No sir, clears 100% at least in drive. The driver side needs a bit more trimming but it's not hitting any metal anymore. So you can make it work, just need the determination lol.
Indeed, these wheels came off a lifted truck I previously owned. After being able to fit them I doubt I'd lift my truck ever again, still rides nice and looks just as good imo.
Yup, not a fan of lifted trucks. Most I'd go is a 1.5" body lift on my 2.5" level. After that I just feel like it's yelling "Hey look at me I have a small penis". As long as there's little to no rake and my tires look beefy under my truck I think it looks awesome. :flag:
2016 SLT Z71 Cardinal Red
Edited by MTY55
Here is my 2014 Silverado with 2.5" Rough Country Leveling Lift, Aries Stealth Series bull bar, 30w L.E.D. Lights. Side rails are factory. Undercover bed cover.
- debadged the rear chevy emblem, Silverado emblem, removed z71 decals on the box
- added a z71 emblem on the tailgate
-LED's added to the reverse lights, cargo lights, and ID lights
- front window tint (not shown)
- 17" pro comp wheels/ 285/70/17 Cooper Discoverer MTP's
- Extang tri-fold tonneau cover
- 2.5" RC kit on the way
13482997_10153751591842547_1694204620052
33x11.50 on stock suspension? What's your wheel offset?
Edited by bcbz71
I believe they are 17x9, +6.6mm, I'm currently rubbing the mud flaps full lock and reverse. Confident the 2.5" RC kit will take care of that. I'll repost when it is installed.
I like the Z71 on the tailgate, it's a nice touch since it is on the grill as well.
Sent from my SM-G930V using Tapatalk
Still deciding whether to keep blacked out or go back to chrome ????
I'd color match if anything.
Not a fan of chrome and the black looks unfinished or work truck level
Finally got around to having the Bilstein 5100 front shocks installed on the 3rd setting last weekend on my 2016 SLT. Had to get a couple pics next to my dad's 2015 duramax and hooked up to the boat. Now time to detail it and get some better pics
Edited by tcan12
Will 295 60 20 Toyo AT2 Extreme fit on a 15' all terrain with stock 20" AT rims and a 2.5 RC level?
Delete
Edited by bwilloby46
thanks for the info! im fine minimal rubbing on the finder liner, was just worried about rubbing on the sway bar/control arms.
do you recommend the Bilstein 5100 shocks with the RC level? How much do they run?
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
