Yea mine currently has a 2.5" level in it with 33's so it's gonna be quite the difference for me haha
Sent from my SM-G920W8 using Tapatalk
Yea that's true.. Didn't realize how much work it was for that kit, not bad though... And i guess the shackles just allow you to go even lower?
read this if youre really wanting to do it. http://www.belltech.com/extras/docs/BBGC/6525-888.pdf
explains how the drop works and tells you the parts needed for a 4, 5, or 6" drop. Hell, get rid of the hanger and you could get 7".
Yea I had a quick glance at it, doesn't look terrible to do, just have to drop the hitch and gas tank
You don't have to drop the gas tank if you have an extra hand. You have 1 guys twist the axle a bit. And the other guy pull the leaf and slip it under the axle
Are your mcg struts from the 07-13 trucks? Don't see any listed for the new style
Hi there,
I want also to be level with either side is easy to do, lower rear or lift front. So, I'm guessing lowering will be easier as I may need just to remove a rear leaf. Will it work? or I need something else?. THanks
21273392_1442903162452747_20496910071977
Hi there,
This is not 1980. You do not remove leafs. Take the block out and add a lowering shackle. Should be level then
Sounds good, :cheers: Do you know from where can I get the shackles? Thanks
Easiest is summit but you can get a belltech or mcg shackle.anywjere. Even Amazon
Im checking in belltech website but I dont see 2500HD model listed just 1500. Will that still work? Would it matter the Z71 with the long box?
http://www.belltech.com/products/belltech/rear-lowering-components/lowering-shackles/belltech-07-17-chevrolet-silverado-sierra-1-2-ton-all-2-or-3-rear-drop-6401.html
Edited by Yoandry
Haven't had a chance to wash it yet, but here is mine with Belltech 6401 kit (6400 shackles w/spacers for block removal). Glad I bought the 6401 kit. Was skeptical on the spacers, but they were narrower than the black so you're torquing on new threads and save a lot of extra turns. I didn't have air tools available this time. Didn't do the block removal on my 14 Sierra, but always wished I had, thought it would be lower in the back. On my 17 Silverado, I got 1.25" from the blocks and another 1.75" from the shackles. Thought I was gonna end up lower on the rear, but it was exactly 3" and I'm sitting at 36-36.125" at all 4 wheel wells. Funny thing is starting out right front was 0.5" higher than left front, but leveled out after lowering the rear? Right side is about 1/8" higher than left. Magnaflow 14" muffler, Airaid MIT tube/filter, tint, stubby antenna.1f5ef7894486a9846e8517fc5454c630.jpg89d8681cba6ae7f6d07eafbaff48e224.jpg111f407fef2b240e0c454a30d254d911.jpg0ad33b8d90a1d949a666aa3ab15feacb.jpg283a1ba50820c20e748cea975efd1c7c.jpg
Sent from my Pixel using Tapatalk
What spacers?
    • Some clarification may help with some of these issues.   - Rev Industries is/was the division of BAK (now Realtruck) that makes covers under the OEM names.  So if you see one with a Ford logo on it, or if you are buying the GM Accessories cover, you are essentially buying a BAK G2 cover with different branding.   - Rev Industries now markets under RealTruck "Advantage."   - As of May 1, 2025, the Advantage covers now have a 5 year warranty.  Anything before that was a 36/36K warranty.   - Parts for the covers are available from Realtruck or BAK.  The email address to reach them is [email protected] or you can call them at 818-365-9000   - If the entire cover has to be replaced, you have to go through your local GM dealer.  Service dept opens an RO, notes the damage and submits it as a warranty claim.  Keep your paperwork handy so they can confirm when you purchased it and it's within the warranty timeframe.  Once the warranty claim is approved, Parts orders the replacement cover.  When it arrives at the dealership, service will remove and install the new one for free as labor is included under warranty.   - The Advantage covers are not the latest and greatest Gen 3 covers.  They still use the old school clamps, elevator bolts, etc...If you want the newer technology, consider buying your cover in the aftermarket world.  That way, if you have an issue you can deal directly with the manufacturer.   - Finally, RealTruck has a program with many of their authorized dealers that doubles the warranty to 10 years if the authorized dealer does the install.     Hope this helps.
    • Welcome to the group!  My '22 just crossed 150K miles.  Runs perfectly.  Oil pump belt will be done in the next 30 days or so and onward hopefully for another 150K.  Love the truck.
