I believe this whole 10 min run limit thing is about liability. I think it's a concern about carbon monoxide poisoning, etc.. Even Chris is pretty conservative about doing much with this.
Your starter isn't going to fail prematurely. You never hear about starters failing anymore. As far as I know it never would run 20 minutes unless you timed it just so- it always added 10 minutes from where you did the command. My 2011 manual says as much too.
Anyone had an issue when using remote start where seats do not heat up/cool. The settings for both are set to "on" but neither works with remote start in my '15 Sierra Denali.
I have only had my vehicle since September, so here (in Edmonton, AB, Canada) I haven't really had a chance to test the auto cooled seats. I can say for sure that my heated seats come on with the remote start, although the lights for the heated seats do not. You can only tell from the temperature of the seat itself.
Everything I've read says that when those settings are on, the truck cools the seats on "hot days" and warms them on "cold days", but I can't seem to find what temperature defines "warm" and "cold".
Mike-I'll check closer. The indicator lights not coming on as they have in the past several trucks I've owned concerned me. With only a 10 minute window, they don't have time to warm up a lot but I'll check closer.
I've noticed the same thing and we have the same vehicle. Would love to know what defines warm/cold. The heat comes right now, but I'm thinking that the seats are not coming on as well.
I have noticed my seats heat up on remote start, they aren't as hot as they would be after having them on high and driving around for a bit; but noticeably warm compared to the other surfaces in the truck in the morning. Once I turn the key I still have to turn the heated seats on. I think that's how they are supposed to work though, correct me if I'm wrong.
-Skeet
It's only 39 here currently. I double checked and the HVAC heat comes on, but the heated seats definitely are not warming up even though I have the setting turned on.
Do they work when you turn them on after a key start?
Yep, everything functions normally once I put the key in and start driving.
Different model, but I think this applies.
http://sandyblogs.com/techlink/?p=3033
"The system uses the information obtained from the Outside Ambient Temperature sensor on the vehicle. When it reads 80°F (27°C) or higher, it will allow the operation of the ventilated seats during a remote start. When it reads 50°F (10°C) or lower, the system will allow operation of the heated seat during a remote start. If the sensor reads anything in between these temperatures, neither the heated nor ventilated seats will turn on regardless if they are enabled in the personalization menu."
Thanks! Admittedly, I have never looked too hard, but that's the first time I've seen numbers around when they cool or heat. Like you said, different model, but could be accurate.
  • 6 years later...
Canadian igloo is a complete moron. I don’t think you actually live in Canada. At minus 35 C it’s bloody cold and 29 mins is not enough. “Get in and drive” guy, you really are an idiot. Nothing wrecks an engine faster than not warming it up. God, some people on here should just shut up.
    • Because single shot injectors are ancient and multi hole injectors provide smoother running engines and sharper throttle response due to the fuel being atomized better..the best lead I have is a 24lb blue top injector almost everything matches up but the injector will put out about 26lb/hr which is just outside the gm threshold.figured id ask here to see if there was an absolute answer
    • Why is my question?   Any change in injectors requires a tune. Unless you are going back with the OEM part number or a newer part number of that same injector.   Any size difference or type difference like the EV6 style injectors all have different injector data for them. And there is no EV6 injector that matches the factory 25 lb/hr size that your truck comes with. I've been messing with these trucks and tuning them for a long time and what you trying to do doesn't exactly make sense to me.
    • My 6.6 gas lt8 had lifter noise with 28000 miles bought new 2026 and while driven to dealer it threw #1 rod bearing “HD my ass” good luck with yours i hope it don’t turn a rod bearing!
    • When a condition becomes a business model.    https://www.gm-trucks.com/gm-truck-suv-incentives-pricing-2026/   Zane posted this in "Latest Articles".    The honest bottom line   Truck buyers have spent three years assuming this is a temporary condition that will break once inventories normalize. GM just presented it to investors as a durable strategy, on a chart, as evidence of good management.   Inventory did normalize. GM is at 511,000 units and squarely inside its own 50 to 60 day target. The discounts still did not come back, because the low incentive number is the goal rather than a symptom of shortage.   Plan your purchase around that reality instead of waiting for it to change. Follow our ongoing GM News coverage for pricing and incentive changes as the next-generation trucks land.
    • Thought it was raining this morning when we woke. Nope. Dew point was over 80 F and humidity 98%. Zero visibility distance. Everything was 'sweating'. I've seen rain come out of clouds but never out of Pepper or the tree trunks.    Wicked storms just missed us sliding off to the east but by blocks. Heat index about 110 F with air temp in the 90's.    This is  our third wave this month of multiple days of this type of weather. And yet the grass is going dormant and the ground is cracking this side of the street and water up the the hood opposite. Just weird stuff going on.
