Specs on lift/ wheels and tires?
Leveling kit up front and rear blocks removed.
Wheels are 17x9 -6 offset Pro Comp 31
33x12.50r17 Nitto Ridge Grappler
2 hours ago, KJS Sullivan said:
When doing a 2.5 frt level , does this cause a harsher ride? my concern is doing this on a 2500 that already has a stiffer suspension. Thoughts?
On a 2500, for that reason, it’s best to spend a little more for a traditional suspension lift.
I wouldn’t waste my time leveling a 3/4 ton. I always spend more for the upgraded suspension components. But as you know, that’s just my opinion, I can send you some great options for 2500’s if you need some.
Sure would like some options   i will be using a plow and that added weight brings the front down to much for my liking.  We currently have air bag lift in the rear that's adjustable.  I'm open to a reasonable lift on the front that would not add to an  already rough ride of a three-quarter ton.
It really comes down to how much are you wanting it lifted and how much are you willing to spend.
I used to have a 2-inch leveler on the front which was sufficient in height and it had a very rough ride after install so on the new truck I would like something different that would give me to three inch height but a maintaining the ride quality. I don't care about money I would think 1,000 to $ $3,000 the company is paying for it
That truck looks great man. I really like the wheel/tire combo. What size tires are they and do you have a leveling kit or is that all stock suspension?
Thanks! It currently has stock suspension, but I’m doing Bilstein 5100s soon. The tires are the stock sized 275/55/20 too.
Turning the stock keys won’t do anything to the ride quality unless you go all the way up and ride on the bump stop. It doesn’t change the spring rate of the torsion bar. Full suspension kit for this truck is a great modification... however you either have the relative leveling type or the frame cutting type. 2.5” in the front can be done in the driveway with 21mm(iirc) combo wrench/socket set. Don’t waste the money if you don’t have too. Crank it and drive it around for a few miles and take a few curbs to see if you like it. If not, dump a few thousand into the suspension. If you do like it, but a set of shock spacers and install them as they will make the ride dampening smoother.
We have had many torsion bar set ups over the years and you are the first person I have heard say cranking a torsion bar will not make it ride worse (except at the max). A torsion bar is a linear spring, each turn makes it tighter and increasing the spring rate. So 1 turn will make it a little stiffer than stock, 5 turns even more so and so on and so on. If he wanted to crank it even 1.5" it would ride rougher than stock but not as rough as 2.5". It basically is like a per-load spacer kit in how it acts with the spring is a good way to describe it (and how bilstein's work). My suggestion if he wants a little more since it is easily reversible is to check out how many cranks equal how many inches and find a number he wants to try, turn it up and drive it around a little and see how it rides. He may not notice much as ride is subjective to each person, or he may notice a big change. He doesn't like it, take that many turns out and go find an actual lift that leaves the torsion bars alone.
Tyler
Edited by amxguy1970
Tyler
You’re correct it’s a linear spring. Turning the key doesn’t load the spring, there is the same amount of weight on it. The key and suspension arms are the only connection pieces, correct? How does the spring increase it’s spring rate to become stiffer? All you are doing is reindexing the linear spring.
2 hours ago, Skidsareforkids said:
As she sits with her Corsa exhaust and Suspension Maxx 1.5” spacers...
Sent from my iPhone using Craptalk Pro
Looks great!
Recently traded in my '06 for this 2015 LT. I've already added 275/60/20 KO2's and Bilstein 5100 level set to the third notch. It did great towing my Jeep this weekend, felt much better than my old truck.
Edited by UNTsilverado50
9 minutes ago, Glen Kierstead said:
2014 Z71 LT 6" Pro Comp Lift 35" Fuel Tires and Fuel 22" rims.
truck2.thumb.jpg.46f456afb4420ac1f72409cee977e2ff.jpgtruck5.thumb.jpg.8a0e661c405762873cc813b4feee90fa.jpgtruck4.thumb.jpg.d372411c8edd3863b10030d9cb2414b1.jpgTruck1.thumb.jpg.91eab3981ff5be1560aaf43c4ab369ea.jpg
Welcome - Truck look's good . where did you get the grill insert from ???
    • I understand that. The price is what it is, though. The price is what oil costs today, where our choices have led us, where supply is, and where demand is, in the market that is. Speculation is for futures, what we think the price will be, but with incomplete information at the time the price is forecast. I know you know this, but you appear to be intent on making a secondary point here about what you think the market could or should be, if only other choices.   In 1975 it became illegal to export US Crude. I'm conflicted on what the best answer is. Free markets allow export in pursuit of profit. But there is also a lot to gain by producing and consuming our own oil here. How do you reconcile it?
    • That sir is a choice. And even if it were not for all the reasons stated, this disruption has zero to do with the reality of the actual logistics and everything to do with the greed of SPECULATION. Spot price is irrelevant to reality.
    • What I think you're saying is there is supply here at home, and in Venezuela, and we could ease pricing if only it were favorable to do so.   Well, yes?   But that's not the current market. Supply isn't what could someday exist, if only, it's what producers are willing to produce and sell at a certain price point.   The national price of single family homes would come way down if we'd just slap together a few million homes this summer.   RAM and GPUs would get a lot cheaper if we just set up some factories to produce a bunch more and stopped using it to build out AI data centers.
    • The turn signal/multifunction switch is faulty.  I've seen a few of these go bad at work.
    • I am experiecing the same issue, I have gone in the setting and disabled rain sensing function but I am still experiencing this. Whe i use my turn signal they will redomly turn on. Sometime they stay on and others times we swipe 2 or 3 times and stop. Its super anoying, escpecially after a fresh wash. Anyone have any advice? . rain-sensing function, but I am still experiencing this issue Sometimes they stay on, and other times we swipe 2 or 3 times and stop.It's super annoying, especially after a fresh wash.When I use my turn signal, they will randomly turn on. I am experiencing the same issue. I have gone into the settings and disabled the rain sensing function, but I am still experiencing this.
