Oh boy. Haha so it still rubs after cutting the metal ? That's a pretty heft offset. Love the stance though
No sir, clears 100% at least in drive. The driver side needs a bit more trimming but it's not hitting any metal anymore. So you can make it work, just need the determination lol.
Indeed, these wheels came off a lifted truck I previously owned. After being able to fit them I doubt I'd lift my truck ever again, still rides nice and looks just as good imo.
New/Better shots of my 16'
Nice stocker! She'll look great lifted a little with some 33s and Westin Pros.
It has a 2.5" RC with the rear block. But yea tires and amps or rb10s are next
my first post on here? im back to a gm full size? went from 04 Silverado to a 03 Silverado Z71, to a 07 Jeep Wrangler, to 13 Tacoma, and now back to a 16 Sierra SLT my dream truckfull.jpg. Glad to be back!
talk to yall soon
Welcome back! Nice truck too!
Sent From My Galaxy S6 Edge+
I've got the same truck but in DC. Love the rims...mine are the same style, but aluminum and 18". I wish they chromed out the 18's like they did the 20s. I've been thinking about Amps too, but it's hard to justify $1400 steps!
My buddy owns a parts store and said he could get em to me for $1k, but yea that's still a ton for steps.
- debadged the rear chevy emblem, Silverado emblem, removed z71 decals on the box
- added a z71 emblem on the tailgate
-LED's added to the reverse lights, cargo lights, and ID lights
- front window tint (not shown)
- 17" pro comp wheels/ 285/70/17 Cooper Discoverer MTP's
- Extang tri-fold tonneau cover
- 2.5" RC kit on the way
Loving the truck. More pics to come when the Kit is in
13482997_10153751591842547_1694204620052
13423533_148136985597044_1381473742_n.jp
Edited by tanner709
  • Like 6
2015 Sierra SLT Texas Edition Z71 6.2
So far only upgrade is tires...285/60 20 Terra Grappler G2 ATs
Runs ok without any suspension modifications?
looks good
Love the white! Good lucking truck!
RC 2.5 LEVEL WITH REAR BLOCK
285 65R20 BFG T/A KO2
I have the same truck, 2015 sierra all terrain and was looking to do either the 275/65r20 or like you 285/65r20 bfg's but ive seen alot of people saying you will have some rubbing with the 285's just wanted to clarify that you have the 285's and No rubbing? Your truck looks really good man!
    • Getting greedy...   The AC pump has been replaced at least once per service records, and it's been recharged twice since 2018 or so, in approximately 2 year intervals between those charges.   It was done at the same shop...clearly they were enjoying the revenue of recharging the system periodically versus actually tracking down and fixing the leak. I learned that the owner was 88 years old when she passed in 2023, so maybe they assumed only a temporary fix was needed anyway.   The system is basically empty now, the compressor spins freely, so I'm guessing it "just needs a recharge".   I vacuumed it down, and it has basically held overnight. Doesn't appear to leak under vacuum, check! So it must leak under pressure. I don't have a way to pressurize the system and pressurizing it with shop air wouldn't be great for the air dryer (which is probably toast anyway?)   The dryer (accumulator? I'm not an AC expert) has a Schrader valve, but the high side has an old ball-type valve, which are notorious for leaking. It's clearly had schmutz blown out of it at one point because the line/area next to the valve is coated old black crud, which I assume is AC refrigerant residue/oil, or maybe even dirty dye. I think I'll roll the dice and replace the valves. I have a black light around here somewhere so I'll find it and shine it around the engine bay in the dark to see if there's any dye.   I can't think of another way to track down the leak other than injecting some dye (if it doesn't have any) and having it charged up. We can't buy R134a off the shelf here anymore, so I'll run it up to Jiffy Lube and have them do it. I think I have a coupon. At the very least, the charge should last long enough for a year or two, according to history. I think this truck will be long gone by then. But cold AC is a selling point.
    • Got the truck back today.  Called them yesterday to get an update, and miraculously my truck is finished?!?! The $13k out the door was complete bullshit!  Ended up being over $14k.  They added some bullshit service bulletin that I cant even find, where they replaced my radiator without telling me or asking me, and charging me for it.  Need to do more research into it, cause they leaked the first delivered radiator was ran over by FedEX.  Sounds like bullshit to me. 2.5 Months for an engine swap, which ended up being remanufactured, not new; ****ing ridiculous.  Brakes are squishy as hell, not sure if its from sitting.  Will give a couple days to see it that figures it self out.  GAVE IT BACK TO ME WITH 1 GALLON OF GAS!  Just filled the tank the day before drop off, more bullshit.  My dash cam SD card was formatted, not really much I can do about that. 3 year, 100k GM warranty at least.  Time to sell it and say **** off to GM.  Bad experience.  Cant wait for the survey email to come through.  Overpriced Raptor R, here I come!
    • If I forget the phone in the truck, and forget the truck in the phone, and reconnect.  It works great for the day.  Truck sits overnight, and the next day is a no go.  It will connect Android Auto via usb cable, but not bluetooth.   Ive tried Everything in this thread so far, and nothing works for more than a day.   I think I might have to go to the dealer and have them flash the pcm.   thanks for all the suggestions guys. 👍
    • 2022 2500HD Crew Z71 Duramax single alternator.  Recently had the primary (water pump / fan) belt tensioner pulley bearing to fail while hundreds of miles from home of course the plastic pulley melted and belt shredded which took out some wiring. Found a replacement tensioner assembly and belt to continue now would like to find a replacement for just the pulley and bearing to have a spare assembly in case of a repeat, the rest of the tensioner is fine. Has anybody here found a correct replacement part for just the pulley and bearing? Any help is appreciated.
    • +1 for the 3.0   Perfect for 1500 pickup towing duties.   Perfect engine for a 1500 pickup period. Huge torque at stunningly low RPM makes it feel a lot lighter than it is. The fuel mileage is insane for a tall and heavy 1500... 30+ on the highway. Mid 20's around town.   It's probably not perfect if you bought a 6.2 for the braaaaaaapppppp V8 noises and wrapping it out to 6k. The LZ0 acts and sounds like a small turbo diesel and there's nothing you can do to make a small turbo diesel sound like a big one, and you can't make an inline diesel sound like a V8 diesel/big Duramax. It's a different driving experience altogether.   Drive one, I think you'll like it, though...
