On 9/12/2018 at 12:52 PM, Rally_18 said:
I'm looking into doing a catback exhaust system don't really want to hack the stock system up in case i want to go back at some point. Thinking about the Carven Exhaust kit with the progressive muffler anyone have experience with this setup or company?
I just got my Carven TR with carven 4" tip installed. I had them weld it in where the stock muffler was. I kept the resonator in and got rid of the flapper.
It sounds great i think, i like mine on the quieter side and this one is just right. It has a nice growl at startup and idle and when you get on it.
No drone but obviously you can tell there is an exhaust on when you are driving. I gotten used to is, first day i was like "ohh man, is this too  loud?"
I did remove the flapper and in V4 mode it sounds like a military helicopter is following me haha soooo no V4 for me going forward.
Go for it, you will like it. The muffler shop guy was pleasantly surprised when he started it the truck up because the muffler looks like a ricer muffler that would go on a civic lol
Edited by Ozer
Good deal man i ended up going with the Carven Progressive Catback. I love it sounds great and looks amazing build quality is top notch!
Good to hear, you made the right choice.
Add a sound clip if you can, id like to see what the catback sounds like vs my splice in job
On 10/3/2018 at 5:31 PM, Breedsrt said:
5.3l with speed engineering longtubes and catless Y pipe though MBRP part# S5086AL
Aluminum 3.5” exhaust. Y pipe came with the adapter to run the 6.2l 3.5” ball flange. I just had to order the 3.5” ball clamp and chop down one of the pipes to make it fit my 2018 RCSB z71. Truck is filthy in the video. First day in like a week it hasn’t rained.
i am in love. that sounds sooo good. are you happy with the speed engineering headers? i have been torn between those and the texas speed
No real complaints with the headers at all for the price. I would upgrade the headers to y-pipe exhaust clamps. The ones that came with them had trouble sealing. I was going to order Texas speed headers and y pipe but at the time they were out of stock and had no eta on them. I only had a week to get all the go fast parts in so the shop could get my cam swap and bolt ons done while I was on vacation. Me being a Texas guy would have liked to support my Texas business but it just wouldn’t have worked for my time frame. I wouldn’t hesitate to use either one imo.
how much power did it end up making? also what cam did you use?
372/365 with no correction factor through factory cat back exhaust. Can’t remember cam specs. It’s a BTR boost cam spec’d out by the shop that did the work.
I'm looking at maybe the Borla Pro XS to replace my stock muffler.  My truck is a 2018 Silverado 5.3 w/just over 1K miles.  I just want a little more sound, hopefully deeper too.  I do not want a loud obnoxious exhaust.  Anyone know what Borla model # is for my truck?  If not, anyone know what size in/out I need, then I could research and find what model I need.  I looked under truck and it appears to be offset intake and center output and states reversible.  If it's 3" then maybe this is the one I want.  Borla Pro XS 40359 .  Thought I'd ask here before I order though since someone may know what I really need.
Thx in advance, Don
This on a 6.2?
Thx in advance, Don
I believe its 2.75" in and out
2 hours ago, SirenRed16 said:
"I believe its 2.75" in and out"  Thanks SR16, I just home and measured the outside diameter of pipe in and out and measured 70mm which converts basically to 2.75".  According to the Borla website they do not sell the Pro XS in a 2.75".  I know little to nothing about exhaust changes.  Would it be normal for a exhaust shop to maybe use adapters to convert the 2.75" pipe to 3" in order to be able to use a muffler designed around 3"?
Any decent shop can make it work. Order a 3" and you should be good.
This on a 6.2?
Negative. This is a 5.3 rcsb truck. This was a boosted cam swap with speed engineering headers through stock cat back exhaust. Didn’t have the 3.5” Mbrp on it before the dyno tuning.
    520Zilla
    520Zilla
  • Who's Online   4 Members, 0 Anonymous, 506 Guests (See full list)
    • Hi all,   I just bought a 2021 suburban RST with 88,000 miles on it and everything has been good but I’ve been noticing within the last month or so that there are small electrical things going on and I know what the AGM batteries and all the electric electrical in these big trucks you need to have a constant flow with good voltage   That being said, I bought a new battery thinking that that might have something to do with it but today I went to get in and start it and it said no key found when I had the key right in my pocket   It also proceeded to flash the lights inside and outside for over 30 minutes as I went to disconnect the battery as soon as I touch the negative terminal, I heard the relay reset and everything come back up. I got in the truck and started it no problem.   Anyone else have this happen to them? I’m starting to think it’s the KARR system that the dealer installed short circuit stuff.
    • I don't drive this truck on a regular basis since I have a new company truck with no out of pocket fuel or maintenance cost. Yesterday I got it out to run some errands and got the title message on my DCI. A quick Google search suggested to first clean the Map Sensor. I pulled it out and it was sooty so cleaned it up and reinstalled it. Issue not resolved. My OBDII is a couple years old so didn't see any codes. Today I took it to a friend at AutoZone to get him to check it with his reader. It had the following codes: P20C3 P02BB P221F Stating the most likely solution is to replace diesel emission fluid (DEF) tank assembly.   So, I guess a trip to the dealer is necessary. I read where there was a backorder on these tank assemblies several years ago so hope that has been resolved.
    • Are you using a weight distribution hitch system with your trailer as that alone can change the actual tire pressure requirements needed. It would prove interesting to see what the actual individual axle weights are on your truck when you are hooked up to the trailer. In fact when your hooked to the trailer, typically if anything unless it has a large capacity weight distribution system that is over cranked, often the weight on the front axle will be less when hooked up vs driving empty and certainly if one doesn't have a weight distribution hitch. Really the only times one may get up there with weight on the steer axle is if there was a snow plow mounted on the front or a motorcycle on a rack or with a very large jockey tank full of fuel at the front of the box that transfers a bit of its weight to the front axle.    And of course your tires carry more weight for a given tire pressure due to their size vs a stock sized tire so there is that to take into the equation as well.
    • Great info here thank you. I just joined, we have a 2014 Silverado truck we bought about 4 years ago with less than 5,000 miles on it. It has approximately 24,000 on it now. It appears to have all the standard issues that people are talking about. Occasional charging problems especially using 110 volt, occasional blinking triangle where nothing will turn on when first starting the truck but it will reset itself if you wait 10 to 15 minutes. Noisy coupler between the flywheel and the generator. Our truck is speed limited to 74 mph, is there any way to change that? The latest issue we have been dealing with is when driving long distance on the highway at full speed the generator does not keep the batteries charged. The meter will go into the yellow/red border Zone for charge status and the yellow triangle will illuminate solid but the generator will not keep the battery charged, not sure why the controller doesn't tell the gas engine to increase RPM to increase generator output it usually stays well below 25 kilowatts even though the battery is discharging and I have to slow down the highway to 45 mph and eventually pull over and let the truck idle to charge the battery so I can continue driving at speed. Has anyone had this issue before or have any idea how to diagnosed it? When via Motors was around it they were very helpful at troubleshooting. This becomes much if the Terrain is hilly and you're towing a small trailer
    • I have the GMC accessory (REV) cover installed by dealer. Ordered with the truck.  They did a very good install job, can't find a single issue. Some water gets in around the tailgate but no where else.  You can see daylight around the tailgate but that's not the covers fault.  Installation is means everything. Guys at my dealer were seasoned pros, not inexperienced here today good tomorrow types, like many dealers employ for these jobs.   I don't mind paying for a professional job.
