Thanks for the info. Now I just have to get around to doing it. I've had the shackles for over a year now.
Lowering a 4x4 has been talked about but I haven't found anything specific on what kits people used. Rough Country is probably cheapest along with quality not being the highest on the list. I was looking at just doing the Shackle drop but feel its not much of a big change. Being in Michigan and having random winters with low snow levels one year and high snow levels other winters, I'm not sure i want to go much lower than where the front sits now.
What are people with 4x4's going with? Shackle and block removal or kits?
Kit that I was looking at was the Mcgauphy 2"/3.5" drop
http://www.mcgaughystore.com/2014-2015-chevy-silverado-1500-double-cab-2wd-4wd-2-3-5-drop-kit-34123/
What are the pros and cons with this kit. I can see the front having adjustment issues for alignment since it lowers just the spring position.
Also I want to run OEM style 22's and need to retain my towing ability.
Hey all.
New to the forum and just bought a brand new 2015 silverado lt double cab 4x4. Figured this would be a good place to start asking questions. Going to order the 2in drop shackels tonight, and probably install some time next week, anything i should know before installation? I know i'll have to drop the hitch assembly and bend those bed tabs out of the way. Any other tips or tricks to make this project go smoothly? Any help is greatly appreciated. Thanks in advance!
-Mike
attached is a pic of the the new ride :chevrolet::chevrolet::chevrolet::chevrolet:
Remove the rear blocks.
044DF323-2108-4B86-86D9-84803560B327_zps
So you can remove the blocks without replacing anything with them?
New to the site myself, but finding all sorts of good info on here. Just got my rcsb lowered and color matched. Mcgaughys kit, 5/9, riding on 285/35/22s
8 24 2015 022
I've been working on my 2015 Sierra SLT and thought I would post a few pics of it so far. I started with a Borla rear exit touring system and Belltech 3/5 drop, added KMC 22 inch wheels with 305-40-22 Grabber UHPs, a BackFlip G2 Tonneau, a Bedslide 1000 SE, 30% tint all the way around and Putco fogs and backup bulbs. I took off the factory oval tube running boards and temporarily installed a used set of ABS boards off a Yukon. I don't love the look of them but needed something to stop my 9 year old from wearing the paint off my door sills. I have purchased a set of the AMP Power Steps but now I am thinking they may extend down too far. Does anyone have the AMP Power Steps on a 2014 or 2015? If so, how far down do they extend from the body? Would you mind posting a close up picture of them extended?
I have already purchased a bunch of stuff for the next stage, I just need to get the time to install them. I have Hellwig front and rear sway bars, an AirLift 59209 Slam Air kit with a Wireless One compressor kit, A K&N cold air intake, Murimoto Sierra Spec headlight kit, Rigid Hi/Lo driving lights and Rigid diffused flush mount backup light kit. When I install the sway bars the Borla pipes will be right in the path of the rear bar. I love the sound of the Borla touring muffler so I plan to cut off the back half and have a local shop custom bend some new pipes that exit behind the rear wheel, pointing out and down, but tucked up tight to the rockers. A pair of the GMC 23238760 tips should finish it off nicely.
Next stage will be a programmer but I have not decided which one yet. If anyone has a programmer they are really happy with please let me know which model. I hoping to find one that will firm up the shift points. The transmission seems to have a light slip between the first few shifts. The dealers says they all do it but I still prefer a firmer shift. I can't help but think a firmer shift would mean a better life-span for the transmission too.
IMG 7183
IMG 6468
IMG 6467
IMG 6465
IMG 6464
All those pictures, your truck is dropped only for 3" front and 5" rear?
I'm looking for help in regards to my Stabilitrak. I lowered my 2015 Denali 1500 2/4 with McGaughys kit. It's got Magnetic suspension with those little level control boxes. We bent the rods in the rear to match the factory angle like the kit said to do. Mr. McGaughy and staff won't answer calls or return messages so here I am. At about around 5-20 mph turns on side streets or parking lots the Stabilitrak light will flicker a few times and cut throttle until I straighten out again. I have 24" wheels on the vehicle. Just had a wheel alignment. GM just reset my BCM (body control module) today as well and it's still not fixed. Any help would be wonderful. Sorry for the double post. This one has better info. Thanks!!
Hey Dan, Curious if you got this sorted out. I talked to McGaughys several months ago and they did not know when they would get MRC kits to production.
No I have not,
I've called McGaughys many times and no one returns calls. Funny they say they haven't made a kit for this truck yet when I ordered it directly from them. Also my boxes say McGaughys all over them. Magnetic suspension is garbage imo!!!
No I have not,
I see the '15 drop kits with MRC are listed as "coming soon, call for info" but the 2/4 is only for 2WD. http://www.mcgaughystore.com/2015-sierra-1500-denali-lowering-kits/ Starting to get a little more excited. I juts hope I can still add bags for when the trailer is pinned up.
Did you get the '14/15 kit intended for non MRC shocks? Was there any shock relocators or sensor rods with the kit?
update: drop shackles installed and blocks removed. pretty happy with how it came out. some pictures make it look like the ass is lower now. see for yourself. i dont know why those pictures are turned, any info on that? haha
post-147482-0-47254600-1440861992_thumb.jpgpost-147482-0-08405700-1440862047_thumb.jpgpost-147482-0-99184300-1440862054_thumb.jpgpost-147482-0-84716500-1440862060_thumb.jpgpost-147482-0-45257600-1440862065_thumb.jpg
Nice truck, mine is at 4/7. How much you pay to get it color matched?
I've decided I'm getting rid of my lift, ordered some bilstein 4600 for the front, going to go back down to stock height and I'm removing my rear blocks. I think it will look good with my 22's.
Can some one confirm this, on the 2014-2015 sierra, the back wheels doesn't line up with the fender evenly. On my 2015, the driver side wheels stuck in about half an inch. On the passenger side is about even with the front. I though it was just mine, but i got a loaner for the day and I check it out. It's the same thing. I'm not sure this is happening to every GM truck or not. It might be the cause of all the vibration that we're having. Please check. Thank you.
I noticed this on mine the other day after I removed my rear blocks.
    • Based on what I can tell, yes.   As for updating it, its a mixed bag.  Updates do fix a lot of issues, but occasionally can create some oddities.  They do more good than harm though overall.     Here's what the most current one does and a  V171 Improvements Important: Improvements will vary by model, build configuration, system, and sales region. Not all vehicles have all features. OnStar and Wi-Fi may not work after remote start CarPlay may not automatically reconnect Part of the Driver Attention messaging screen may be in English even though the language is set to something else XM may not work After a dead 12V the radio may set to Arabic at each startup Bluetooth contacts might not be able to sync with the vehicle During an OTA the 12V battery may drain Customer might see a screen telling them to return to the dealer After changing the Wi-Fi SSID or password a device may not disconnect If a device is connected on the 2.4Ghz band, nothing will connect to the 5Ghz one, which could show as slow Wi-Fi speeds Customers might have noticed Wi-Fi dropping in certain areas and reconnecting later Customer might see the top of the screen blinking during Android Auto Android Auto may not connect CarPlay audio might momentarily cut out The "Add Phone" button may be grayed out The radio may not start up   V167 Most Notable Improvements:   Outside Air Temperature is incorrect. -You may see a popup message for Engine Shift. (Corvette Only) After changing the exhaust sound they get a popup that "mode change not applied", even though it was. -When changing volume, the volume bar is for Traffic instead of Audio. -(Corvette Only) Improvements to the placement of buttons and text. -If the customer receives the message "Apple CarPlay Could not connect", the cursor might move in the opposite direction than expected when using the control knob. -Android Auto automatically starts playing their music, even though they have turned that off in settings. -Intermittently they have a red OnStar LED with no OnStar function and/or no audio. -The minimum length of the Wi-Fi password was increased to 12 characters. -The popup message "Driver Attention Check, check your mirrors or Super Cruise will shut down" may not have come up on the display when it should have. -Startup animation added for 20th anniversary of the V-Series on Cadillacs. -The Navigation app received location improvements when going under long underpasses. -In the Navigation app there are filters for charging points that the vehicle cannot use.   V164 Most Notable Improvements Most notable improvements contained in this release may include: Apps Intermittently, an “SD Card Removed” message will pop up in the Navigation app. While in the audio app, the radio may stop working. Trailer Tire Pressure sensors may not be learned in the Trailer app. Not being able to return to the home screen while in the Camera app. After an ignition cycle, the radio might go to a black screen or stop working if using Sirius XM. Spotify icon truncated on Audio app.   SXM When changing power modes with the ignition switch, the HVAC pop up might appear. During startup, the radio will show the brand splash screen then go blank. Receiving a confirmation pop-up when changing drive modes. A “Return to Dealer” message may appear on the radio screen. SuperCruise setting toggle may not work. System After an ignition cycle, the radio might go black or stop working if using Sirius XM (SXM). Settings When performing a factory reset, the radio may stop working. After performing a factory reset, the radio may stop working when trying to switch users. When trying to go into the Language section quickly after startup, the radio may stop working. Projection Wireless CarPlay cannot be connected after unpairing another wireless Android Auto device. When the Android Auto screen comes up to connect wirelessly, the screen may freeze if the Cancel button is pressed. Removed the Apple CarPlay Cannot Connect screen when a device fails to pair during the autoconnect process. CarPlay information may not show up in the audio app. Near Field Communications (NFC) chime may be heard when NFC does not work. The Cannot Connect screen does not pop up after the first connection on wireless CarPlay fails. Apple CarPlay is now functional in Guam. Over the Air (OTA) When a software update is cancelled, the downloading logo may still be displayed. Energy When using the Energy app, the radio may stop working. When plugging in the vehicle, the display might show “Now” instead of “Charging Upon Plug In.” Instrument Cluster Voice recognition can be started while on an OnStar or phone call. When downloading contacts, there is a progress bar and circles on the Recents page of the cluster. The temperature on the cluster and the display may be different. After receiving and ending a call on the secondary paired phone, the cluster may get stuck on the phone menu. Bluetooth Intermittent Bluetooth connection loss.
    • Looking for help troubleshooting a metallic like front end rattle. Figured I’d see if anyone had thoughts before I schedule an appointment with the dealer.   The rattle is fairly loud and occurs primarily when the front driver side wheel hits a bump, even fairly minor road seams. Sometimes does it when the passenger hits a bump but I don’t believe when the rear hits. Rattle still occurs when foot is pressing brake peddle so I think that rules out the caliper rattle I’ve read about. I’ve also checked the running boards and they are tight.   Most noticeable at slow speeds.    Any insight is appreciated.
    • We try to make cruise the coast. It’s where our favorite casino is. I only want to spectate. Never took a car. Always had one to take. I belonged to a club once. Even when I used to drag raced. It was during test and tune. Probably because I’m not a night owl, party person.
    • We had a pretty big cars and coffee in Indy this past weekend.  Pretty much anything and everything was there.
    • Good looking Olds, and TRX!   I haven't been into car shows either. I'm probably not a convert but I did push myself this year to attend a few select events to challenge some assumptions and try to experience car-based social clubs in a different way. I joined up with the local Hagerty group for some cars/coffee events, group drives. A month ago I showed my '94 Camaro I rescued last fall at Radwood. Had a good time, but, there was some sitting around with the car and that's the part of shows I don't enjoy as much. I prefer to be a spectator, walk the show, grab a burger, go home.   Radwood was the only era-limited event, but where it had strict model year limitations, it made it up in variety. Having Jason Camissa there was also a hoot.   Where I see old 50's car shows, doo-wop and winga dinga music stuff fading out, same with "only" vintage muscle clubs, it seems to be the activity-based clubs/events which are gaining strong popularity. Places where all cars and interests come together.
