This is my truck so far, waiting on the leveling kit to get here. Tinted windows, removed 4x4 stickers, 20" wheels. 275/60/20's, polished emblems, TonnoPro
This isn't my truck. The dealership ordered in a set of the new Bushwacker smooth flares and put them on a truck so I could see what they look like. Thought I would share it so others can see.post-125934-0-41629200-1395406343_thumb.jpg
Here's mine. The first two pics are at the dealer's back lot right after it was unloaded off the transport.
Just picked it up on Tuesday. Stealth gray, jet black perforated leather, sunroof, heated/cooled seats, driver alert, Bose, 20" wheels, chrome steps pkg, off road pkg, nav, front/rear park assist, backup cam, 4x4, 6.2L
Traded in my 2011 White SLE for a 2014 Black SLE
Mods so far:
Tinted windows, Added factory assist steps, Flowmaster duals (side exits)
Mods to go:
Drop, 24" or 26" black rims with chrome trim, Change mirrors and door handles to chrome, HID's, Tune (98 MPH just doesn't cut it for me. Lol)
Edited by Thaheavyone
Can't get enough of mine!!
Matt you have got to get a license plate filler piece on the front of that truck! Then it would be perfect. I had to order one from dealer about 90 bucks.
Here's mine. Just window tint, Westin bars, bakflip G2 and black emblems.and removed 4X4 stickers
Edited by Fyreman97
Just pick 'er up tonight.. SLT 4x4, Iridium w/ jet black interior.. LOVE IT!!
Added 2" Rough Country Level kit. Also took off lower front valance. post-128234-139561548441_thumb.jpg
Sent from my LG-E970 using Tapatalk
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
    • Just don't turn the steering wheel as much?
