1 minute ago, 18SierraAT said:
Those Z,s came out nice.... those lights on top of the cap are a nice touch as well !
Thank you, it was nerve racking drilling into my new roof but the smoked cab lights was worth it
285/70/17 falken wildpeak at3 17x8.5 American racing.
Looks good! Would you mind measuring from the ground to the top of the tire? Falkens seem like they run big so I'm curious how it compares to my nittos
Edited by Borntorun
It will be Monday supposed to rain till then
42 minutes ago, Borntorun said:
Not a fan of white but ill admit that is a sharp truck without a doubt! Congrats and enjoy.......time to modify now lol
My 18 that I took delivery of today !IMG_1428.thumb.JPG.1ffb23884834790efe51393bf115ee1a.JPG
Very nice truck, congratulations
Was there any special template for drilling , or any special wiring needed?
I measured the spacing on my buddies 2500 hd and i pulled a power from parking light thats it n grounded above roof console, pretty easy just lil un nerving drilling into roof, i put a thin coat of black rtv under lights and wire holes too
Here’s my truck with the winter wheels, freshly washed.
My new to me 2015 Sierra All Terrain!
Corsa Sport Exhaust
Airaid MIT
RC 2” Level
Toyo R/T 305/55R20
Factory 20” AT snowflake wheels wrapped in SuperWrap High Gloss Black
Lund Rollup tonneau cover
DIY GMC and AT badgework and taillight tint
Looking forward to doing some more projects on it.
Edited by TXTiggr47
    • I have never seen GM instructions for the other trucks as per the HD with the 6 speed or the half tons but had got the impression that the HD trucks with the 6 speed were not having the same problem that the 10 speed and pan presented. Also video that I have seen of the HD 10 speed with the gas engine starting in 2024 model year showed that it was a real struggle to even make it work when pulling down hard on the exhaust after undoing the exhaust hanger bracket on the side of the transmission as after all there is little room for the pipe to even go down behind the Y joint as it soon would hit a frame cross member. Also that they had tried just like I did with the gasket off and no way was that pan coming out any way they tried to manipulate the pan. From that as well as the local transmission shop talking about the pain in the rear issue, I was not expecting my pan to come out because GM shows it was not even intended to come out without dealing with the exhaust piping.    It would be nice to claim, here's what you do and its easy to remove the pan guaranteed on any HD truck with the gas 10 speed but dollars to donuts the next guy trying what I did would not have the same luck as the exhaust was just manufactured slightly different and be pissed off at my claim that the pan comes out with no issue. Its more of a try and see if your particular truck might work like mine did .... or not !.
    • Sorry I didn't see this until now, but it works on both the 6 speed and 10 speeds, as well as all the half tons too.
    • Hello, I have a 2018 GMC Sierra 1500 that I recently changed both motor mounts on due to the driver's side being blown out. After replacement I seem to have a steady vibration that I can feel in the pedals and the back of the seat. At this point I'm convinced that the aftermarket "Anchor" branded mounts I used are not performing as well as OE, the only real reason I ended up using the mounts in question was because my local dealers were out a few months to get a Driver's side mount. I've tried "Neutralizing" the mounts according to the motor mount TSB published for these truck to no avail. My trans mount is also in great shape and seems to be absorbing vibrations swimmingly. As far as I can tell there is no issues idling, my idle RPM is steady and I've recently put GM plugs and wires on, however, I have not cleaned the throttle body or intake valves. Any one else have a similar experience with aftermarket mounts? Patience certainly is a virtue that I wish I exercised here. Thank you!
    • I still saw people out for runs, on their bikes/motorcylces, jeeps with the doors off driving around here the past 2 days. I guess we are just used to it here haha.   Tasted like a bonfire the last 2 days.
    • The TCM has to be flashed before it can drive.   If you installed it the way it is, it has the OS (operating system/program) from the 2010 truck you got it from. That will not match with the VIN/OS pair that your 2013 truck has.   You can do the full install. Then tow it to a dealership and they can flash the trucks PCM/TCM with the latest program for your VIN.
