Just a heads up to anyone running the McG front spindles, your spare won't fit without trimming the bolt on the bottom of the spindles. Found that out last night.
THis....had to cut end off to run 17" cookies.
Got any pics of that setup?
unfortunately not...but it is about 3/4" off the ball joint bolt end. It is pretty much now flush with the ball joint nut.
Need some new shocks now. My bilstiens are making a funky sound. Belltech or?
Pretty sure it said that in the instructions.... I lopped mine off after torqing the nut.
RT
Mine said there could be an issue with 17's but nothing about you'd be in a situation with your spare, lol.
That are lowering shocks but I think they're to short for when I enter from 6 to 7
I have the belltech street performance shocks on all 4 corners... loving the ride
It's not the ride. It's the length
Agreed, the McG fronts ride great, rears are terrible. The Belltechs are brutal on a RCSB on the rear too. Prime example of a shock designed for a heavier truck not adapting well. Not to mention the passenger side is longer than the driver side and yet it's the same part number.
McG spindles have been that way forever, the 17+ spindles will always need the ball joint trimmed. Lol... 17" wheel is a 17" wheel whether spare or not. You could always swap the wheels on the side of the flat and put the spare on the rear.
You mean too long going from 6-7, spec out shorter bilsteins. This part #33-062518 can use the same bushing/sleeves from current ones and 2in shorter.
Out of the box they're same size, not labeled L or R. When installing the rear shock passenger side appears to be longer if the truck is in the air; if the truck is on the ground they're same length eye-to-eye.
I have the belltech 2210FF on the rear of my RCSB, and it rides phenomenally. Currently looking into Timbren products to use as the bump stops. The ones from mcgaughys aren't cutting it.
    • I just can't think of the exact term GM uses for that higher gvw package without looking at the website but basically sort of a trailering package and I imagine it may also have been created to skirt around the licensing fee differences between a3/4 and 1 ton that apply in some states although ironically I believe in some states its the reverse that a 1 ton is the cheaper truck to license over a 3/4 ton. It makes no difference here in Alberta but oddly enough a 1 ton through my insurance company is a bit cheaper to insure over a 3/4 ton as its based on the insurance statistics they generate.    For sure when ever you do have the chance to weigh your truck and to be fair, try to have the fuel tank full or nearly so rather than give yourself a false sense of the truck being lighter by having an almost empty tank.    In my other comment I was mentioning stock sized tires and partly in case someone was reading this and thinking they could lower their pressure down to what your aftermarket tires are able to do with your empty truck as that is a vastly different picture in the leeway you have to play with for running minimum pressures while remaining safe. I will say also that its easy to see from reactions of truck owners that may have been more used to owning a half ton in the past or a car and be it on a forum like this or in person etc that they get so wrapped up in that placard pressure sticker that they can't get their head wrapped around the fact that an HD truck due to how much it can carry can also vary the tire pressures drastically lower than those pressures ( typically more so for the rear axle on stock sized tires ) when empty vs some car that isn't made to carry much so the tire pressures can't be lowered since it needs almost that much pressure just to carry the empty car.    If I ever do find myself in the states with this truck, I will only be too happy to switch it over to the US measuring system as then I will understand all the dash readings. The only thing that is off for me slightly with US measurements is US miles per gallon as I grew up with the Imperial gallon and to this day up here anyway speak in Imperial miles per gallon ( I don't do that on this forum though as that would confuse everyone for no good reason ).
