attachicon.gif20150628_104538238 compressed.jpgattachicon.gifIMG_20150626_171249 compressed.jpg
Always changing. Recon finally released their third brake light so replaced my Anzo. Amp Research powerboards were a great addition. Check out more pics on Instagram @tstehle07
I really like the dual exhaust out the back
Sent from my iPhone 6+
Thank-you, that was designed by my local shop Keystone Styling, it sounds really good also
Thought I would get in on this, some nice looking trucks out there everyone. Mine, 2015 GMC Sierra, 2" level kit on front and went with Nitto Terra Grappler G2 all terrains. I also took off the air dam in the front due to some recommendations on here and I must say, it looks better with it off. Have had no problem with tires rubbing and very smooth ride on these AT'spost-145611-0-48430000-1435965664_thumb.jpgpost-145611-0-40867600-1435965696_thumb.jpg
Happy Independence Day!
Thank you to all of our servicemen and women, past and present for your sacrifices to make this country great!
Edited by tootall87
  • Like 4
Hello everyone. I ordered me a 2015 ltz crew cab standard bed with the 6.2 2 wheel drive. I'm in the works of debaging the whole truck and changing out this powerslider back window.attachicon.gifIMG_8564.jpg
Hello everyone. I ordered me a 2015 ltz crew cab standard bed with the 6.2 2 wheel drive. I'm in the works of debating the whole truck and changing out this powerslider back window.post-145646-0-24190100-1436057408_thumb.jpg
Edited by Silver ice 6.2
Got the ole 'Merica Mobile out for Independence Day, thank you to all past and present serviceman/woman. This country is proud!
Edited by philbilly20
Hello everyone. I ordered me a 2015 ltz crew cab standard bed with the 6.2 2 wheel drive. I'm in the works of debating the whole truck and changing out this powerslider back window.attachicon.gifIMG_8564.jpg
I just blew out my back window, I don't have the powerslider and was considering upgrading to one. (Assumed when I ordered my truck it was coming with it)
Dealer quoted me at least $3100 for the install, harness and window [emoji52] I said forget it. Now if you're changing from powerslider to flush rear window, I'm sure it won't be as bad but who knows
Traded tires for Goodyear A/T w/ Kevlar, I wanted Dueler Revo 2 but they were on back order...I'm glad they were these Goodyears are awesome they are quiet, great ride and they handle better than the factory Goodyear SR-A's.
where did you get the denali grille?
well I did a swap and $1,500 cash I'm so much happier now. I didn't want the power window but apparently it's standard with the ltz trucks
    • Length/amount of data capture will be important to consider, sifting through 5 minutes of a data log can be enormous when it is stored in milliseconds. Being able to find the 'event' let alone decipher it.   Presumably the driver would notice something and hit a button to capture the 'window' of data. That window has to be large enough for the operator to recognize the event and react accordingly.    The data has to be able to be retrieved easily.   The data has to be able to be understood. Which is the biggest challenge, dealer techs won't even know what most of it is and would likely not even look at it if an owner brought it to them. Meaning the owner, the least educated/qualified, trying to understand it.    How will the data be presented? Could specific PIDs be selected and a timelapse graph be watched? How will a specific value be noted as abnormal? Additionally, a good data logger would be able to 'learn' normal values for a specific vehicle and flag abnormalities automatically. It could in theory watch parameters degrade over time and suggest maintenance as needed. (If the MAF reading begins tapering off for a given set of other readings - MAP, throttle position, Ambient, etc.. a flag to check air filter.) With the amount of data available, a device (really the vehicle rather than an additional accessory) should be able to do more than issue a DTC. It should be able to run the full diagnostic suite automatically and present a solution rather than a code. (It's not the 90's anymore). The technology is available for the vehicle to not just say "P0087", it should know low fuel pressure, check other PIDs to narrow down the problem itself, and determine if it is a lift pump, high pressure pump, regulator, leak in the fuel line, clogged filter, etc. Even if it can't narrow it down, it should be able to guide the user to the likely problems.   This would be a major problem for dealer service departments, which are the manufacturers customers it is in their collective best interest to NOT have this available to the consumer.   Further, if the owner is going to be the primary consumer of the data, it's got to be at a consumer price point vs. dealer only specialty tool price.   This group is more 'involved' in their vehicle than general public/consumer and will have knowledge, experience, needs and desires that are quite different from the market at large.
    • I put the prof up. If you read what I posted. You can see that housing, cars and income are in line with the era we were talking about. It’s harder in some places easier in others. Let’s agree to disagree and put this back on track, OK? We both are pretty stubborn and hard headed. But I bring receipts. If you wish I will not respond to you in the future.
    • Lets see if I can sum up two pages of nothing useful.    You want to refute your own governments data of the "Purchasing Power" Index FOR THE ENTIRE USA and its territories replacing it with the experience of a single family and its business and label that reality?  Then pound on that for a week hoping it will find traction?    Stan, I've told you several times. I don't do irrational. There are more people in the USA than your family.    I'm pretty sure this tread is so blown up. I'll give you a few days or months if need be to post yourself silent then I'll see if I can find enough parts of the train to reassemble it.
    • Facebook groups hate VSE, poor customer service; their responses to criticisms are pretty poor for a reputable company. I'm not a customer, haven't bought anything from them, but how they handle themselves on social media is a definite "No" for me.
    • $10,000 for a transmission?   Pretty sure I could buy all the parts, tools, and education to rebuild it myself for a quarter of that amount.   or swap it out with a new one...
