Transmission engages with remote start
Fla Eagle
I just joined the site today and sure enough after i make a few post, i now have a problem with my truck. Truck has been great withno issues until i notied this problem recently. I have a 07 crew cab with the 5.3 4l60e transmission 4x4 with about 145k miles with factory remote start. I noticed recently when leaving work and I use remote start, many times the truck starts and runs for couple of seconds makes a clunking noise in the drive train and shuts off. It won't remote start again until I put the key in and take it out. Today it did it again so I thought to investigate why and i remote started when I was next to it. To my surprise it did it again, it made the noise but noticed the truck rocks back a bit. The clunking noise I think is the transmission engaging as it sounds the same as when I put it in reverse but quite a bit louder. Now the truck was parked on a slight incline so it was enough to roll the truck a bit uphill. When I started it with the key there was no noise and the truck didn't move. I tested it a few times and with remote start it always replicated the problem. The only time I notice it is at work and I park in the same place every time. I remote start every morning and it has never failed to start. I don't know if it makes the noise or if the truck rocks back any, but I am parked slightly up hill. I did it at the gas station on flat ground and it was fine. Anyone know what this might be? I am going to do some more investigating to see what variables causes it to replicate the problem.
Try getting in the truck first, do not put key in ignition, use the remote to lock the doors, then try the remote start. If it feels like it is going to do it, use the gas pedal to keep truck running. If the transmission is in reverse, you will be able to tell by how the engine feels as you try to keep it running.
There are not many reasons for this to happen. If the transmission is has issues with clutch packs or bands, they may stay applied, and that will allow the engine to drive through transmission, with only the park pawl stopping it from driving off. If the shifter is far enough out of adjustment to allow reverse to be applied with lever in Park, I would expect the neutral safety switch to prevent engine starting.
Your trans is also electrically controlled. I have little knowledge of how they work, but, may in some conditions you have a solenoid/switch/or ? sticking or leaking allowing trans to be in gear. Someone else can comment on that part.
    • Hey everyone,   For anyone looking at roof-mounted lighting for the Hummer EV, we wanted to share our M&R Automotive 50" PRO Roof Light Bar for the 2022+ GMC Hummer EV.   The curved 50" bar sits close to the windshield rather than sticking way up above the roofline. The mounting position is designed to keep the setup relatively streamlined while minimizing wind noise and maintaining full use of the factory windshield wipers.   A few details:   50" curved PRO light bar Fits 2022–2026 GMC Hummer EV Spot + driving beam pattern TIR optics White main beam Amber DRL backglow Approximately 15,410 measured lumens through the lens Mounts to factory accessory locations No cutting or drilling required Wiring runs down the A-pillar toward the AUX connections Designed to minimize wind noise Lifetime warranty Off-road use only     The 50" is an interesting middle ground for anyone who wants the visibility and mounting position of a roof bar without stepping all the way up to the larger 60" setup. For the Hummer EV owners here, would you go with the 50" for the lower-profile look or step up to the full 60"?
    • My son got a hatchback withe the aero package for like 17k new. Great little car with amazing MPH
    • Yeah, I've given up years ago with that! I was able to load a few when I first joined the site sometime around '07. Then after maybe 20 pics, it said I exceeded the limit. Now every pic I try to post says I've "exceeded 1mb".   ONE MB??? That's Windows 95 ******, lol!!
    • I get the same results with pictures. Then I figure it out. Then I forget. Screw it.
    • I guess I'm the only one on this forum who can't get effing pics to load here! Do you have to resize them to post, or am I just blocked from uploads?   I have the same luck with automotive electronics ... but this is the ONLY site on the net that I have this problem!   I'd post pics of what I'm working on ... but I CAN'T! 🤬       Just fabbed up the kickdown cable (had to extend the cable mount WAAAY out from the throttle shaft to get a full pull), and parts arrived for the fuel lines on the 940 carb conversion project. Should be able to drive this thing by the end of the day. If not for work, I'd have had this thing done SIX weeks ago.   Got the jetting sorted out last week. Had a real bad tip-in bog that I couldn't seem to correct. Friggin float height was over 11mm too HIGH! eBay purchase, so no wonder everything is screwed up right out of the box! I ended up with a larger dual-squirt accelerator pump jet anyway instead of the single. Also moved the 70 primary idle jet (4 sizes too big out of the box) to the secondary idle circuit, and installed a 57 in the primary. Runs great on the fuel bottle!    Still using the computer for ignition. Going to drive it first and see if I want to go through the project of installing an intermediate shaft with a distributor drive gear, so I can install a block-mounted distributor and run points, 100% computer free. I should do that anyway just from a simplicity / reliability / tunability standpoint. The electronics left me stranded last year a couple times! I can't tweak the timing to my liking right now because of the computer. Tried twisting the cam-driven distributor already ... and the damned thing just reverts back to where it was! That's infuriating. But if it runs well enough I might save that for next season.   Just driving it in and out of the shop to work on other projects, it feels 1,000% more responsive with the carburetor. Also fires MUCH faster when cranking. Can't wait to drive it and see if I got more than 114 ponies, lolol.   Hopefully these don't go 404 like the last post ... https://postimg.cc/gallery/MjhrmZS   Seems like that site went back to dial-up internet! Maybe they'll fix that some day ...
