Looks good. What brand tire? and what brand wheel and offset? 20x9?, 10? No rub?
I own a 2016 Silverado, and it comes equipped with lane keep assist and forward collision warning systems. My question is, will adding a leveling kit affect the functionality of the systems? Has anyone had any issues, or have you had no issues at all? Thanks in advance!
I was concerned about the exact same thing. The answer is no, it will not affect either one one of those. I installed a 2" leveling kit last weekend and checked all those things and they work perfectly.
I agree. I have a 2" RC Level and have zero issues. Works flawlessly.
Does anyone know of any good shops to get a leveling kit installed? I'm in the Phoenix Arizona area. I want to know that the job will get done 100% flawlessly.
Ok. I know this has probably been asked and probably even beaten to death.... But I have a 2015 Silverado I bought a few weeks ago. It is 2 wheel drive. I am thinking of a 2in leveling kit on the front. I am wanting to keep this truck for a long time and was wondering if there are any down sides to doing this? I am just wanting to take out the rake but don't want to lower the rear. I will need a alignment correct? Any long term effects on the front end with only 2 inches? Also any particular kit better than another? Thanks for any input.
Really want to know if safety with wheel spacers is really a concern. I'd like to put 1.75" spacers on my 2015 (after leveling it) because I really like the LTZ chrome wheels. Some say unsafe, and most shops won't work on the truck, etc. Anyone have any words of encouragement with spacers, such as BORA?
Anything over 1/4 inch spacer is not recommended. It's unsafe and I'd never use them. Wheel adapters and spacers imho should never be used.
Got rid of my 14 sierra and got the 16 model now. 3" level went on today and tires will be on tomorrow. Here is how it sits now with stock tires
(Old toy)
(New toy on the left)
  • Like 4
It's not hard at all to do it yourself. Of course you'll need an alignment afterwards.
I've come to understand that 2" is safe. Any higher than that is questionable as it reduces the travel of the front suspension too much. If you do go higher than 2", you'll want to add the additional spacer at the top of the strut as opposed to the bottom. The spacer at the bottom reduces downward travel and it's best there as opposed to the top of the strut which reduces upward travel. The kits that give more than 2" are split between upper and lower with 2" on the lower and the additional at the top. I went with 2" Rough Country. Relatively easy install and a lot of guys on here have as well. Edited by '17 Sierra
I've been doing some digging and watching some YouTube tutorials and it does seem pretty easy. I'm going to go with the 2" Rough Country spacers. I figured I'd buy the part and whatever I was going to spend on labor, I would just spend on tools haha your replies are very much appreciated my friend!
    • *Your
    • I'd guess that it's because they are Mann-Hummel filters since about 2016, they own Wix and are mostly all made in China now.
