Just bought this GMC Sierra yesterday. Love it so far but only have 200 miles so far.
Great forum. Lots of information on here.
looks good
Got my truck back from the dealership installing the black Denali door badges and black side molding. As you can tell I have color matched the mirror caps and door handles. Took the chrome window molding off and replaced with black. I haven't finished all the changes yet but wanted to post the black badges.
Looking forward to some pics, I'd love to have glossy lettering.
  • Like 7
Had to pull the boat out of the water for some service. Not attached to the truck in the pic, but this and a cold beer is all the love a man needs right there.
Edited by Kerrslight
  • Like 4
Damn that boat makes that truck look tiny lol
Sent from my Nexus 6P using Tapatalk
Wow that looks great! Nice truck sir. They did a great job of aligning the letters.
What lift and tire?
2.5 RC level w/ 2" block. 33x12.50x20 toyo MT
Just bought it, need to remove the dealer emblems, but it's a pretty truck
Nice truck. I contacted Ewing first to purchase mine since they were closer but they didn't have the one I wanted in stock at the time.
Blue looks great
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
