2015 Silverado
-(Front Air Dam Removed)
-Airaid Intake System
-Flowmaster Outlaw Exhaust
-KMC Rockstar 2 Rims
-MGP Caliper Covers
Trying this post again, my new rims and tires with the tow mirrors on. Definitely liking the new look!
What size lift and tire setup? Could you post more pics? Side/rear view and the tow mirrors? Looks great!!
2015 Silverado
-MGP Caliper Covers
How's the flowmaster outlaw sound?
Sent from Tapatalk App - Samsung S6
This should give you a good idea
Ha, nice video.
Trucks looks good Wantavant!
Debadging not only looks better, saves time when washing the truck! Did mine a couple weeks ago.
Updated Pic of the front of my truck with Rigid D2 Driving lights and Dipped GMC logo.
Enjoying those new fogs?
Sent from my iPhone
2015 Silverado
-MGP Caliper Covers
Any pics of the mgp caliper covers I've been thinking about getting them
Sent from my iPhone
I love them. I almost try to drive more at night just so I can use them.
Still looking for bigger tires, retrax cover for know. Love these trucks. 0ce596de836604bb5da38e04434ff46d.jpg
I think the 2500 HD Denali is the best looking truck on the road. (Especially with those wheels!)
I would consider that vehicle as my next one. A couple questions: 1. What engine? 2. Fuel economy city/highway? (Gas mileage would not be a huge factor unless it would be half of the 1500).
Thanks! Bill
Just picked this beauty up tonight! Should give me something to do for a little while!
  • Like 5
Thanks, I have the Duramax which this is my 3rd one. Mileage as of now average I say is about 16-19 depending on how I drive.
Thanks! Bill
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
