA's or something and you are only looking at the fenders. It is not possible to run 12.5" tires at stock haha
Okay, I am rubbing at full turn, I just tried it and realized that. Is this a problem for my control arms or will I be fine? I do not see any real signs of wear on the inner tire or control arms. Will it be okay to run a 2" level kit if I have this going on? I'm now thinking about returning it and doing a 2.5"...
33's on stock height is fine. The only thing that would worry me in the 12.5 width. I know that 11 width doesn't rub, but that extra 1.5 inch would be the only thing that worries me. All you would have to do is look on your wheel wells and UCA's to see if you can see any signs of rubbing. If you don't see anything, keep on rocking it.
First time posting in this thread but as soon I'll be looking for rims and tires. A guy at my gym has a 15 silvy. No lift. Running fuel rims don't know width or offset...But he's running 33x12.5x20 Toyo OC mt. He didn't tell me this, I looked. I thought from reading 12.5 would rub especially on a no level or lift but he says he has no problems. I have 3 in level w 3 in blocks out back. I would figure w 3 inch there should be no problems. Anyone running this setup and not have any problems?
Sent from my Nexus 6P using Tapatalk
Edited by Jeff5347
Would love to see pictures of both these stock trucks with 33x12.50 tires with no rub. They are only 32.5" or so tall, so that's very believable, but that extra width usually spells trouble for UCAs, swaybars, and sometimes fenders, especially with no lift.
Anxiously awaiting pictures.
It's a hit miss seeing him. If he's there tomorrow I'll grab some.
Anyone done the MotoFab 3" front and 2" rear leveling lift kit?
https://www.amazon.com/dp/B0156T83UI/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=3E9A220X5ZBKU&coliid=I18D34G3PH9V2
Any reason to not use this for a little extra height over the 2.5" sets? Is that .5" cause too much angling of joints and is why most use 2.5"?
Your gonna get blasted with ppl saying 3 in is crazy and ludicrous...But I have the MF 3 inch front and 3 inch blocks out back. I have had no problems clunks or noises. Live in mass and drove from ma to FL over the summer trouble free. Now I've driven dirt roads albeit not bad massive bumpy roads still no prob. Mass has a lot of crap roads...Potholes, crack, bumps and o try to drive around them even hitting them no problems. I've use 4wd and no probs. Obviously when I'm out of warranty I'll prob go taller with a better lift system but until then I'm very happy
Just go with 2.5. You won't notice much difference anyway. It's not worth that additional added stress. Contrary to the last post, ask anybody here or any mechanic with knowledge, 3 inches is just too much stress on cv axles and ball joints without correcting them with control arms and a diff drop.
It's only a matter of time if you actually use 4wd or go on anything besides concrete until you will have front end issues on a 3 inch level. 2.5 is max for your front end to last somewhat decently.
Exactly you won't notice much difference and in that 2.5 isn't a whole lot better than 3, it is minimally better. Not sure how 2.5 became the "safe" zone but it is still pretty rough on your front end. 1 inch is worse than stock. 1.5 harsher than that and so on until the max amount of spacer lift that will fit. So everything in between there is proportionately worse from stock. Issues might not surface for 50k+ miles or sooner too, each is different.
If you have a 3 inch level and you are waiting until after warranty to do a level, the chances of you having a 3 inch level and it being warrantied is minimal.
Tyler
Here is the dealership's photo of my truck with the mud tires they had on it (federal cougaria 33x12.5x20). I made them throw in new tires for the deal, same size 33x12.5x20 nitto ridge grapplers. It only rubs when I got it turned all the way to the side, I can see faint rub marks on the inner fender. But the dealership said there was no level kit or anything on it and they said I would have no problems running those tires, since that size was already on there at the dealership. Just got my 2" RC level in the mail, will I have any additional problems with that? Any input is greatly appreciated.
)IMG_1376_zpscfy8vxsu.jpg?w=280&h=210&fit
It doesn't look leveled, but it looks overstuffed. You'll like it with the level kit on it better, but it could possibly look saggy without the rear block.
Blocks are cheap, so you can always add them later. Put level on it and get it aligned....bam...done.
Thanks. Will adding a 2" or 2.5" make a difference for better or worse on my control arms or anything? In respect to having 12.5" wide tires...
Will do. Won't be for a while though as I'm currently building a house, hope to do in by the end of the year. Here is a pic of a Sierra with a 3.5 level and 285/55r20. So picture this but 1 inch less and white. That's my set up, same wheels too91349dd931e7a3c0dbdf9f50a8810a42.jpg
Sent from my treestand using Tapatalk
>>>>does anyone know what nerf bars these are?
Rough country
Well I broke my ball joint thread on the passenger side so now I have to replace my whole upper control arm. I'm going with moog control arms, might as well replace both sides. Is it straightforward replacing the upper control arm?
Edited by wcgreen20
Installed. 2" RC level kit today. All I did was disconnect the bottom of the strut and loosened the ball joint and I was able to slide the level blocks in at the bottom. Took me 35 minutes a side. Anyone else install them like this vs taking everything apart?
    • I am not techy at all but wondered if you have the truck running but sitting still in park as some functions gray out as soon as the truck is moving. I believe in the settings for updates you can choose for it NOT to update and I wonder by chance if maybe that was chosen before and now it won't allow you to chose to press update, I think that is back in the settings menu where it has all the items one wants on or off etc. Also I assume you have a wifi connection and checked that it has some signal strength, not that it would have anything to do with the grayed out updates choice in that case. What I am thinking out loud of here may be be of no value but thought I would suggest it, sometimes it can be the simplest thing that resolves an issue.
    • The so called rare failure that some certainly liked to tout ( die hard Ford fan boys ) as per the lifter failing and wiping out the cam. Back when it started happening the blame was being pointed to the lifters and honestly I never did hear anything myself conclusively one way or the other on that. Ford themselves in I believe 2024 had a technical bulletin I will call it that came out and for some engine platforms they were reprograming the engines idle speed but also they had a software update for the oil pump which then some time later was said what that software update did as to be increasing the oil pressure at idle. It is a good question if that issue was completely solved as one Ford specialist mechanic youtuber said he saw failures after that time period. Like anything there would be the variables, what oil is being used and the OCI and how much idle time gets put on an engine. I've seen some comments to claim that the L8T isn't so happy with high idle time either but I also know that companies that require their vehicle to idle a lot on the job don't tend to get the oil changed often enough for all those hours of idle time and go off of the odometer.
    • My 2026 Silv. 1500 WT (reg cab/short bed/4wd) has the 40/20/40 with storage in lower middle seat as well as the fold-down center bolster/armrest.   With the dual glove boxes this is about as much storage as possible in a std cab IMHO. Bill
    • I have a 2026 base 1500 "WT" regular cab with basic Chevy "Infotainment 3" 7-inch screen/radio. How many speakers do I have If I want to upgrade? Is the audio amp separate from the radio/display unit]? [I listen to classical and it gets a bit raspy at slightly higher volumes. Don't need a sub etc.] Do I have two or 1 speakers in the doors? etc. Thanks Bill  San Jose
    • probably won't get a response from that user, as they haven't returned to the site since making that one post.  users don't (at least I don't, and I haven't seen any setting which would notify me via say, email) get any notification other than going to this site, and checking if they got a response on their thread...
