I have a slight lean on the drivers side (like all chevys) does anyone know of a strut spacer that's 1/4"- 1/2"? To fix this lean
Yep I made one for my 14 for the lean. Actually made a few 1/4 thick worked great.
Sent from my SAMSUNG-SM-N910A using Tapatalk
I have a question for you guys, at what amount of drop in the rear do you run into driveshaft bottoming out in the transfer case or transmission?
Drive shafts are not a uniform length. Some people have had to cut and rebalance them and others haven't. My guess is they use different suppliers to source them.
You able to make me a few? I don't know the arm ratio. I'm 1/2" differance in the front and obviously is more when I sit in it. I yhink the ratio is 2:1 but not sure
Yea I got some send me your address and I'll send you some.[emoji106]
I've been talking with djm for 2 days. The 16s have dofferant ball joints so they are teyung to source the right one. I have a 16 and I'm just waiting on them
Any updates?
Yes I found I had the first round of 2016 arms which are same as 14 and 15 so I got the kit
How low are people going in their 4wd RCSBs? Will we run into front end issues like other AWD and 4wd cars/trucks?
2015 RCSB Z71 4x4 here, and haven't had one issue at all with my 2-4 drop. However, I am thinking about dropping the front a little more and would like to learn more about doing an air bag system for the rea only, so I can run level when I want to, and lift it up when I want to trailer or carry heavy loads.
What's the best way to get 1" more drop. I have a 3/7 kit waiting to be installed but I have a feeling I'll need to go 4/7
I would say the McGaughy's struts. That's what I'm gonna put on mine just gotta make sure I have clearance with the front axles.
    • Hey everyone,   For anyone looking at roof-mounted lighting for the Hummer EV, we wanted to share our M&R Automotive 50" PRO Roof Light Bar for the 2022+ GMC Hummer EV.   The curved 50" bar sits close to the windshield rather than sticking way up above the roofline. The mounting position is designed to keep the setup relatively streamlined while minimizing wind noise and maintaining full use of the factory windshield wipers.   A few details:   50" curved PRO light bar Fits 2022–2026 GMC Hummer EV Spot + driving beam pattern TIR optics White main beam Amber DRL backglow Approximately 15,410 measured lumens through the lens Mounts to factory accessory locations No cutting or drilling required Wiring runs down the A-pillar toward the AUX connections Designed to minimize wind noise Lifetime warranty Off-road use only     The 50" is an interesting middle ground for anyone who wants the visibility and mounting position of a roof bar without stepping all the way up to the larger 60" setup. For the Hummer EV owners here, would you go with the 50" for the lower-profile look or step up to the full 60"?
    • My son got a hatchback withe the aero package for like 17k new. Great little car with amazing MPH
    • Yeah, I've given up years ago with that! I was able to load a few when I first joined the site sometime around '07. Then after maybe 20 pics, it said I exceeded the limit. Now every pic I try to post says I've "exceeded 1mb".   ONE MB??? That's Windows 95 ******, lol!!
    • I get the same results with pictures. Then I figure it out. Then I forget. Screw it.
    • I guess I'm the only one on this forum who can't get effing pics to load here! Do you have to resize them to post, or am I just blocked from uploads?   I have the same luck with automotive electronics ... but this is the ONLY site on the net that I have this problem!   I'd post pics of what I'm working on ... but I CAN'T! 🤬       Just fabbed up the kickdown cable (had to extend the cable mount WAAAY out from the throttle shaft to get a full pull), and parts arrived for the fuel lines on the 940 carb conversion project. Should be able to drive this thing by the end of the day. If not for work, I'd have had this thing done SIX weeks ago.   Got the jetting sorted out last week. Had a real bad tip-in bog that I couldn't seem to correct. Friggin float height was over 11mm too HIGH! eBay purchase, so no wonder everything is screwed up right out of the box! I ended up with a larger dual-squirt accelerator pump jet anyway instead of the single. Also moved the 70 primary idle jet (4 sizes too big out of the box) to the secondary idle circuit, and installed a 57 in the primary. Runs great on the fuel bottle!    Still using the computer for ignition. Going to drive it first and see if I want to go through the project of installing an intermediate shaft with a distributor drive gear, so I can install a block-mounted distributor and run points, 100% computer free. I should do that anyway just from a simplicity / reliability / tunability standpoint. The electronics left me stranded last year a couple times! I can't tweak the timing to my liking right now because of the computer. Tried twisting the cam-driven distributor already ... and the damned thing just reverts back to where it was! That's infuriating. But if it runs well enough I might save that for next season.   Just driving it in and out of the shop to work on other projects, it feels 1,000% more responsive with the carburetor. Also fires MUCH faster when cranking. Can't wait to drive it and see if I got more than 114 ponies, lolol.   Hopefully these don't go 404 like the last post ... https://postimg.cc/gallery/MjhrmZS   Seems like that site went back to dial-up internet! Maybe they'll fix that some day ...
